Question about Carrier 38CKC036 Air Conditioner
Air conditioner is blowing hot air; fun blade not working
  • 382 Answers
Dear sir
if fan motor is not working that why your airconditioner is not getting cold. please try to test fan motor by electric tester check continuity on fan motor wire one bye one. if there is all wire have continuity with each other then it,s mean fan motor is ok and problem in other device . if you can do by yourself then try if not then take help to a technician.
hope answer the question
thank you
please vote!
Posted on Oct 03, 2010
Heater is not blowing hot air little better than cool air and thermastate keeps changing settings
Thermostat changes all by itself? This is programable thermostat? connects to wifi? Childern around? or near by. Sounds like someone is having fun at your expense.
Thermostat under warranty? if so go that route. If out of warranty, Check out some ot the new thermostats.
Jan 02, 2015 | Filter Heating & Cooling
My air conditioner blows hot air and my heater blows cold air. The heater will warm up after the engine has been running for awhile but when I turn the air conditioner on it takes power away from the...
check your blower motor under the passenger side of the dash, round plastic box three screws pull it out something might have fallen though your cowl and chewed up the fan blades. as for the ac your r-12 is probly empty or has a leak bring it to a local garage and have them flush and fill your cooling system. heater would be your thermostat not openig properly, by far your cheapest fix under ten dollar part.
Apr 04, 2012 | 2000 Toyota 4Runner
Cold and hot stiky air
try cleaning the filter and fan blades.
Jan 01, 2012 | Heating & Cooling
2006 crown Victoria blows hot air with the air conditioner on the air condition lines are cold under the hood
sounds like the temperature blend door is either jammed or the actuator is shorted ou. when the temperasture control is moved you should hear the door moving...my guess is you are not hearing that..the actuator would be attached to the heater plenum behind dash/glovebox area...becareful to test the correct one as there will be a fresh air actuator and a mode door actuator as well...you can determine which one is which by changing the positions on heater head from hot/col, floor/defrost, recirculate and fresh air settings..each setting will move its designated actuatror..the one not moving would be you temp actuator....have fun!
Jun 29, 2011 | 2006 Ford Crown Victoria
Goodman A/C won't cool
Fan motor or capacitor has gone out. Running the unit with the motor not running can cause damage to your compressor
May 01, 2010 | Goodman CKL24AR24 Air Conditioner
Air conditioner blows hot air inadvertantly.
possibl ac compressor clutch problem,cooling fan at rad not working so ac goes into high press mode and turns off(so it doesn,t blow system apart,built in safety)not enough r134 in system(low charge)
Sep 19, 2009 | 1997 Chrysler Concorde
Blows hot air
My 2003 chevy suburban just started blowing hot air...it was working find , then i stopped to eat lunch, when I came out it started blowing hot air
Jun 25, 2009 | Heating & Cooling
After boost air conditioner started blowing hot air
BLOWING HOT AIR YOU MAY HAVE A RESTRICTION ON THE SYSTEM, OR MAYBE A REAL BAD LEAK THAT UR FREEON IS ALL GONE,
May 28, 2009 | 2006 Chevrolet Trailblazer
Carrier 38CKC036 Air Conditioner Logo
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
