Reinstall and bios update problem
After blue screens on this laptop I ran chkdsk /r and when itrepeatedly reported it was fixing errors I replaced the drive andghosted it. I did a repair reinstall and a large number of files were"not able to be copied". I reformatted the drive and ran themanufacturers disk checking utility. The fresh install also reportedcopying errors and blue screened with both 04e pfn_list_corrupt and 0Airq_not_less_or_equal errors. I ran a memory check. I tried to updatethe bios, but this requires an installed operating system. I copied thei386 folder to the hard drive and installed from there, again "unableto copy file" errors.
Does anyone have any idea what to do next. I am using a standardWindows disk to reinstall and the licence key is accepted (when it getsthat far). Thanks.
  • Simon Clarke May 27, 2008
    Laptop is Toshiba Equium A100-147
    I did have a corrupted registry and attempted to repair it. However the problems persisted even on a clean install on a new, formatted disk. I think the problem may be specific to this model of laptop.
    Master:
    Sergeant:
  • 461 Answers
This might be due to system registry, I'm not sure what operating system you are installed but below link might be useful for you to check the system registry and boot system failure...
http://etech.maiila.com/?p=27
and
http://etech.maiila.com/?p=24
All the best....
p/s : please don't forget to rate me... :)
Posted on May 27, 2008
PC bleeps only not booting
Count the beeps. That is your error. Googling it is the easiest way. You don't mention make, model and OS so can't suggest anything.
Aug 23, 2016 | Computers & Internet
I have an acer that will go to a blue screen after I type in the password then it restarts itself over again the same thing!
Blue screen errors, or blue screen of death (BSOD) errors, are the most severe errors Windows can encounter. Since Windows can not recover from this kernel level error, a blue screen is displayed with the error details. The error details contain a STOP error code, which indicates the type of error.
There are a lot of possible causes for blue screen errors, but most of them relate to the computer hardware. The cause of a BSOD error can be a temperature problem, a timing error, a resource conflict, hardware failure, a corrupt registry, a virus or simply a device incompatibility or driver error.
How to analyze blue screen errors
The first thing to do to analyze a blue screen error is to check the meaning of the STOP error code. You need to stop Windows from rebooting when a STOP error is encountered. Once the blue screen of death is shown, you can check the meaning of the STOP error code. Together with the filename of the driver or module, this will give an indication of the error cause.
Another option to analyze the cause of the blue screen error is to look at the Windows system event log or to debug the memory dump (minidump) that Windows created when the error occurred. The event log can be viewed using the event viewer. Right-click Computer in the Start menu, and then select Manage. In the Computer Management window select Event Viewer. The information in the event log can be of great help to isolate the cause of the blue screen error.
Reading the minidump requires a bit more technical knowledge, but Microsoft has tools to read the minidump.
The most common cause of blue screen errors
In reality, the most common cause of blue screen errors is a device driver problem. Outdated, incorrect or corrupt drivers can cause the system to encounter a STOP error, resulting in the BSOD.
So the easiest way to try and fix a blue screen error is to reinstall and update your system's device drivers. This will ensure that all driver bugs are fixed and that all hardware has the correct driver.
If you know which device caused the error, you can update or reinstall that driver first. The file name in the blue screen of death can help identify the driver. Look for a file with the .SYS extension and search for that file name.
If you do not have the drivers for all devices, or are not comfortable updating your PC's drivers manually, you can use a driver update tool to find, download and update all device drivers for you. Such tools will accurately identify your computer hardware, including any device causing an error, and automatically install the latest drivers for it.
In most cases updating or reinstalling drivers will solve your blue screen errors.
Other causes of blue screen errors
However, if updating device drivers does not fix the blue screen error, there are a number of additional things to try:
Load the default BIOS values - resource conflicts and timing issues can be caused by incorrect BIOS settings.
Update the BIOS - especially after adding new hardware or installing a Windows service pack this can help fix issues.
Update Windows - missing updates, including service packs can be a source of stop errors.
Check your system - run a virus scan and spyware scan after updating your definition files.
Driver rollback - if you have recently updated a driver, you can use the driver rollback to revert back to the previous driver version.
hope it helps, if so rate the solution
Nov 29, 2010 | Acer Aspire 3690-2196 Notebook
Toshiba Satellite P25-S5093 screen/boot problem
the memory cards are loose or are dirty and need the contacts cleaned with pencil eraser.
when the memory cards lose connection you lose video on screen.
Jun 18, 2010 | Toshiba Satellite P25-S5093 Notebook
After formatting my pc is unable to run
(1)When you power up the computer press F8 key thne if you are able to see safe mode and other menu then enter in safe mode.Then go to start menu->run type in run "chkdsk /r"
thne press "y" then scan your computer with antivirus. uninstall that antivirus because sometimes it conflict to windows.
then restart computer thne wait untill it check disk and fix errors.
Then you can see desktop screen.
(2)But if you are not able to enter in safe mode then you need windows disk or recovery disk.
Then boot computer with that disk.
For that when you power up the computer press F1 or F2 or "del" key to enter in bios .
Then go to boot option and set frist boot device as your cd or dvd drive.
Then save and exit settings.
Then insert disk in rom then it boot with that disk.
then follow the procedure and enter in recovery console .
Type in console prompt "chkdsk /r"
the press "y"
then it fix error on disk.
Then check in normal mode if still not load windows then follow above procedure again but this time select repair previous windows option so it repairs old windows and you get your old windows .
Let me know if you need further assistance.,
Thanks
Nov 06, 2009 | Computers & Internet
Hp pavilion dv6000 laptop ...now displays no main page/screen only a blues screen is there an easy way to remove/fix this
This blue screen error comes when there is memory related issue.
For that first REFix your ram memory . It is in back side of laptop .
Then also you have to fix bugs on harddisk .
For that you need winxp bootable or recovery disk.
Then boot your computer with that disk.
You can set first boot device as your cd or dvd rom in bios when you power up the computer press F1 or
F2 or "del" key then ente rin bios then set first boot device as your cd or dvd rom.then save settings.
Then put bootablew disk in cd or dvd rom then follow the procedure then enter in recovery console mode.
Then type in prompt "chkdsk /r"
then press "y"
then it fix error on harddisk.
Then if still face problem then choose your existing windows repair option .
Let me know if you need more assistanse.
Thanks.
Aug 30, 2009 | HP Pavilion dv6000z Notebook
Laptop starts and after a while of using a blue error box falshes on the screen and turns off comp I can't even read the blue box its sooo quick!
That is called the BSOD (Blue Screen of Death).
try a chkdsk:
Chkdsk
Take the Windows XP disk. Boot from it, then DO NOT select F2 (automated system recovery) but continue through the procedure until you get to the point where you can choose between installing Windows XP and entering the Recovery Console. Once you get into the Recovery Console, do chkdsk and fix potential errors on your disks! Type Chkdsk C: /R at the prompt.
Or try a XP repair:
XP repair
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your Applications or data; it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 24, 2009 | Sony VAIO VGN-T1XP/L Notebook
Error window when starting windows xp
restart in setup or bios options
then choose to set to default
then f10 to save and exit
you may have had a virus
let me know
you may need to format
if you can't start in safemode
Feb 02, 2009 | Toshiba Satellite M50 Notebook
When I turn on my dell c600 laptop, it stays on for about 1 minute then a blue screen appears with a bios error message. How do i fix this?
From the minimal description you provided, it sounds like 1 of two things. Either OS problem/virus/spyware or bad hardware. Try to write down the message generated when the BSOD (Blue Screen of Death) appears and google it.
To scan for bad hardware (sounds like it might be a bad hard drive), use the tool Hiren's Boot Disk 9.4. Replace the bad part and then update the system/reinstall windows (if it's the hard drive)
Good luck
Jan 01, 2009 | Dell Latitude D600 Notebook
Computers & Internet Logo
158 people viewed this question
David Payne
David Payne
