Question about Frigidaire Kitchen Ranges
I own a UF-16D freezer that is approximately 16 years old. Never had a problem. Recently I have noticed the food on the bottom shelves is not freezing and the outside of the freezer door is cold to the touch. Any ideas as to what is causing this?
icansurf
  • 72 Answers
SOURCE: The water filter keeps freezing and food in door and on shelves keeps freezing.
clean lint from coils in back. could also be low on refrigerant (freon)
Posted on Jul 11, 2007
aborcass
  • 2651 Answers
SOURCE: Bottom freezer door dripping water on kitchen floor
you can take a ook into the freezer sect its possible that the line has frozen, nad no longer is defrost water going into the drain but rather falling on to the floor of freezer and evnetually out the door
Posted on Jan 14, 2009
TheRepairGur
  • 27 Answers
SOURCE: Frididaire side by side refrigerator- water freezing in bottom
Frozen or Plugged Defrost Drain
On Side By Side Refrigerator
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models the pan is accessible without removing the back panel and others are not.
Once you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster like this one: Turkey Baster http://www.repairclinic.com/SSPartDetail.aspx?PartID=428708&PPStack=1
To squirt hot water into the drain hole to clear the drain.
When the drain is clear you should hear or see the water you are squirting into the hole enter the pan under or behind the refrigerator.
TheRepairGuru ---- www.repairclinic.com
Posted on Jan 27, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Posted on Feb 12, 2009
  • 236 Answers
SOURCE: Both freezer and fridge Not cold on top
sounds like the circulation fans are jammed/seized or faulty -try a full defrost and see what happens after that.
Posted on Apr 04, 2009
Door handle coming off
now you just need to buy another handle because the first one is not fixed well, it doen't cost a lot, but when you buy the handle you get free maintenance.
Mar 04, 2008 | GE GSS25JEMWW Side by Side
GE Profile Side by Side PCF25PGTAWW Ice maker started to leak inside several weeks ago. Ice column formed inside back of freezer and on shelves. Removed ice and turned off ice maker. Refer and freezer...
when you removed the back panel if you look on the right side you'll see a round coil next to the fan you have to clean that out at least once a year,if you get a shop vac you can vac off the coil and then set it to blow and blow the coil out to clean it,if your food is staying clod you don't have a problem,when the machine goes into defrost there's a heater in the freezer that melts the ice off of the coil,when it comes on the temp will get warmer for like a half hour or so until it comes out of defrost and starts to cool again.hope this helps
Oct 05, 2017 | GE Refrigerators
I have a 6-7 year old Magic chef top freezer, refrig which is collecting water each day at the inside bottom of the box, refrigerator section. I notice that a slight drip of water comes thru the middle...
The defrost drain is located just under the cooling coils in the back of the freezer. You will need to unload the food and remove the shelves from the freezer. Take the back panel off from inside the freezer and you will see a hole just below the coils. Flush it with hot water using a turkey baster or small hose. See the link below for more details.
Defrost Drain
Jul 21, 2010 | Magic Chef CTB1821AR Top Freezer...
Freezer will not keep foods frozen fridge will not keeep temp.
Sounds like a main control board problem keeping the freezer fan from working . If no air flow to the top of the freezer , the icemaker will stop working and the ice will begin to melt ( leaking from freezer ) . The coils will start to freeze up due to no air flow across them . If continued for a period of time , the cold air could return thru the return vent located in the bottom of the ref/freezer section and freeze the water tank in the refrig section , causing the no water thru dispensor .
Jul 11, 2009 | Hotpoint HSS25GFP Side by Side...
Sub zero bottom freezer access
that unit must be 20 plus years old. There wouldn't be any diferent shelves available for it.
Jan 31, 2009 | Sub-Zero 650 / O Bottom Freezer...
Not all shelves freezing Alarm on
If this is not a frost free unit. I say replace it. I don't believe in recharging a deep freeze. You can never really trust them again. The food inside is worth more than the freezer. If this is a frost free unit, See if the fan inside is working. This can also be a defrost system proplem such as a timer and well worth fixing.
Jun 23, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Mar 22, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezer Shelves are too small for freezer and keep falling when I put food on them...
I had the same problem with the freezer sheles being too small in my GE Profile side by side. The shelves would simply collapse down with any weight on them.
After measurng the gap, I determined that the shelves were approximately 7/16" too narrow.
The fix I did was simple, effective, and very cheap.
I bought a roll of clear flexible polyethylene tubing at Lowes for about $5.The tubing is 3/8" outer diameter, 1/4" inner diameter (see picture below).
I cut pieces to fit along the side rails of the shelf, and then sliced the tube pieces down their length with a utility knife. I wrapped the pieces around the outside rails on each side of the shelf. It took a little work, but I got the tube pieces attached.
In a few spots, I did a double wrap of tubing.
The shelves fit tightly now and can hold significant weight without collapsing. Plus, they don't look too bad.
I hope GE fixes this simple problem in the future.
2_29_2012_2_35_52_am.jpg2_29_2012_2_36_07_am.jpg2_29_2012_2_36_33_am.jpg2_29_2012_2_36_53_am.jpg
Jan 21, 2008 | GE Profile PSW26P Stainless Steel Side by...
Freezer is producing"snow" and freezer burning everything
AFTER A DEFROST,HAVE A GOOD LOOK AT THE DOOR RUBBER. IT MUST BE 100% SEALED FOR A FREEZER. (SHOULD ALSO HEAR A SLIGHT VACUME WHEN DOOR IS SHUT WHEN UP NTO TEMP).ALSO MAKE SURE MOTOR IS SWITCHING OFF AT +/- 20C (TEMP).IF ALLOWED TO RUN CONTINUOUSLY TEMP WILL PULL DOWN TO CREATE EXCESS FROST.
Jul 07, 2007 | Whirlpool ED2FHEXN Side by Side...
Kitchen Ranges Logo
147 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
