Question about HP Compaq Presario V6000T Notebook
Won' start does not start up ,but light blinks three times
  • 1 more comment
  • Anonymous Jun 01, 2008
    does not start up ,but light blinks three times. Am trying to replace the battery-but HP sent the wrong one. As soon as I get a refund for the wrong battery, will see if the correct battery solves the problem. But all the other blogs seem to suggest that the problem is the mother-board? HELP!
  • tina4667 Mar 19, 2009
    I have the same prob. I have a Compaq V6000, it was running perfectly when I left the house, I came back 2 hours later and it was off (odd because I don't remember turning it off). I hit the power button and nothing happens (no fan, no noise, no nothin), but the blue light under the lightning bolt symbol blinks 3 times.
    So, here is what I have done so far. I unplugged the power cord, took the battery out, and held the power button for about 30-40 seconds. I then plugged the cord back in without the battery, and nothing even blinks. Then, I put the battery back in, and again i get the blinking lights, 3 times.
    Any ideas? I am about to just go buy a new power cord, but if this is something else, I need to get this fixed. Thanks!
  • Brian Canute May 11, 2010
    Can you supply a bit more detail
    laptop or pc base
    Scholar:
  • 139 Answers
Try these sites there good for yr problems: its about laptop repaires and its free.
http://www.notebookrepair.org
thank u
Posted on May 27, 2008
Sony bravia won't stay on 52w4100, clicks with green light three thimes then shuts off and blinks red 6 times
Sounds like a power board reset switch gone bad. Have the power board replaced.
Good Luck Ed Pinero
Feb 03, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
My WD-60639 DLP TV won't stay on (it goes off right after it gets on)
You should be getting a light or lights on set blinking in this case, and the set should have a self check if they blink etc---hold menu and input in at same time for more than five seconds and release both, the blinks on the power light should be a two digit code like three blinks, seven blinks which is 37 Let me know what if any code you find.
If you unplugged the set during this time it will clear the errors so you have to try to turn it on again, let it fail and do the check again.
SD TECH
Dec 11, 2012 | Mitsubishi Televison & Video
Help me, dish network hd monitor,model 34-310. made in 2004. wont turn on,on button blinks and attempts to,turn on but screen remains blank. tries three times and blinks a green light. no picture,no sound....
It is the right age for failure---IF you are able look inside at the power supply for bad caps---I will attach photos of what to look for.
The three tries is what is called a three strikes and you are out (no joke)----the unit has built into it (many do) a feature where it will try 3 times to make it up and on and if fails shuts down or stops trying.
Dec 07, 2012 | Computers & Internet
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
Sony tv won't turn on, light in standby blink three times
that is a master control board failiure, it is caused by having your TV on all the time, when the TV gets warm, you need to shut it off and let it cool down(that caused your problem) call sony and order a replacement part, it will take you about 20-40 minutes to install yourself.
Jul 19, 2012 | Televison & Video
Frigidaire dryer faqe7001lw blinking lights
Try resetting the computer like a cars e.c.m. by turning the dryer on and plugging it from the outlet. It worked for me once w our new Malta front loaders
Apr 07, 2012 | Frigidaire FAQE7001LW Dryer
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
Kindle light is orange when I charge but even after of hours of charging continuous efforts to turn on Kindle, it won't turn on.
Try to slide and hold the on switch until after the power light blinks three times (should happen after a little more than 5 seconds). Release the switch after the blinks and the Kindle should start up.
This is only necessary if the Kindle was switched off by the same method before, or if the battery was completely drained. A short nudge of the power switch merely puts it in and out of a power-saving sleep mode, the prolonged hold really cuts / reinstates power.
Jul 16, 2011 | Amazon Kindle Wireless Reading Device
Air bag light is blinking
my airbag light is blinking . can i reset anything its a04 nissaun armada
May 02, 2009 | 2004 Nissan Armada
Red light blinking three times in a row
Service manual says 3 flashing red leds = eeprom error (main digital / video pcb).
Suggest you start by implementation of Fujitsu Service Bulletin PDP 0068-01 Main Digital pcb see:-ttp://www.eserviceinfo.com/download.php?fileid=43450
Mar 31, 2009 | Fujitsu Plasmavision P42HHA10 42 in....
HP Compaq Presario V6000T Notebook Logo
179 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
