Question about Cell Phones
Micro sd card cannot be formatted?my phone is T11 celphone?
I just copy a file from a USB but while im transferring the data an error occur unexpectedly then my micro sd cannot be formatted.
  • Anonymous Nov 25, 2008
    i have the same problem
How can i use the usb cable of this stupid T11 phone?!!!
Posted on Sep 13, 2008
Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
All you have to do is
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Insert micro SD
3. Open EASEUS Data Recovery, choose Complete Recovery - Next
4. Select the drive micro SD - Next
5. Save the data to the hard disk (max. 1GB)
6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
After all data is secure, do the process repair micro SD
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, for Win XP
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe - select Install.
3. Insert micro SD
4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
5. Remove the micro SD from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, for Win Vista or Seven
2. Then, double click the file cp006049.exe - select Extract
3. Insert micro SD
4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Insert micro SD
3. Open program HDD Low Level Format Tool, select micro SD - continue
4. Click S.M.A.R.T - click Get Smart Attributes
5. Click LOW LEVEL FORMAT - click Format this device
6. Wait until the process is complete - press OK
7. Remove the micro SD from the USB port, then insert it again.
8. Quick format micro SD (FAT file system)
9. Restore all data, to the micro SD.
I hope this information helps.
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
My lg t300 isn't reading my micro-sd card, so what should i do to fix it?
Try checking locky micro SD card on hand just in case locked. Next do an anti virus scan on your PC, usually data files have Headen infected due to virus, or did the format but not before first copy the existing data and save it on your PC. Next copy and paste data on the micro SD card. nex on a micro SD card input, and open menu phonsel phonsel, next select memory. if still not read, error mean micro SD card, and replace with a new
Aug 22, 2011 | Gomadic Car Cup Holder for the LG T300 -...
In my Nokia 5130c-2 mobile I've a 8GB Micro SD memory card. When I try to enter into Memory Card it tells Unknown File Format in Memory Card. Format Memory Card Yes/No? Every thing was going fine...
Put the SD card in a stand alone card reader, and copy the data off it to your computer. Next, format the SD card, and put it back in your phone.
May 06, 2011 | SanDisk 2GB microSD Memory Card
PNY micro small piece inserted in mobile phone and adapter to the computer, but not copy mobile phone pictures to the computer.
for reliability buy a dedicated micro sd reader as not all the adapters work.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Mar 01, 2011 | PNY 2GB microSD Memory Card
I have an 8GB micro sd card for my blackberry storm when i put it in. It says media card has inserted contains errors. to correct the errors use a disk error-checking utility on a computer. what do i need...
The chances on any micro sd card showing errors can be either the files stored in it are corrupted or the card is simply bad already. You may try to identify the problem by performing the following steps.
1· Access micro sd card through a card reader. May it be built-in in a computer or an accessory that needs to be plugged-in to a computer.
2· Wait for a few seconds for the computer to read the micro sd card.
a· If it asked you to "open the folder to view files", do so then copy all contents in a new folder on your desktop. This is to make a backup copy of your files. Then, format the micro sd card with FAT32 format. Copy all files back to your micro sd card.
b· If it asked you to format the micro sd card, most likely all files are corrupted. Try to format the card for re-use. If not successful, your micro sd card is bad already and needs replacement.
I hope this works for you. Good Luck!
Mongkey
"Understanding explains better..."
Jan 30, 2011 | SanDisk 2GB microSD Memory Card
Error 0x8007045d Memory transfer
Be sure you inserted it properly, but if the problem still persist, then your micro card is defective.
Oct 30, 2009 | Electronics - Others
LG KC550
kk to add music make sure you syn the phone and the cp do the data and all then put .mp3 on all the media files and see if it works. Then if that doesnt go to computor format the card and then put it in the phone. Otherwise you need new stuff.
Mar 13, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Transferring stored data from micro SD card on G1 to new one
plug your G1 to your PC via a USB cable that came with it .., once you plug it in you'll get a notification entitled USB connected .. select it and then choose mount ... once thats done open your My computer icon , you'll see an exrta drive that wasn't there be4 somethig like K or M .. open that and you'll see all the content of your SD card .. copy and past everything to a folder anywhere in your computer ... then all you gotta do is replace the SD card , repeat the same proccess but then time copy everything back to your new SD card .
Jan 30, 2009 | HTC G1
MyPhone T11 cant transfer via Bluetooth
ahhm madali lang poh.nong bumili poh ako ng myphone t11. ang ginawa ko lang poh. linagyan ko poh ng sd card, and ang "sd card "nya poh ay micro SD. malapit pof yon sa my lalagyan ng baterry. tingnan mo na lng po sa manual booklet nun. baka andun poh. thankz poh
Nov 05, 2008 | Lands Phones
Cell Phones Logo
158 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
