Question about Soyo Computers & Internet
Motherboard manual for a soyo K7V is needed - Soyo Computers & Internet
  • 8,197 Answers
You can get the manual on the link below. if this is not it please give the full model #.
http://www.motherboards.org/files/manuals/1/k7vt-101.pdf
Good luck and please rate 4 thumbs up and please leave a testimonial
Posted on Oct 03, 2010
I changed some BIOS settings for CPU speed and memory, now it wont boot - how do i reset the BIOS back when I cant get to the BIOS screen? Soyo K7V Dragon motherboard
Hi:) Turn the computer off but leave it plugged in so you have no static problems. Open the computer tower and on the motherboard near the Cmos Battery there is a blue or red jumper that covers 2 of 3 pins move it to the other side of the 3 pins for 30 seconds then put it back that will reset the bios to default.
Mar 07, 2011 | Soyo SY-K7V Dragon Motherboard
What does three long beeps soyo sy-p4vgm indicate? Everything was running well. Powered down, powered up..beeps thanks
might be a faulty connection/lead make sure they have secure connections
test all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive also cd/dvd/3.1/2 inch floppy drive leads
hope this helps
Sep 30, 2010 | Soyo SY-K7V Dragon Motherboard
Need motherboard manual for soyo k7v dragon plus
SY-K7V DRAGON Plus! - SOYO
AMD Socket-A Based VIA KT266A Chipset ATX Motherboard
AMD Recommended Motherboard
D: DDR266 SDRAM
R: Promise IDE-RAID (0,1)
A: CMedia 8738 6-channel hardware audio on board
G: Universal AGP Pro slot
O: Overclocking, set up FSB by 1MHz increment
N: 10/100 Mbps Ethernet by ICS PHY Controller
Specifications
Processor
Click here for maximum CPU support
Click here for maximum Front Side Bus (FSB) support
Interface
Socket "A"(462)
Chipset Type
VIA KT266A
Chipset Description
VIA KT266A / 8233 CE Version Chipset
Supports 200/266 MHz FSB
Form Factor
ATX
Memory Type
DDR SDRAM
Memory Description
Three DDR 2.5V DIMM sockets support up to 3GB*.
184-pin PC2100/PC1600 non-ECC, unbuffered DDR SDRAM memory.
*recommended to use 3 sticks of DDR200(PC1600), or 2 DDR266(PC2100) memory on this board.
Expansion Slots
Five 32-bit Bus Mastering PCI slots (V2.2 compliant)
One Universal AGP Pro slot (supports 1x/2x/4x modes)
Expansion Slot Types
IDE Type
UDMA 33/66/100
IDE Description
Four independent channels for 8 IDE devices (2 for RAID)
Supports up to PIO mode 5 & Ultra DMA 33/66/100
Two PCI bus mastering ATA E-IDE ports
Audio Description
On board CMI 8738 audio chip providing 6-channel audio solution
IO Port Description
Two RS-232 serial ports (16550 UART compatible)
One parallel printer port (SPP/EPP/ECP mode)
One FDD port (supports 3 modes, 1.2/1.44/2.88MB FDD)
Provides IrDA with optional cable for transceiver
Provides 6 USB ports (2* rear, 4*front)
IO Connection Description
PS/2 Mini-DIN mouse & keyboard ports
Two USB ports
One RJ45 connector
Two D-Sub 9-pin male serial ports
One D-Sub 25-pin female printer port
Audio I/O: LINE-OUT x 1, LINE-IN x 1, MIC JACK x 1
One game port
BIOS Description
Award PCI BIOS with ACPI function
Supports multiple-boot from E-IDE / SCSI / CD-ROM / FDD / LS120 / ZIP
2 Mbyte Flash ROM
Health Monitoring Description
On board voltage monitors for CPU Vcore, +3.3, +5V & +12V
CPU fan speed monitor
CPU temperature monitoring through flexible thermal sensor
Dimension Description
Four layers, 30.5 cm x 23 cm (12" x 9.05")
ATX form factor
Certification
FCC Class B & CE EMI Regulation CompliantPC99 Compliant
Compatibilities
WinXP / Win2000 / WinNT / WinME / Win98SE / Linux / FreeBSD
Warranty
All SOYO products are designed to offer stability and flexibility, and are tested to ensure highest reliability. We offer a 1 year limited warranty on this SOYO product.
CPU Support
Compatibility
RAM Memory Support
Compatibility
Manufacturer - downloads drivers, manuals and BIOS : SOYO
Prodejce v èR : Mo?nost vlo?ení odkazu prodejce - info zde
Recenze : Odkazy na recenze vlo?íme po dohodì
Problems, experience, griffs.....:
Jun 06, 2010 | Computers & Internet
Soyo k7v dragon plus motherboard continuous
2 beeps = memory problems. Since you get them even after the memory has been replaced then the problem is in the motherboard itself. Check the capacitors for bulging. If you can't find ones or you can't replace them then the motherboard is dead.
May 13, 2010 | Soyo SY-K7V Dragon Motherboard
Hi Jopav1,
At the age of *********** board, I would recommend physically looking at the board, in particular, the large upright capacitors. If the tops are bulging, or have anything leaking out of them, send the board to a recycler, and look for an exact replacement on the used market, or replace with new. I just bought the same board you have today for $25, with AMD 1800 CPU.
At 10 years of age, the battery is probably past due for replacement too. It is a standard CR2032 3Volt battery. If you replace it quickly, you may not loose your BIOS settings.
If you have a volt meter, you can check your power supply voltages. Again, your manual will show what voltages to expect at each power connector pin. A range of +/- .05V is generally allowable on all sources.
Also try unplugging all boards and powering it up. The beep should change to a sequence of 2-1-3-1 beeps, indicating that it's not able to see the video card. If you still only get a repeated long beep, It's possible that the CPU itself may have died. These are also available very cheap at this point. The fact that you are getting a cycling beep indicates to me that the CPU is OK though.
I looked up beep patterns and did not find anything for one long repeating beep for the Phoenix BIOS on your board. There is no mention of them in the Soyo manual either.
Last resort is resetting your BIOS settings to "First Birthday", and try again. This will require you to re-set any manual settings you had set previously (probably 10 years ago). This is done by moving the jumper located between the green LED, and the battery, to the two pins nearest the LED, for a second, and then back to the position nearest the battery.
Good luck
Video Flyer
Mar 22, 2010 | Soyo SY-K7V Dragon Motherboard
One beep then a long beep and it shuts down
This is due to there is problem with memory slot or memory modules or memory has not been inserted. Check and rectify the same will resolve your problem.
Revert back for more assistance and give your valuable feedback/rating for the solution provided.
Thank you for using Fixya.
Feb 13, 2010 | Soyo SY-K7V (SY-K7VKPE) Motherboard
Where can I get a manual for my KT600 DRAGON PLUS V2.0
I have a PDF file for SOYO KT-600 Dragon Plus V2.0. I can email it to you.
Oct 15, 2009 | Soyo SY-K7V (SY-K7VKPE) Motherboard
Need to reset Asus k7v bios
Yes, if you consult your motherboard manual this will show you the location of the cmos battery and reset jumpers. You can either move the jumpers from pins 1+2 to 2+3 and then back again after a few seconds or remove the cmos battery for a few seconds. Make sure your pc is off!
Dec 16, 2008 | ASUS VIA KX133 Chipset K7V (K7V/500/SWA)...
Computers & Internet Logo
119 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
