Question about HP Deskjet F4180 All-in-One InkJet Printer
MY hp deskjet f4180 printer is printing out blank pages i inserted a new black ink into the printer and then it printed the alignment sheet i then scanned it properly, however when i print it goes in and makes the printing noises but keeps coming out blank
SOURCE: HP Deskjet 6940 printer - printing but no ink transferred to page itself
I have the same issue, but with a HP DJ 3550, I´ve heard about the data execution protection (DEP) migth help when changing the options, but still have to try it
Posted on Jul 17, 2008
jaznet
  • 75 Answers
SOURCE: HP Deskjet F380 won't print
i think the inside printer have dirt or obstacles that blocken the cartridges while printing.
try to clean manually the printer by using powerful air blower,repeatedly.
Posted on Sep 14, 2008
bootz84
  • 197 Answers
SOURCE: I have a HP Deskjet F4180 AIO. It is printing
If you just replaced the ink cartridges, make sure you've removed the plastic tabs that cover where the ink shoots out. If they are old cartridges, make sure that the nozles haven't dried up. Remove the cartridges and dab a cloth (one you don't mind staining) where the ink shoots out, if all the colours show up, it's clear. If you notice very little colour, or none at all, try dampening the cloth and wiping down the cartridges to promote inkflow through the nozles. Hope this helps.
Posted on May 08, 2009
SOURCE: Will not print black , HP PSC 1610 All-in-One
Here was the solution. You MUST use HP brand black cartridge. Originally I purchased a #94 Office Max brand black cartridge. After it did not work I took it back and they gave me a second Office Max brand and that did not work either. So I took it back and they sold me an HP brand (I only needed to pay the difference in price so Office Max was good to work with). I installed the HP #94 black cartridge and everything now works.
Posted on May 11, 2009
  • 240 Answers
SOURCE: HP 2210 New Black Ink Cartridge print alignment page over & over.
unplug the printer while it is in ON state..it will reset all settings..^_^
Posted on May 16, 2009
My hp deskjet f4180 printeris acting like it is printing, but the pages are coming out blank. The cartriges are new, they worked for the first few pages, then it started printing lighter, and lighter...
Hello. It sounds like the cartridges are running empty, strange that new cartridges would run empty so quickly. Depending on the cartridge number the 21 and 22 are very low capacity. you do have the option of using a 57 colour also which has approx double the capacity, but unfortunately the black is only a 190 page cartridge (according to them, real world testing has shown much less)
If it has been refilled try this link below to get it flowing again. http://www.fixya.com/support/r3986425-unblock_print_heads
If the Cartridges are HP Brand jump on the phone to HP to obtain a replacement cartridge.
F.Y.I Most compatible cartridges (21 and 22) have a capacity of approx 20ml of ink, compared to HP that hold approx 6ml. I would recommended SkyWell Brand of compatibles as they have great colour and a large capactiy.
I hope this helps Regards GM
Apr 26, 2011 | HP Deskjet F4180 All-in-One InkJet Printer
How to change ink in HP Deskjet F480 printer???
  • Check the ink levels by opening the HP Solution Center. Click on "Settings." Click on "Toolbox." Click on "Services." Click on "Service this device." Click on "Estimated Ink Levels." A graphic will appear showing the estimated ink level in each cartridge.
  • 2 Verify that the unit is on. Open the print cartridge door allowing the print carriage to move to the far right side of the unit. Once the print carriage has stopped, lightly press down on a print cartridge to release it. Pull the print cartridge toward you out of its slot. To replace the tri-color print cartridge, remove the print cartridge from the slot on the left. To replace the black or photo print cartridge, remove the print cartridge from the slot on the right. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
  • 3 Remove the new print cartridge from its packaging. Remove the plastic tape by using the pull tab, being careful to not touch the copper-colored contacts or the ink nozzles under tape.
  • 4 Slide the new print cartridge forward into the empty slot. Gently push the upper part of the print cartridge until it clicks into place. The tri-color print cartridge fits into the left slot. The black or photo print cartridge fits into the right slot.
  • 5 Close the print cartridge door. If the print cartridge alignment sheet prints, load it on the left front corner of the scanner glass with the top of the page to the left. Verify that there is plain paper loaded in the input tray, and then press the "Scan" button to align the printer.
  • Read more: How to Replace an Ink Cartridge in an HP Deskjet F340 ' eHow.com http://www.ehow.com/how_2303716_replace-ink-cartridge-hp-deskjet.html#ixzz16MAooFTf
    Nov 26, 2010 | HP DeskJet F380 All-In-One Printer
    My printer is not printing out any black ink onto paper. Only the color is printing out onto paper. I put two brand new cartridges in for the black ink and color ink, and it says that the ink levels are...
    You need to take it a couple steps further after your test print. Sounds like your print heads need cleaning or your cartridge may need aligning. It’s best to do this each time you install a new cartridge. for more information….... http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
    Sep 03, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
    HP Deskjet F4180 Color changes and lines in photo printing
    HP always recommend that ink cartridge should be replace by original ink.
    As this kind of scenario will occur if the ink will just be replace by a refill ink.
    Sep 21, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
    New HP printer Deskjet F4180 will not print
    Hey
    Try to take the cartridges out and clean the cartridges and cartridge holder with damp clothe
    now shake the cartrdges and clean it agaian with damp cloth
    put the cartridges back in and see if it works
    Sep 18, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
    May 08, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
    Printer won't stop printing alignment sheet, following changing of ink cart.
    my printer only printed 1 page out of 3 so now it wont stop. it pulls the paper in and comes out blank. this will keep going unless i turn it off. how do i reset my printer?
    Aug 20, 2008 | Office Equipment & Supplies
    Alignment problem
    I want to start my office working with the HP F380 DeskJet....
    Apr 30, 2008 | HP DeskJet F380 All-In-One Printer
    HP Deskjet F4180 All-in-One InkJet Printer Logo
    228 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
