Question about Stoves 720EF Electric Double Oven
My stoves 720ef keeps cutting to automatic timer. Have tried turning off mains and restting worked for a while but keeps cutting out and automtaic cooking symbol keeps flashing please can you help
  • 250 Answers
SOURCE: stoves 720ef fan oven cutting out
I confirm that you should get an oven thermometer as I did as my 720 wasn't behaving itself. Lakeland do one that works well and is not to expensive. I found that the fan oven was working ok but the top oven was way out, i.e. setting 160 on the dial produced 140 in the oven. The thermostat sensors for both ovens are located at the rear of each oven at the top right. They should be clear of all congealed fat etc and should be bright and silver in colour. If they are dirty this may cause them not to work correctly. Lakeland again do an oven cleaner that you paint on with a brush. It may take more than one go but it cetainly removes all the rubbish and may well restore the thermostat to near normal operation. When cleaning the sensors be careful of the thin wire from them as if this is damaged you will have to have a complete new thermostat.
(The oven cleaner works on everything inside the oven including the stay clean lining).
As a final thought is the cooling fan running when the oven fan is on as this may cause the oven to overheat?
Best of luck.
Posted on Jan 05, 2009
  • 250 Answers
SOURCE: I need an instruction manual for 720EF
Supply me an email address and I will give it the access to my BT Digital Vault so that you can down load the copy I scanned in.
Posted on Feb 09, 2009
  • 250 Answers
SOURCE: stoves 720ef fan oven cuts out after a while, then
There are thermal cutouts for both ovens. When the fan oven cuts out, does the thermostat display and the oven lamps go out as well or do they stay on? Is the oven cooling fan working ok, i.e. does it run for about 10 mins after you turn all the controls off? Do you think the oven thermostat is working ok and not running too hot? If it is, Lakeland do an oven thermometer for about 5 pounds that you can check the thermostats with.
Posted on May 08, 2009
  • 250 Answers
SOURCE: My stoves 720ef oven keeps cutting out after 20
There are seperate thermal (overheat) cutout devices for both the top and bottom ovens. First check to see if the lower oven fan is running ok and is not restricted by grease or fat (there are 4 self tapping screws that hold the fan cover on) and the thermostat is switching off and on as it should. You should also check that the main background cooling fan is running and switches off a few mins after the ovens have turned off. If these check out ok, then it is possibly the lower oven thermal cutout.
Posted on Aug 05, 2010
SOURCE: I have a Fagor 5H 196X oven and whenever I set the
Please find here our reply from the customer service of Fagor America:
This problem could be confusion over how to properly program an automatic cooking function. First, you must program the cooking duration, then you must program the time of day you want the food to be ready. Sometimes customers think they need to program a “start time” and an “end time” versus a “duration” and an “end time”. Please, make sure you are doing both steps correctly. Also, you should be aware that this clock works on the 24-hour principle (military time). I know that sometimes this confuses people as well. If both of those are okay, then it probably has a defective clock. If that is the case, please feel free to call our customer service:
UNITED STATES OF AMERICA and WESTERN CANADA: Please contact ADCO Customer Care at 1.877.743.2467, or by email at: fagor@adcoservice.com
EASTERN CANADA: Ontario, Quebec. Please contact A.G.I Service Inc: Telephone: 450-963-1303 or by email at: nruel@agintl.qc.ca.
If you have any other questions do not hesitate to contact us at: infoappliances@fagoramerica.com
Best Regards,
Posted on Aug 23, 2010
Bypass a faulty timer unit on a stoves 720ef cooker. . . . My partner tried this today on my cooker and now there is no power to the cooker at all!! Is there a chance he's managed to do the wr
I would suggest the wrong wires were cut off and joined. If the ground wire touches the power wire a fuse or circuit breaker will blow.. Before you do anything more make sure the curcuit breaker is not blown. If it is reset it and turn the cooker back on. If the breaker blows again then it is wired wrong.
Dec 16, 2014 | Stoves 720EF Electric Double Oven
How do I bypass a faulty timer unit on a stoves 720ef cooker
Try taking the power wire that goes into the timer and the power wire that comes out of the timer and put them together not hooked to the timer and that should work. If that works you should solder them together and electrical tape them good.
Make sure the power is off when you do this so you don't cook yourself.
Dec 03, 2014 | Stoves 720EF Electric Double Oven
I have a stoves 720ef oven and cannot get rid of the auto
The handbook says:-
To cancel the automatic setting and return the oven to manual operation, press the cook time and ready time buttons simultaneously. These are the second and third buttons from the left. If you have done that and it is not working, try turning the complete oven off for awhile - say 30 mins and turning back on. If this still doesn't work then it may be that the timer/clock has gone faulty.
Nov 10, 2011 | Stoves 720EF Electric Double Oven
Stoves 720ef small 'A' appears left of display. how do i get rid of this and return to manual? without fiddling cannot turn oven on. I have no manual
If the 'A' appears, it means that the automatic setting has been enabled. To stop this and return to manual setting, press the COOK TIME and READY TIME buttons simultaneously.
The COOK TIME button is the second from the left and the READY TIME is the third from the left.
If the 'A' keep s reappearing by itself, then it could mean that the timer is going faulty. ESPARES should be able to supply one.
May 29, 2011 | Stoves 720EF Electric Double Oven
Clock keeps flashing i keep setting clock but after 5 minutes or so starts flashing again putting tape over ready time button to hold it down then reset clock seems to work till the tape comes loose Stove...
It looks like the clock is on its way out. I would try two things. First, turn the power off at the main switch, leave it off for a few mins and then turn it back on and see if it makes a difference. You may need to do this a couple of times. Secondly, with the power switched off, repeatedly press all the clock buttons one at a time a number of times - there may be a contact that needs cleaning by operation and then see what happens. if you do need a new clock/timer then ask espares for a quote.
Nov 14, 2010 | Stoves 720EF Electric Double Oven
My stoves 720ef oven keeps cutting out after 20 minutes and will not turn back on, the grill continues to work ok. I know the timer is set to manual so I guess it must be a thermal trip. As I do not have a...
Aug 04, 2010 | Stoves 720EF Electric Double Oven
Stoves 720EF - main fan not working
When you say the main fan, do you mean the background cooling fan or do you mean the circulating fan in the bottom oven?
Do you have the handbook for this oven as the wiring diagrams are included in it. If you haven't, you can take a copy from my BT Digital Vault - all I need is an email address to register you.
Looking at the diagram, the power for the cooling fan comes via the timer board. If, as you say, the fan doesn't work at all, the timer board could have gone faulty.
Nov 15, 2009 | Stoves 720EF Electric Double Oven
STOVES 720ef Oven Programme won't go off automatic
This is a solution - of sorts - but probably not the one that you were hoping for.
My Stoves 720EF oven developed the same fault.
I tried pressing the buttons in various combinations and I tried switching the power off and on, restting the timer and the clock, no joy.
I then tried getting hold of a copy of the manual and trying to fix it, no joy. Called up Stoves and booked a visit from a specialist service engineer, costing £75 +VAT for the call out, and was advised that the engineer would attempt to repair it but it might need a replacement circuit board, costing a further £110 plus VAT.
engineer arrived on the appointed day and was straight onto swapping out the circuit board - not much scope for "attempt to repair" - so that was about £190 plus VAT to fix it. job took about 25 mins and didnt seem to need anything beyond what any electrician (or electrically-expert DIYer) could do.
comes with a 12 month warranty - hopefully it will work without any issues !
If you have a regular electrician you might prefer to buy the board and get your electrician to do the job - or do it yourself, assuming that you are suitably skilled and qualified.
hope this helps
cheers
David
Nov 07, 2008 | Stoves 720EF Electric Double Oven
Stoves 720EF Electric Double Oven Logo
76 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
