A/c question answered
You answered me about my a/c heating unit by GE, with no model number. Between the fan, a/c and heat, the heat was the only part that worked. You needed to know if it was central air or a window unit. It is actually through my wall. The only parts on it I can actually see are the two knobs, six buttons and the round filter. I don't know if this helps but thanks for trying.
  • 20 Answers
One last question ?when you go outside the house and you look at the unit does it have pipes runing to another outdorr machine
Posted on May 27, 2008
Fan moves slowly ,compressor still hot even with a portable fan blowing on condensor ,but temps are back to normal. What would cause the fan to blow slowly and there is no obsructions
Ralph78yanks,
Your condenser fan (fan motor by compressor) is a variable speed and controlled by a computer board and compressor speed. If the fan motor slows down and the compressor is running in high, the unit can over heat and cause temperature issues in refrigerator sections. GE has a program which can see actual fan RPMs of motor. As I research this incomplete model number (7 possible different models) I see they all use the same fan motor Part# WR60X10209, this is a DC motor. Make sure you fan has not melted also. The heat from the compressor can melt the should or blade when this motor fails. I hope this information helps you..
Jul 11, 2011 | GE Profile PSW26P Stainless Steel Side by...
Microwave does not heat
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms, as well as the answers to these questions:
- When you try to microwave are the inside light, internal cooling fan and turntable all working?
- Is there any unusual noise or is it louder or quieter than normal?
We have a sound clip here of what a microwave should sound like when the cooling fan and high voltage section are working.
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
These answers will help me figure out if it's a control-level issue or a problem in the high voltage section.
Nov 28, 2009 | GE Microwave Ovens
NO HEAT IN "OTC" GE MICROWAVE
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms ("no heat"), as well as the answers to these questions:
(A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.)
Nov 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My GE spacemaker oven will no longer heat the food. can I replace the heating thing?
Yes, GE Customer Service is here, and they can tell you what model would be a "drop-in" replacement for your model.
If you or someone you know would rather fix yours, which can often be done pretty easily, (on some models the magnetrons have 10 year warranties) please post a NEW FixYa inquiry that includes your full model number from the tag in or on the unit, and the answer to these questions:
- When you try to microwave, do the inside light, internal cooling fan, and the turntable all come on?
- Is it louder or quieter than usual?
- Is it making any odd noises?
(We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are working.)
Otherwise, if this takes care of you...
Oct 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
JVM1640BB 004 GE spacemaker Not heating
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
(A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.L
Oct 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker microwave oven does not heat. Can
Oct 08, 2009 | GE Microwave Ovens
Ge convection micro combination has a problem with convection fan . fan runs for about 5 seconds, rattles, then stops. heat element gets red hot but little heat inide oven. replace fan motor or maybe more?...
I would say the convection fan blade is loose on the shaft.
If this is the case, it would try to run, but no cooling would take place, so the heat from the heating element would get very high but it would not be distributed through the oven.
The thermistor would then detect the extra high heat and stop it, I assume.
You may be able to use super glue or JB Weld to fix the blade on the shaft, as long as they are clean and dry and it is allowed to set overnight.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Accessing these components for testing and possible replacement will require you to remove the oven from the wall and take off the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Jul 11, 2009 | GE Monogram ZE2160SF Convection /...
Ice build up out side hitting fan
pop out drain plug heat up pan with heat gun to melt ice
Nov 24, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Heating & Cooling Logo
62 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
