Question about Cisco Linksys WirelessG Broadband Router WRT54G Wireless router + 4port switch Ethernet Fast Ethern
Cannot get a network connection using my linksys modelWRT54G2 WIRELESS ROUTER
  • 2,260 Answers
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Posted on Oct 03, 2010
How can I get the router IP of my Linksys 2.4GHz broadband router?
The Linksys G router gives you both wired and wireless connections over a broadband Internet connect to create a local area network. The Linksys router is compatible with wireless G and B devices, through the 2.4-GHz wireless band. The wireless speed is at 54 megabytes per second and you can get 100 megabytes per second with a wired connection. You have to set up the wireless configuration on the Linksys before using it on your network.
Plug the router's power cable into an electrical outlet. Attach an Ethernet cable into the Internet port on the back of the router. Connect the other end into your broadband modem. Connect your computer to the Linksys G using another Ethernet cable. This Ethernet cable can go into any of the wired router ports. Open your Internet browser. Type "192.168.1.1" in the address bar and hit "Enter." This is your router's IP address and the home of its Web configuration page. Click "Wireless." Click "Manual." Alter your SSID, also known as your network name. You can change this name to any value that you want. You can also change the wireless channel if you are in an area with many wireless connections that may interfere. Click "Save Changes." Click "Wireless Security." Choose an encryption method to encrypt your wireless transmissions. WPA or WPA2 are common security protocols you can use in wireless networks. Input a network key, also known as the network password. Click "Save Changes."
Setting Up WPA Wireless Security on a Linksys Wireless Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=3696 Wireless G-Broadband Router support http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G b> b> Changing the Wireless Network's Name (SSID) on a Linksys Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=4037
Mar 27, 2013 | Linksys Wireless-G Broadband Router
Having trouble with initial connection to an existing wireless network wireless router is a cisco wireless-n broadband router and we have 2 laptops and a printer on a wirelss network already
Follow these instructions to connect to a wireless network using the Linksys Wireless Manager.
Step 1:
Launch the Linksys Wireless Manager. To learn how to access the Linksys Wireless Manager, click here.
Step 2:
In the Connect to a Wireless Network screen, locate the name of your wireless network in the list.
NOTE: If your wireless network is not in the list, click here to learn How to Connect to a Hidden Wireless Network. If your wireless network supports Wi-Fi Protected Setup kb17673-005_en.png, click here to learn How to Connect Using Wi-Fi Protected Setup.
Step 3:
Select your network. Then click Connect.
Nov 01, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
I have a linksys wrt160n wireless router,, recently I was unable to connect to the wireless device, I noticed another linksys wireless device showing up on available networks,,I live in an apartment. I...
Is there any computer connected to the router ?
If not then connect the computer to the router. If you are connecting a wireless computer then disable the wireless connection on the computer. open the set up page of the router. change the wireless network name to something different that you never used before. change the standard channel to 11. save the settings. Try to connect to the wireless network. Check if you see the new network name ? If you see the new then try t connect and see if that works.
This router WRT160N has issues with the firmware.
Upgrade the firmware of the router. power cycle the router.
Click here for more information about router and network
Feb 28, 2010 | Linksys WRT160N Wireless Router
I can connected to my linksys, but the the linksys
there is nothing issue with the linksys ist chk the ipaddress which u had provided to the modem and router is in same serious for eg: if ur modem is in 192.168.1.1 ten provide ur router ip as 192.168.0.1 and also chk whether the connection type is in PPPoE and also chk whether u r able to browse through modem which is provided by the ISP....
Feb 18, 2010 | Linksys Cable Modem
Cannot connect to wireless network
To connect to the linksy's router you will need to run the linksy's setup disc on each pc in that netwrok.
Mar 29, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
Wireless router connection problems
Assuming "cannot connect to linksys router directly" means you cannot connect to a Wireless Lan managed by Linksys router,
1) try to connect new computer to LinkSys Router using a Lan cable, add new PC to your network.
2) recover protocol (WEP or WPA) and Key of WLAN (Passphrase or Key: TKIP or AES) either from other PC on same network either from your Router.
3) If you missed actual key you must connect to router and reset it to a new key to be eventually used for every connected device.
Call for detail on this possibility
Dec 29, 2008 | Linksys Access Point WAP54GP Wireless-G...
SMC EZ Connect 2862W-G does not see Linksys network
It shows that your wireless router and wireless adapters are both working. One thing to try is changing your wireless channel. Since you are already using 11, try maybe 1 or 9. Check if your SMC adapter will pick up the wireless signal.
By the way, how far is your computer (using the SMC adapter) to your wireless router?
Oct 21, 2008 | SMC EZ Connect g SMC2862W-G 802.11g/b...
Wireless connection
Possible you did reset the router. Its okay to connect to that linksys network name. But if you want to customize you network name.
MAKE SURE TO USE THE WIRED COMPUTER TO SETUP WIRELESS CONNECTION.
Example : The Desktop computer that is connected to directly to router.
Just follow the steps.
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3967&p_created=1159257209&p_sid=aNKUFggj&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9ODExJnBfcHJvZHM9MCZwX2NhdHM9MTcyMSwxNzIzJnBfcHY9JnBfY3Y9Mi4xNzIzJnBfc2NmX2xhbmc9MSZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PUNoYW5nZSBTU0lE&p_li=&p_topview=1
Hope it will work..
Oct 14, 2008 | Linksys Wireless-G WRT54G Router
Cisco Linksys WirelessG Broadband Router WRT54G  Wireless router + 4port switch  Ethernet Fast Ethern Logo
71 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
