Question about Sony Grand WEGA KDP-57WS655 57" Rear Projection HDTV
Will not turn on consistently. standby light flashes 10 times. If left unplugged overnight will generally turn on when power plugged back in.
  • rhill107 Oct 03, 2010
    I don't have electronics ability or much spare time. Can you give me an estimate of repair cost? Thanks.
  • 10,515 Answers
This model is popular for 10 blinks. This is an internal failure. You need to check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
If you have electronics repair experience, could read schematics, would be able to use multimeter and soldering iron - i would be glad to provide you the link where you could purchase cost effective service manual for this model.I would also provide you few pointers to fix this problem.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 03, 2010
  • taran_2005
    taran_2005 Oct 03, 2010
    Thanks for your response!!
    Regarding repair cost, it would be tough to estimate as the cost depends on location, experience of the technician and many other factors. If you call someone from a small repair shop, the ballpark cost would be around $300 + parts.
    Hope i helped you.
Vizio vw37l hdtv20a standby light on but wont turn on
you either have a faulty power supply or faulty main board. Vizio power supplies on the older sets are pretty decent. It's usually the main boards that go. These older main boards tend to be pricey so it may be better to buy a new set.
Mar 27, 2013 | Vizio VW37L 37 in. LCD HDTV
Sony LCD turns off 34 flash turn on 30sec repeats ...
The self-diagnostic function of the projection television will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue, some of which you may be able to resolve without the need for service.
  • If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
  • If the STANDBY light flashes four times in sequence, the television may be overheating. To resolve this issue, ensure that the back of the television is well ventilated.
NOTE: If the television will not turn on immediately after being turned off, wait for the fan to finish its cycle, then attempt to turn it on again. This is part of the cooling process of some projection televisions and is normal operation.
If the flash sequence is not listed above, or the light continues to flash after troubleshooting the indicated issue, follow the steps below to perform a power reset on the television:
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
lno2()
Dec 14, 2007 | Sony Grand WEGA KF60XBR800 60" Rear...
My standby/timer light is flashing and will not turn on.
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jun 02, 2011 | Sony KV-27S66 27" TV
Standby time light on and keeps flashing
May 21, 2011 | Sony FD Trinitron KD-36XS955 36" TV
Ive just bought this tv and when i turn it on the stand by light is flashing but i cant turn the tv on please can you help?
This shouldn't happen. When the standby light is flashing there is a problem with the television and it needs servicing. It could be the main board, the power supply, or both. This is a costly repair when a television is not in warranty. Now there are times when a television has to be turned on from the power button located on the top or side of it when first being unboxed. At a time like that the remote control will not work to power on the television. I don't believe that is the problem you are experiencing.
The troubleshooting for this is to unplug the television overnight and when you plug it back in the next day wait for the standby light to start flashing. Hold down the power button on the television set itself. Wait and see if the standby light stops flashing and turns red (or a different color). Let go of the power button. Press it once more and release it once more. The television should come on.
Even if the above works you don't want to risk something really being wrong with the television and a costly repair being needed after the warranty expires.
May 14, 2011 | Televison & Video
Standby light flashes but tv will not turn on
Ur high voltage is dying.The block of plastic with a red wire with a cap hook to ur CRT(tv tube).The FBT,it call the Flyback transformer,that is dying.That must be replace.
Sep 22, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Top up tv+ digital tv stopped working.
i had same prob, tried unplugging three times
then unpluuged for 5mins
, plugged back in left it alone, ie didnt touch remote or front panel, until it settled down ~15mins, green light came on (doesn't normally)
and everthing seems ok now
May 03, 2009 | Televison & Video
The standby/timer is flashing 6 times on my Sony KP-53HS30 TV
no the 6 blinks indicates a missing voltage. If your talking about a sony lcd KD or KE model you probably have a bad thermal fuse. You must also clean or change the Lamp fan so it won't blow again.
Apr 16, 2009 | Sony KP-53HS30 53" Rear Projection...
Desktop shutdown. will not come back on. Green light flashing.
Clarify please:
can you hear the hard drive running ? see the cpu cooling fan spinning ? operate the cd/dvd drives, see nothing on screen though.... yellow standby light not the solid green light.
compdoctor2005@btinternet.com
Dec 30, 2008 | Compaq Computers & Internet
Sony Grand WEGA KDP-57WS655 57" Rear Projection HDTV Logo
42 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
