Question about Garmin nuvi 250W GPS Receiver
Europe SD card wont work
Have purchased Europe maps on SD card, the files are there, my Nuvi250W appears to read the card when I do a system test, however, under Map Info all I see is my preloaded US map. If I do an inventory test, suppma is shown as erased, don't know what else to do?
  • Anonymous Aug 23, 2008
    have same problem with singapore malaysia map on sd card. insert but doesn't appear
    turn on and off, reinserted sd card, reseated mini card in holder now joy
    Scholar:
  • 174 Answers
Tap on the wrench, tap on map, tap on about map, there you should see the base map checked, and the Europe map unchecked, uncheck the us map and check the europe map by tapping on the check box. leave the menu.
Posted on Jun 16, 2008
Change country
Do you have the map checked (enabled) on the map screen? At the main menu, press the tools icon, then the map icon and then the map info button. You should see the Europe map listed. Make sure it is checked. If it isn't, then the map will be turned off. Once it is enabled you should be able to perform searches for places in Europe
May 15, 2013 | Garmin Nuvi 205 W 205w
Can we download European maps onto our Garmin 200W for travelling with motorhome
If you bought the satnav in the USA it won't work in Europe. If you bought it in Europe you can download the maps but the full map of Europe won't fit on it. You can fit Western Europe or add and remove countries as you need them. It's probably not a satisfactory solution when traveling with a motor home. You can put the map on an SD card but the nuvi 200W has problems reading maps from SD cards of 2 Gb or more. The map of Europe would take a 4 Gb card to hold it all.
You would probably be better to buy a cheap satnav of Europe. You can get them from http://www.pixmania.ie/ie/uk/xx/617/xx/1914/23/criteresn.html?sSortInfo=Prix-ASC
if you want to buy on line or Halfords shops if you prefer to deal with someone face to face. Some of them cost less than €100 and would be near the same price as buying the map of Europe.
Or if you want a satnav that covers both the USA and Europe and will work in both the Garmin nuvi 1370 or the 2370 would do the job but costs a bit more.
I hope this answers your question.
Jun 07, 2011 | Garmin nuvi 200W GPS Receiver
I am traveling ion europe and have purchased a set of european maps for my nuvi 1300. i need to transfer the maps from the sd card to the nuvi 1300
If you bought your satnav in the USA don't transfer the maps to your satnav. The USA version of the satnav won't work in Europe. If you bought the satnav in Europe you should only have to plug the SD card into the satnav for it to work.
Jun 06, 2011 | Garmin nuvi 1300 Car GPS Receiver
I have inserted micro SD card for Europe but have no recognition on the 1490T. Do the European maps only appear when in Europe ?
When adding maps via the SD card slot they will automatically be activated, to see this go to Tools > System > Maps > "Map Info" from here you will be able to see what mapping you have on your unit.
Hope this helps!
Apr 06, 2011 | Garmin nuvi 1490T GPS Receiver
Europe maps microSD card problems
You didn't mention where you live. If you live in the US and you have the SD card with the Europe maps plugged in, it's going to grab the Europe map first. Try going into set-up by clicking on the wrench symbol, then the maps symbol and then "map info". You should see your original map and the europe map. uncheck the europe map to get back your original map. This screen allows you to toggle between both maps.
- Jim
SHARCNET-USA
Dec 09, 2008 | GPS
Add Europe sd card to Garmin 660
No. When you plug in the SD card, the Nuvi will load the map from your SD card. Once you get to the main menu, select the wrench symbol, then the map symbol and then "map info". You should see both the US and Europe map. Make sure the Europe map is checked. You can uncheck the US map. This is how you switch between maps. The reason why you have to have the extra map on the SD card is because the Nuvi can only have one map on it's internal drive, one at a time.
However, backing up your US map is a good idea.
Good luck,
- Jim
Nov 21, 2008 | Garmin Nuvi 660 GPS Receiver
Cannot get map to work
First make sure you have a backup of your NEW ONE XL. You should be able to connect your XL to your PC using USB but not use TomTom home software. Your TomTom should appear in "my computer" as a drive . OR , put the SD card in a USB reader connected to a PC , that way you can look at and copy from or to the SD card.
You should be able to copy the map you have to the SD card directly ( if there is enough room on it ) , if theres not enough room , get a new bigger card , copy all the backup files you already have on your PC + the map you want. You might / should be then able to activate that map in the XL using the codes you say you have for the maps. if you try to do this using TomTom home it might have some restiction to stop you activating the required map but hopefully you should be able to do it manually as described above rather than use TomTom home. ... GOOD LUCK .
Please rate this reply if you find it useful .
Nov 12, 2008 | Tomtom GO 700 GPS Receiver
New Maps - Can't update unit
The new maps will be unlocked to your GPS using the code Garmin supplied you.
You will have to add these maps to a second SD card if your present card is full, or else purchase a larger card. Since all the Mapsource NT 2008 Europe maps are 1,395MB in size, you'll need to purchase at least a 2GB SD card.
Mar 27, 2008 | Garmin StreetPilot c510 Deluxe GPS...
Tomtom One 3rd edition - no SD slot and not enough memory
You could probably just manually delete the Canada/USA maps from the device, and copy over the europe (or whichever ones you need) to the device.
Just plug it in, and view the memory like a normal usb drive..delete the old, copy over the new.
Don't forget to use tomtom home to backup your gps device to your computer first (thus saving your canada maps for later..)
Afterwards, you would probably have to go into your preferences and choose the europe maps.
Jan 11, 2008 | Tomtom ONE GPS Receiver
Tomtom 1 (new edition) map of europe
I think you'll find that you can download it from tomtom home, with full technical help online & on the phone.
I dont advise COPYING it from a friend as you will get a symbol appear on the screen with a tomtom SD card with a large red cross through it, indicating that the tomtom knows its not a genuine copy.
Dec 02, 2007 | Tomtom One Europe v2 GPS Receiver
Garmin nuvi 250W GPS Receiver Logo
473 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
