Question about Konica Minolta magicolor 2490MF Laser Printer
Change k toner error message
Printer has a change k toner error message but k toner is already full......any suggestions?
  • mhill16 May 20, 2009
    I have the same problem. Since moving my 2490mf to my home office, I keep getting a message to change the yellow toner. I only use the black, so the yellow can't be out!
If you want to use the toner cartridge after the printer decides that it's empty, you can do it by going into the Machine Settings in the menu, and option 8 (at least on my Magicolor 2590MF) says "Toner empty stop?". Just change that to NO, and you're set to go.
Posted on Oct 02, 2009
    Champion:
  • 214 Answers
Try to replace it again, put the old empty one in and reboot printer, after reboot, and try changing back also there can be some menu about changing consumables, sry, don't remember right now. also you may clean the chip on toner cartridge.
Posted on May 29, 2008
I do not have a new one here. I've tried taking the old one out and shaking it and reinstalling it. It cannot be empty since I rarely use color for printing. I hate to have to buy expensive new cartridges for this printer, but it won't work with an error message about the cartridges.
Posted on May 20, 2009
This error is caused by the drive gears missing teeth on the top cover assembly. Open up your printer and remove the toner cartridges when you start to close the cover you will notice 4 white connectors that are sprung loaded and they move as the top cover is slowly shut. This is the toner motor connectors and there will be a problem with the black connector. This issue requires an engineer to remove and replace the connectors
Posted on Apr 02, 2013
Where is the ATDC sensor
If you replaced the developer unit then you already replaced the ATDC sensor. using third party toner or KMBS? if so use only KMBS
Jul 25, 2014 | Konica Minolta Bizhub C360...
Waste Toner Error Message For Samsung CLP 550
Dr. P,
Printer will display "Waste Toner Tank Full/Not Installed" error message if the waste tank is full of toner or not installed.
  • Open the waste tank door and check for the waste toner tank.
  • If the tank is full or not intalled, install a new tank.
If you have user guide, it will show you how to install the waste toner tank.
Sometimes you will also get this error message if the Waste Toner sensor is covered with toner powders.
  1. Remove your waste tank and look for the black plastic on the right side after removing the waste tank.
  2. You sould find small openings on each side in the black casing.
  3. Use Q-tips or thin cotton object to clean the inside the small opening.
for user manual just click here:
If this solution works, please don't forget to rate it fixya
For any more question just ask me.
Thanks
Iqbal
Apr 14, 2008 | Samsung CLP-550 Laser Printer
WASTE TONER IS FULL ERROR
You have to empty out the waste toner bottle... The bottle is a milky white plastic and I believe it is right under the fuser unit. It should slid out toward you. Carefully dump the toner out of the bottle into a plastic garbage bag and re install the bottle and you are done....
Dec 07, 2012 | Ricoh 4506 Copier
We have an error message CRUM 009-367 and we are unable to figure out what is wrong with it on our Dell 3110cn. Thanks
009-367:The Yellow (Y) Toner Cartridge CRUM Data error is detected.
  1. Cycle power on the Printer.
    1. Turn the printer off.
    2. Wait 10 seconds.
    3. Turn the printer on.
    4. Determine if the issue still occurs.
  2. Verify that the toner installed is Dell toner
  1. Cycle power on the printer again.
  2. If the error persists, replace the desired toner cartridge.
    • If the desired toner cartridge has already been replaced, replace the Toner Dispenser CRUM.
    • If the Toner Dispenser CRUM has already been replaced, replace the Printer.
Mar 07, 2011 | Dell 3110cn Laser Printer
I'm already change the new catridge toner but my machine still asking replace toner. how i going to fix it
Have you tried cleaning the toner wast bottle, or at least the sensor sometimes if there's dust on this sensor a printer gives weird error messages
Mar 01, 2011 | Xerox Phaser 3200MFP/N Laser Printer
Error message keeps showing to "reset black toner".
Try to reset the toner by taking it out and putting it in again.
Jul 16, 2009 | Ricoh Aficio AP3800C Laser Printer
Error message in di620
my copier says toner colection box is full what can i do
Mar 16, 2009 | Minolta DiALTA Di620 All-In-One Laser...
Ricoh aficio 2045eSP
Please make a power off and then start it. Let it to initialize then install the Ink Bottle. Make it off again. and then power on.
Try to check it out and print.
Hope it will solve your problem. Otherwise let me know if you need further assistance.
Regards
ELLIN
Sep 20, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
Poor print quality like toner low, but toner quanity is fine.
this sounds to me like it could possibly be stemming from the fuser, this is quite common on fuser that use a thin film belt for the heat roller...
May 08, 2008 | Brother MFC 7420 All-In-One Laser Printer
Konica Minolta magicolor  2490MF Laser Printer Logo
2,446 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
