Question about Sirius ST5TK1 XM SIRIUS Radio Receiver with Car Kit
My Sirius ST5 fails to dock properly. The dock is good, but I have concluded that the radio,rather the the pins that connect to the dock on the radio, are not properly connecting. If I slide a piece of cardboard (about 3 cm thick) between the dock and the right side bottom of the radio, the connection is possiable, and will work, but only if the shim of cardboard is placed perfectly. If the shim of cardboard is off even slightly off, I will not have any antenna connection, untill I slightly adjust it to get a connection. Its the pins. Can this be refurbished or repaired ? I'm willing to mail it off for repair. I'm also willing to hand drop it(the radio) off to a repairman.
2 Suggested Answers
  • 149 Answers
SOURCE: which plug(connection) on bottom of
The small, gold, circular connector on the bottom of the unit. You can purchase a repair on eBay if the antenna connection has loosened itself from the board.
Posted on Sep 13, 2011
Which plug(connection) on bottom of ST5 sirius radio is the antenna plug?? keeps losing the antenna, i have replaced the base with the same error ocuring
Aug 16, 2011 | Sirius Starmate ST2 Satellite Radio...
Keeps coming up no antenna detected...changed antenna ...same problem
Sounds like it could be the dock itself, but could also be the radio. Do you have other docking stations to test it out in? If it works in one dock but not the other, we know its the dock that needs to be replaced. If it does the same thing in both docks it is probably the antenna connection in the receiver.
Jun 14, 2011 | Sirius ST5TK1 XM SIRIUS Radio Receiver...
I'm considering purchasing a Sirius Stiletto 2 Satellite Radio Receiver - just wondering if it can it be connected to my new Harmon Kardon 3600 avr or do I need to buy the Sirius connect SCH1 Home...
You will need to use the aux input from the top of the unit, or from the back of your home dock. If your receiver has a built in or add-on dock for the XM2GO line of radios, you will need to read here: http://www.digitalradiocentral.com/sirius-backstage/stiletto/108379-i-converted-xm2go-dock-stiletto.html
Jan 08, 2011 | Sirius Stiletto 2 Satellite Radio Receiver
I have a sirius stiletto sl100, and i use it on my slv2 vehicle kit. my wife got into an accident a while back and ever since, i am not able to hear on the speakers. i used to able to hear it, i had it...
Your audio out pins on the dock, or on the top of the radio are loose. The BGA connections on the chips inside may also be loose, but that is less likely depending on the force of the collision.
Jan 07, 2011 | Sirius SLV2 Stiletto 2 Vehicle Kit...
My receiver continues to show no signal even after a refresh by xmradio. I had left it on for 24 hrs with the receiver turned off
Your antenna pin solder joint on your dock connector is bad. I've seen this problem a lot (I buy returned sirius radios, fix them, and resell them). The antenna connector is on the right of the dock connector. It has 1 n-shaped pin (connected to 2 pads on the PCB), and 1 middle pin. The middle pin's solder joint has cracked, and needs to be resoldered. You can use any soldering iron to do it, just use flux and be careful not to bridge the pins.
Dec 26, 2010 | Delphi Roady XT XM Radio Receiver
It will not hold the signal as long as it used to.
I would try cleaning both the dock and the receiver pin connectors with alcohol, then drying and try that.
Jan 01, 2010 | Sirius Satellite Radio Sirius Sportster...
Logo only
Bad news my friend. That model isn't supported anymore. Sirius is pretty good about replacing the radio for free and discounting the accessories. You will get one for free. The docks are reasonably priced. The boombox you might be able to get a discount for. The new docks are more designed for multiple units should this happen in the future to you again (like Stratus radios).
There isn't much to service on the radios. If the board is dead it isn't worth fixing. It's cheaper for Sirius to replace it.
Aug 26, 2008 | Sirius Satellite Radio Sirius Starmate ST1...
"no antenna" message
it could be the wire that connects from the actual antenna and the radio. Even if it is new it might just be wrong from the factory.
Jun 10, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
SIRUIUS SPORTSTER
Satellite radio antennas do tend to fail sometimes. In the early days of Sirius/XM they were made a lot better, but now I've had problems with them a lot more frequently. If the antenna is plugged in securely and it still shows the 'antenna' error code, you most likely need to replace your antenna. It is possible that something else along the antenna signal path is causing your problem - Sometimes the antenna connections in the dock or the receiver itself can cause the issue, but most likely it is the antenna.
Feb 25, 2007 | Sirius Satellite Radio Sirius Sportster...
S50 stopped working
Perhaps getting a new battery will do it. RadioShack has some online. You could take you chances on eBay also. Also, because you have all the accessories for the S50, you could buy a new unit on eBay that is used.
Feb 20, 2007 | Sirius Satellite Radio S50-TK1 Satellite...
Sirius ST5TK1 XM  SIRIUS Radio Receiver with Car Kit Logo
96 people viewed this question
Top Sirius Audio Players & Recorders Experts
Steve
Oloyede Monsuru
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
