Question about Slik PRO 700 DX Tripod
The screw that keeps the main pole from rotating on my pro 700 DX tripod was a metal screw with a plastic sleeve and wing turning handle. The plastic turning wing popped off during use and I would like to replace the screw. I can get parts at kenkomall but I need the part number. Where can I get a schematic view of this tripod with part numbers?
  • 3,083 Answers
You're going to have to go to the manufacturer for the parts list, and that is sometimes not available, since their repair facilities would have them, and it would take quite an effort on the manufacturer's part to track it down.
What would probably be an easier shot at figuring this out, would be to take the tripod in to a camera repair shop, and see if they might be able to give you an idea of the screw and thread size. If that doesn't help, there are hardware outlets that might be able to run down the right screw for you.
I couldn't find any internet support for this company, and if nothing else works, you might see if they have a contact phone or email on their literature that came with it.
Good luck, and hope this helps.
Posted on Oct 03, 2010
I have a slik pro series 400 dx tripod, however i have lost the vertical tilt handle and wondered if spares are available
Your best bet is probably either Ebay, or the manufacturer. You may get lucky with a tour of your local camera stores, especially those that deal in pre-owned gear.
Mar 30, 2016 | Slik Photography
How do I keep the button down when screwing the camera on
I suspect that this is the tiny locating button that sits beside the screw on the tripod.
Check your manual to find out how to remove the quick release sled. There is usually a small lever that needs to be rotated out of position and the sled lifts out.
Once you have the sled out, turn it over and you should see a small flap of metal that can be folded up and this is the means by which you screw the threaded part into your camera. Once it is tight, flip down the metal flap and then refit the sled to the tripod , taking care to rotate the lever again.
Some tripod levers remain locked while the sled is removed and they slip back into place when it is replaced in the tripod head.
Hope this helps.
Sep 17, 2014 | Sunpak PlatinumPlus 6000PG 61" Tripod
I have a broken wing nut on my hadlebar. I'm
Depends on what's broken the wing nut is quite easy to get out, the plastic block it screws into is a bit more difficult. You need to take to top cap off (the black plastic cover where the extension handle comes out) It's held by either a small screw or a pop rivet. If a rivet you'll have to drill it out and replace with a self tapper screw or a new pop rivet. The wing nut assembly will now side up and you can access the screw at the back that keeps the wing nut from coming right out. If all you need to do is swap the wing nut you're done! But if you need to replace the plastic block you have to open up both sides, remove the handle release buttons and find a small Allen/hex key to release the plastic blocks clamped to the wire rods that links to the hubs. Then you can pull the extension handle out and access the screw blocks.
Aug 04, 2011 | Bugaboo 'Cameleon' Stroller
How do you replace drives side exeior door handel for 95geoprizm
1) Remove the plug inside the interior armrest and remove phillips screw.
2) Remove armrest and two screws that hold door panel to door frame.
3) Pop the outer cover off the interior door handle.
4) Remove the interior lock knob and remove door panel by popping out tabs connected to door frame and lifting up off of window ledge.
5) Remove the two nuts holding exterior handle in place.
6) Disconnect the L shaped linkage from the handle. The trick to getting the L shaped linkage into the new handle is to feed L shaped metal pole through hole in door where exterior handle was, leaving the lower end of this linkage in its slot.
7) Feed the end of L shaped pole through the plastic 'hinge' in new handle by folding the hinge over and pushing the end of the L through both sides of the plastic hinge at once. slide the lower loop of the plastic hinge down the L shaped pole to secure pole to handle.
8) Place new handle into door and reverse the process to reinstall interior panel.
Hope this helps Tim
Apr 17, 2011 | 1995 Geo Prizm
Head will not tighten on AF2100 Pistol grip
one of the treads in the tripodas head is broken try unscrewing the grip the other way to remove it, then examine the grip, if one of the threads on the part of the grip that screws in to the head, is broken then you might be able to get a new grip, and that might work, but there might also be damaged threads inside the tripod head, in which case you neet to replace the head if you can, but if you cant, then I do not think that you can repair that tripod
Aug 01, 2009 | Slik PRO 700 DX Tripod
Plastic handle Rival slow cooker model 38511 broken
The problem is the threads strip on the bolt and nut. I took these to Home Depot's specialty fastener section (the one with the drawers of stuff) and purchased a nylon bolt and nylon wing nut and solved the problem. I is easy to remove for cleaning and all is dishwasher safe.
Apr 03, 2009 | Crock Pots & Slow Cookers
HOw to reverse Tripod reversible 3/8" - 1/4" screw
Hi there, welcome to FixYa.
That screw is just screwed into the top plate. Just unscrew it. If it's really difficult, you can use a pair of pliers to hold the screw, then turn the pliers. - Make sure you don't damage the threads that screw into the camera. You can help prevent this by using a cloth like a t-shirt. The cloth will help prevent damage incase you have to grip it hard. Just remember to be carefull.
Thanks for coming to FixYa.
Rob
Mar 12, 2009 | Slik (611613) Tripod
Need a handle
repair and replacement parts can be ordered by:
• Phone 973-627-9600
Jun 01, 2008 | Sunpak Ultra Pro 757 Tripod
Can't figure out how to straighten and level the camera
if you have lost a srew or wing nut, it will be loose where there should be one. set it up and then try to raise or move it around in one spot. iof it moves than look for a screw hole. the handle itself sets the rotation try unloosing the handle..
Dec 31, 2007 | Quantaray QSX-DigiPro 8500 Tripod
Need parts to repair pan handle
I just had this problem! I took it to Ace hardware and the guys helped me out, big time. I have a PH-358 panhandle and the same piece fell of during a shoot into some brush and dirt outside.
We (they) fixed it using a #6 metric bolt and butterfly wing nut along with two grommets (3/8 ID and 5/8 OD). It worked perfectly! Not only does it hold the handle together but you can tighten or loosen the handle as well using the butterfly wing nut.
Sep 17, 2007 | Velbon VideoMate Deluxe Heavy-Duty...
Slik PRO 700 DX Tripod Logo
167 people viewed this question
Top Slik Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Slik Photography Expert? Answer questions, earn points and help others
