Question about Dell Inspiron E1705, Intel Core 2 Duo T5300 , 17" WSXGA+ LCD, 1GB DDR2 SDRAM, 256MB ATI V... PC Notebook
Mouse and Keyboard are slow or stuttering
For the last few days my mouse has seemed to stutter - sometimes goes beyond where I move it and sometimes not far enough. The clicking somtimes recognizes a double-click, sometimes not. Also the keyboard is skipping letters as I type. It seems like something is running in the background somewhere, but the CPU usage is only between 4 to 10 percent. I did a system restore to see if that would fix it, but it did not. Help me, please!
  • Rybbyn May 29, 2008
    I ran the spyware program that I have installed on my computer. It didn't say it caught anything, but somehow something must have been fixed because it seems the computer is running okay now. Keyboard and mouse (internal, as this is a laptop) are back up to speed and all is normal. It probaby was something to do with spyware, I'm sure. Wouldn't have thought of it if there weren't several posts here suggesting it! Thanks soooo much! I can type at last!
  • Suresh babu
    Suresh babu May 11, 2010
    Is your keyboard and mouse are USB devices?
    If so, will your mouse and keyboard work under safe mode?
I have been having same problem for one month now. I have the new dell E6400 (pretty fast), but all of a certain, it started stuttering on almost everything particulary noticeable on anything audio including playing music with any music player and listening to streaming audio. I tried all tricks I found online but nothing worked. Finally, I went to setup (F12 key at startup) and changed the setting on hard drive configuration from ACHI to ATA. ACHI allows eSATA port usage, but I do not use eSATA anywhere anyway. Magically, this solved all the problems of stuttering. Windows even discovered the IDE channels (therefore using ultra DMA mode 5 under device settings, IDE channel). Now I can load as many heavy duty programs as I want and there is no stuttering. What is amazing is that this stuttering just happened out of the blue. Good luck, hope this helps someone.
Posted on Dec 27, 2008
  • 3 Answers
Take the battery out and run of the mains
Posted on Dec 16, 2008
    Sergeant:
  • 458 Answers
Everyone seems to be giving good advice. There is a couple of things that they are leaving out though. Turn the system restore off. System restore keeps everything in restore. Meaning......... If you have spyware or a virus, it will stay in your system. Run Spybot S&D (This program is free and is better than using msconfig as long as you go through the settings and change everything to the highest settings.) Then do the same with Adaware 2008 (sounds stupid to use 2 things for spyware, but one catches what the other one does not.). I have links on my website (tandnfamilyelectronics-online.com). These links go directly to the download so you will not get the run around. You would do good to try a program called Window Washer. This is a great program that completely cleans anything in your computer that you do not need. It will not clean out anything that you have to have. I have used this for years to clean out my customers computers and have cleaned as much as 3 gigs of trash out. If you contact me I will give you some tools that I have for free that will do a great job on your computer. I have them ready to download and I will give you the link. (dean@tandnfamilyelectronics-online.com)
Send me the complete specs of your system and I can help you more. I hope that this helps you. There is no reason the really buy a program for spyware when there are free things to use that work great. Free AVG is a great Antivirus and yes it is also free. It will check your e-mail coming and going. It will also let your friends now that the E-mail does not have a virus. It also has a spyware program that is free. This day and time with all of the spyware out on the net you can never have too many programs for spyware. I would not run all of them at the same time though. Make sure that you do not use your computer during any scan. Defrag is also something to do after you do everything else. Some stated that you should not reload your computer. If nothing seems to work then sometimes that is the only good way to get it repaired right. Most of the programs that come pre-installed on a store bought computer is useless and most are even trail software that causes problems when they expire. Let me know if this helps at all. Please rate me if it helps.
Posted on May 29, 2008
  • 1 more comment
  • T&N Family Electronics Dean and Sherrie Terrell
    I found a free link for Window Washer. Click the words below.
    Window Washer download.
    Glad to help. Spyware can do a lot of strange things. Run these programs often and also set them to the highest settings that you can. Use the tools within Spybot to stop things loading at startup. You do not need your printer,nero,and other programs to run when your computer starts. These programs will still run when you click on them. Start up programs just slow down your computer when they are running. If you are unsure, you can always go back and change the settings if something screw up.
    Glad that I could help. I am online most of every day. I will help you with any question that you have as soon as I can.
    You might want to try the spyware programs that I told you about. Spybot can be set up to run daily. It has a lot of settings and features. It is very good when you go through the settings and mark them all to the highest setting that it has. It can also stop things from coming on at startup. When it runs daily it will catch things, before you have trouble with them. Remember that all of us are here for YOU.
Please go to this link (below) and download Advanced Windows Care. Scan your computer and hopefully this will fix what ails ya.
http://www.iobit.com/advancedwindowscareper.html
Terry
Posted on May 28, 2008
Terry
I am Mike of mikescomputer@earthlink.net I have 35 years of experience in computer repair and own my own computer repair business. The following info is MY website. I am a search engine expert too, go to Yahoo, search for "free computer debugging", my website returns #1 in over 10 MILLION search returns and has for 4 years! This should tell you something!
This is a new Dell laptop from the stock number I see, a really nice one with wide screen HI RES, etc. A Cadillac! I believe this stock number is Windiws Vista but this works on XP too! I NOTICE ALL THE ROOKIES SUGGEST REFORMATTING THE HARD DRIVE. DON'T EVER DO THIS UNLESS IT IS ABSOLUTELY LAST RESORT WHICH YOU HAVEN'T REACHED YET.You will never get all programming back into the machine that it came with! DON'T REFORMAT UNTIL YOU CONSULT WITH AN EXPERT. A real EXPERT. Go to:
http://home .earthlink.net/~mikescomputer/
If you can't get there by way of the browser hit "RUN" type the following URL into the "RUN" box {http://home.earthlink.net/~mikescomputer/} and hit "ENTER". This bypasses the browser! Get to this site, it has MANY freebies, and try the "Spyware Detector. It's on the FREE ANTIVIRUS PAGE. You have SPYWARE! I guarantee it!!! The FIRST thing to be affected from Look2Me {I suspect this is the very one you have} and other nasty spywares is HOW THE COMPUTER SCROLLS AND HOW THE MOUSE FUNCTIONS. They will appear very sluggish. YOU HAVE SPYWARE. PERIOD!!! SPYWARE IS VERY DANGEROUS. UNLIKE VIRUSES, WHICH ARE EASILY REMOVED AND PREVENTED. I HAVE NEVER FOUND A VIRUS YET THAT YOU HAVE TO PAY MONEY TO REMOVE, BILL GATES WILL NOT ALLOW THIS. Spyware is a form of ADVERTISING and is a different story. For $22. and change you can fix your computer and keep IT RUNNING SMOOTHLY FOR A YEAR! If not... They give UNCONDITIONAL REFUND! THIS IS THE ONLY 3RD PARTY SOFTWARE YOU NEED TO PURCHASE TO PURGE YOUR MACHINE OF MALWARE. THIS SITE WILL GIVE YOU FREE ANTIVIRUS AND MANY OTHER FREEBIES TO KEEP YOUR COMPUTER IN TOP RUNNING CONDITION. PLEASE PLEASE PLEASE TRY MAX SPYWARE DETECTOR FROM THE ABOVE WEBSITE, IT IS CHEPER THERE THAN ANY OTHER WEBSITE AND BEST ON THE NET. I GIVE THE CONSUMER MY COMISSION!!! USE THE CODE IN THE WEBSITE ON THE SPYWARE DETECTOR ORDER FORM. You may call me. I DON'T want your money or your credit card!!!!! I do not want to sell you anything, but I can help you. FREE!! Mike. Good Day!! Ps. THE MICROSOFT REPAIR TRICK IS : GO TO THE "RUN" MENU, TYPE IN "closeall" and hit "ENTER" This closes all nonessential programs including whichever one is running spyware on your machine. Then, hit "{RUN", type exactly "msconfig" without the quotes and select the "STARTUP" tab at the top. Hit "DISABLE ALL" then "APPLY" then hit "OK". 252-287-7926
  • 23 Answers
If you pay close attention, you'll probably see the hard disk light spinning. Often there is either processes or program that is running that you might not notice. In an earlier suggestion, disabling startup-items is not a bad idea for inproved performance, but in troubleshooting I always ask ,,, When did this start?, Did you install or update anything? I the answer was yes to the second uninstall these and see your results, if no. then I would point to either hard disk failure (run a utility to check entire drive) or adware/spyware issues.
    Problem Solver:
  • 5 Answers
The best solution to this problem is to reintall the operating system that is after confirming that the mouse&keyboard is ok .to do this, lose out the keyboard dust it to see if theres any dust in it.if it still continue the best option is to reintall the operating system.
  • 55 Answers
Start/Run/msconfig Click on Startup/Disable All/Apply and restart your computer. If this situation persists, I suggest u format the computer. And if is okay, then slowly enable one by one of the Startup items by restarting the computer for every one you enabled.
  • 55 Answers
System restore restores both good and bad. So you could try restoring to an earlier date, if you haven't made major changes recently. What is your anti-virus? Norton is a waste of time and I would uninstall it. My preference is Nod32 free trial from http://www.eset.com/download/free_trial_download_eav.php. Run and anti spyware also, SpyBot S&D is good, but beware of imitators that will make the situation worse. When you have run these, done a disk cleanup and defragged then you can look at the hardware. Can you check that the keyboard cable is securely attached.
    Problem Solver:
  • 22 Answers
Do not format the HD or reinstall the OS! First let us know how the keyboard ad mouse connect to the computer. If the are wireless, try changing batteries or recharge (if applicable). If they are USB, shut off your computer, unplug and replace in different port. then turn on again.
You can also try typing MSConfig into the "Start Search" section of your start button and then select " diagnostic Startup." If this helps let us know and we can go from there.
2 Suggested Answers
n25an
  • 622 Answers
SOURCE: Slow/sluggish Keyboard and mouse
sounds like ram failing...
Posted on Dec 22, 2009
How to make a optical mouse work better?
Your mouse is an important part of your computer system, and when that mouse has problems it is important to get them resolved as quickly as possible.
There are a number of things that can cause a mouse pointer to behave erratically, and it is important to work through each of those possible causes one by one.
Change the batteries if you are using a wireless mouse.
The batteries in a wireless mouse will generally last a long time, especially if you use rechargeable batteries.
But once the battery power begins to decline, the batteries will lose power very rapidly.
If you are using a wireless mouse and the cursor begins to stutter and jump, chances are that changing the batteries will resolve the issue.
Move the wireless transmitter to another USB port.
Problems with the wireless transmitter can cause the mouse pointer to stutter and jump. Moving the transmitter to another port will often resolve this issue.
Right-click on the "My Computer" icon on your computer's desktop, and choose "Properties" from the menu.
Click on the "Hardware" tab, and click the "Device Manager" button.
Navigate to the mouse entry in the list of hardware devices, right-click and choose "Update Driver" from the menu.
Allow your operating system to search for and install the most recent driver for your model mouse.
Clean the mouse surface thoroughly if you are not using a mouse pad.
If you are using a mouse pad, shake any dust or dirt off of it to make sure the surface is perfectly smooth.
Any imperfections in the surface could cause the mouse pointer to behave erratically.
To clean the mouse surface, hold a clean cloth over the opening of a bottle of isopropyl alcohol and soak the cloth.
Then, go over the entire surface with the alcohol-soaked cloth and allow the surface to dry before attempting to use the mouse again.
Click on the "Start" button, and choose "Control Panel" from the menu.
Double-click the "Mouse" icon, and click the "Mouse Pointer" tab.
Adjust the speed of the mouse.
If the mouse speed is set too fast, it can cause the mouse pointer to stutter or hiccup.
It may take a few tries to get the speed just right, so just move the slider and test each new setting
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop
then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7
in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar
Hope this helps
Nov 04, 2012 | Computers & Internet
My mouse keeps stuttering, I really don't know why. I changed the batteries and installed the latest drivers available. It works on and off. The stuttering really makes it unusable. I'm not sure what I...
When the mouse stutters, check the adapter plugged into the computer. If the little light on the adapter (labeled #2 in the picture) is blinking then you may have accidentally pressed the sync button on the bottom of the adapter or the mouse.
To fix this problem, press the sync button on the bottom of the adapter.
Next, press the sync button on the bottom of the mouse.
Mar 01, 2011 | Microsoft Wireless Mobile Mouse 3000
RF wireless technology can easily be compromised. Anything can interfere with connection from an appliance running to the surrounding walls and of course electro-magnetic interference. My suggestion is to look for a keyboard/mouse that uses bluetooth wireless technology.
Slow Keyboard and mouse, DPC's problems
switch everything over to usb...mouse and keyboard... or by a ps2 to usb adapter and test it out... one usb to ps2 adapter can handle both keyboard and mouse... if that doesn't work its either a virus or memory...
Dec 22, 2009 | Acer Aspire 3050-1733 Notebook
My Microsoft Wireless Notebook Laser Mouse 7000 stutters
Replace the batteries. If this doesn't work, resync the mouse and the wireless adapter that is plugged into the computer.
Usually you can do this by holding down the button on the wireless adapter first and then the button on the mouse. This will also change the frequency in case something is interfering.
Dec 20, 2009 | Microsoft Wireless Laser Mouse 7000
When I move my mouse over favorites, it is slow
After a great deal of searching and toggling many different options, I found a solution!
I am using Windows XP.
The option may be in a different place if you have some other version of Windows.
In Control Panel, Folder Options, View tab, scroll to the bottom and uncheck “Show pop-up description for folders and desktop items”.
I am not certain, but it also seems to have improved the general performance in Windows Explorer as well.
Oct 26, 2009 | Microsoft Internet Explorer 8
Stuttering Graphics
check for the mouse pointer movement speed.... this can be located in control panel --> Mouse Options.... there check for the mouse wheel speed and decrease it ..this may help.... sometimes wireless devices doesnt have compatibilty will vista OS , this may also cause an issue..if any vista drivers exist for ur mouse install them and check ...hope this helps...
Aug 18, 2009 | Computers & Internet
Laptop Mousepad and Keyboard stuttering, slow
Whenever that happens to me, at least to the mouse pad I restart my laptop and it fixes it...
If not then perhaps it's a hardware or software problem, maybe you could reinstall XP over again, or you could, as a last resort crack it open and see what's goin' on inside or have someone check it out for you (I wouldn't go that far though).
Jan 30, 2009 | Dell Inspiron E1705 Notebook
This may be a battery power monitor issue. Try disabling the "Mircosoft ACPI- Compliant Control Method Battery" device. This is located in Control Panel-->System-->Hardware Tab-->Device Manager-->Batteries. Had similar problem with 2 Acer Aspire series laptops (diff models). 2 and 3 year old. Original batteries (both still hold charges for 1.5 hrs of normal usage). Running WinXP, one with SP2 and other had SP3. Both came in the last month with slow jerky TPAD function and nearly non responsive keyboard access. Checked the usual; virus, spyware, hijacking, driver conflict etc. Cloned drive and factory installed..still same problem with kb & mouse. However an external USB keyboard and mouse functioned normally (no lag). Noticed with Battery removed kb & mouse was normal. Finally found disabling ACPI control battery device resolved this issue while allowing laptop to run on either battery or AC.
Jan 30, 2009 | Acer Aspire 1640Z Notebook
Dell Inspiron E1705, Intel Core 2 Duo T5300 , 17" WSXGA+ LCD, 1GB DDR2 SDRAM, 256MB ATI V... PC Notebook Logo
876 people viewed this question
Alun Cox
