Question about LaCie Hard Disk 1TB Desktop with Hi-Speed USB2.0 USB 2.0 Hard Drive
I have this Lacie 1TB hard drive and i recently uploaded about 150 GB of video on it at once. I did it over night and the next morning the drive was making some noise like its working on something. Now it won't stop making that noise and the hard drive is running very slow on video playback. Can you help?
  • 4,340 Answers
Drive noises are typically a common and needed noise. Most run via magnetic (voice coil) technology and that is noisy. Slow play back may be related to connection, usually you need stuff on your harddrive (C:\) to avoid access delays.
Posted on Oct 03, 2010
Lacie d2 Quadra Ejects Itself
I've had issues with the lacie mini power supply before. I can cause some wierd issues. Unfortunately, it isn't the cheapest thing to replace but that's probably the best place to look first.
Oct 16, 2012 | LaCie 1TB D2 Quadra eSATA/USB 2.0/FireWire...
I just bought Lacie rikiki hard drives. As I put it into my computer the assistant starts. Unfortunatelly after few minutes the process stopped and the capacity is 465 GB instead of 500 GB. Is there any...
Hi.
This is normal. You will never get all the capacity for a USB key or a hard drive. The missing space is for format purpose and hard drive maintenance.
Hope it helps
Feb 08, 2011 | LaCie Rikiki Go 1TB USB 2.0 Portable -...
I have a 1TB LaCie 2Big Quadra. It has 2 500GB and runs on RAID 1. I replaced both 500 GB LaCie drives with 1.5 TB LaCie drives, but my computer only recognizes the original 500 GB. I formatted both...
I have the same problem too on my 2big form lacie . If I use 2x 1,5 tera disk in "fast mode" or in "big mode" my disk manager only shows 746 gigs available (it should be at least 2,5 terra).
If I use "safe mode" so my system can see 1,3 tera available, wich is normal for a raid mirror configuration.
I hope to find a solution quickly.
Dec 13, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
My "t " bird hard drive fell onto floor from about
The '1TB' device is 10 to a large power.
The '930GB' is 2 to a much-larger power.
Since '1GB' is 1,073,741,824 bytes,
multiplying 930 times 1,073,741,824 is equal to 1TB.
So, your device is 100% empty -- all 930GB are "free" space.
Oct 31, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
My mac does not recognize it. It was working last night and then not this morning. It did not fall and was in perfect working condition yesterday. I only bought it about 3 wks ago so i'm terribly confused...
There are several things that could have gone wrong. The least worrisome is a software glitch. Please shut your Mac completely off, then unplug the Lacie and turn your Mac back on. Leave the Lacie drive disconnected for about 5 mins then reconnect it and see if it re-appears.
If it does keep your data on both the Lacie and the Mac for the next few weeks and if it does it again get it replaced. If it does not, you should be fine.
If the Lacie drive doesn't reappear then it may have failed. I can suggest a simple program to check if it's dead or just lost it's formatting. In the latter case the program can retrieve files from it before reformatting, in the former you will need the help of a pro to repair the drive before any files could be retrieved from it.
The program I'm suggesting was recently reviewed here Once you get to that page just click on the picture at the top and it will take you to the download area where you can get a copy. It's free to download and scan but you will have to pay them before it will recover files.
Of course if there's nothing important on it yet and it's dead, I would suggest simply having it replaced.
Hope this helps FixYa,
Chris
Sep 21, 2010 | LaCie (300728U) 250 GB Hard Drive
Won't recognize drive
Have you checked the disk properties to see if the 400 GB of data is still showing. may be your data might be hidden foir some reason. can you give more details pls
May 05, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
I have a lacie 1TB exteranl hard drive and i cant get it 2 read on my dvd player via usb port...any ideas
Dows your DVD player supports reading drives of 1 TB capacity?
Check if the drive works on a computer!
Aug 24, 2009 | LaCie Hard Disk 750GB with Hi-Speed USB2.0...
Lacie 1tb external hard drive into ps3 is not regconised
I have the same issue, however with my verbatim 500g its ok. i believe it is because the lacie is a desktop external and therefore is compatable with windows xp and 7 alone.
Verbatim is a "portable" external hard drive which makes it compatible with several different systems. I would suggest returning it, I just formatted my old verbatim harddrive and set up mediaasharing. Through my router. You can actually route the lacie harddrive by going to my computer and right click the icon. Next go to share with; advanced settings and allow all. Then when you turn your ps3 on search for media servers... I would suggest to google media server for ps3 to get it all seet up. GOOD LUCK
Jun 07, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Troubleshoot lacie hard drive 500 gb
all you have to do is put it in a different computer and format it.
Jan 05, 2009 | LaCie Big Disk External USB 2.0 1TB Hard...
Upgrade Possible?
Hey Al,
The internal Drive is a standard 3.5 inch IDE 7200RPM unit. you can indeed upgrade this to a 1TB drive as long as it's IDE wether 2.5 or 3.5. Luckily when Lacie was originally offering these drives you could get these in 1TB, so that won't be an issue.
Ciza
Oct 28, 2008 | LaCie (300770) 250 GB Hard Drive
LaCie Hard Disk 1TB Desktop with Hi-Speed USB2.0 USB 2.0 Hard Drive Logo
297 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
