Question about Asrock 775VM800 Motherboard
Upgrading ram Hello, Saw your answer about another ram upgrade problem and found interesting what you say about the confusing manual. that´s right! I´m checking it right now and I don´t seem to understand what can I do... I have slot 1 occupied with a 512mb pc3200 dimm and I want to upgrade the pc to 1gb or maybe 1512mb ram. You say it won´t work with slot1=512mb pc 3200 and slot2= 1gb pc3200? What would you advise? Thanks in advance, regards Rui Reis
  • reisrui May 27, 2008
    Thanks for your answer, Mike.
    So, It´s best to just buy a 1GB PC2700 333mhz and put it in slot2?
    Can I then have my actual 512mb pc3200 + this 1gb pc2700 running with no problems?
    Thanks again,
    Rui
  • reisrui May 29, 2008
    Hello again, map9966
    Just to check another thing, when you said "I can’t be 100% sure of the 1GB of PC3200 400MHz into slot 2, will run at all!".
    Even if doesn´t work, is it risky to try to insert this kind of dimm in slot2 just to try? I´m afraid to damage the board...
    Thanks again,
    Rui
    President:
  • 2,351 Answers
Hi reisrui, yes it is odd. (It's not the first time I have seen this.)
According to you're manual on page 6, under Specifications. The manual say's you can run up to a Max speed of PC3200 400MHz, 1GB in slot one. In slot 2 you can run a Max of 1GB of PC2700 333MHz in slot 2. Every motherboard I have come across that can run two different speeds of memory. The system will reduce the Max speed to the lower MHz memory speed. If you currently are using 512MB PC3200 400MHz in slot 1 & add 1GB of PC3200 400MHz into slot 2 for a total of 1.5GB of memory. The motherboard will ruduce the total memory over all speed to PC2700 333MHz. Motherboards alway run at the lower memory speed if two different speeds are presant.
I can’t be 100% sure of the 1GB of PC3200 400MHz into slot 2, will run at all! Or if it will be reduce down to 333MHz. I am sure you can run 2GB of PC2700 333MHz, 1GB of memory per slot in you're board for a total of 2GB.
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
Posted on May 27, 2008
  • Mike Peluso
    Mike Peluso May 27, 2008
    You shouldn't have a problem with that reisrui. Total memory 1.512MB running at 333Mhz.
    Mike
  • Mike Peluso
    Mike Peluso May 30, 2008
    Hi reisrui, no sir you will not hurt the board running two different speeds. As I mentioned the faster 400MHz will be reduced to run at 333MHz. (As per manual spec's).
    The voltage for both DIMM's is the same. If you recently bought 1GB of 400MHz memory, you should try returning it for the 333MHz memory. You might save a few bucks!
    Mike
HP Pavilion dv9000us (RP246UA#ABA) Maximum Ram?
ask the top makers of memory that, kingstone
the limit is clearly in the manual
RTM
http://www.hp.com/ctg/Manual/c01311536.pdf
page 10 pdf.
for better answer ask HP directly? yet? we are not HP.
https://h30434.www3.hp.com/
for RAM to work (only right Ram spec, works)
AND the BIOS must like it too. if not fails.
all upgrades of any type can cause issues.
so we do not upgrade or work the issues, 1 by 1.
its your call what you want to spend or time wasted, on upgrades.
upgrade from what, XP , vista? unsaid.
using what media, HP , there is non now for 11 year old HP.
so my guess using MS disks, from what source?
endless bad sources exist, a retail boxed set w7 from MS, ? goodl but
MS does not sell W7 direct now, that means finding NOS
new old stock off a shelf , for $120 retail .
issues with upgrades are (besides just RAM)
are vast.
chips that fail to have working driver for W7 are vast.
LAN
WIFI
sound
to name 3. (even video GPU if unlucky) non ATI non Nvidia.
now RAM start with #1 in the business. ask them.
https://www.kingston.com/us
Jan 06, 2018 | HP Pavilion dv9220us Notebook
I have a Dell Dimension 2400. I want to upgrade from 512mb of memory to 1GB. The manual says I have two memory connectors. Do I get the 1GB, or two 512mb to upgrade? Thank you for your response.
Hello
Yes, you can upgrade your system upto 2GB RAM, buy another 512MB RAM DDR 333Mhz and install it to empty slot of RAM, it will upgrade the RAM to 1 GB.
Hope it will help, if so do rate the solution
Good Luck
Dec 15, 2010 | Dell Dimension 2400 PC Desktop
I am interested in upgrading the CPU and Ram on my ASUS P4C800-E motherboard . What do you suggest?
Go to crucial.com
They are the best I've found. The sight an scan your system or, you can enter the info manually.
Good Luck!
Oct 18, 2010 | ASUS P4C800-E Deluxe Motherboard
I purchased my computer in 2001 with an intel D845GLLY motherboard. the ram was 256 mb. When I upgraded the systemthey said the max. Ram is only 512MB & so we upgrade ram to 512MB. I am surprised to...
I want to answer your question but I would need so many other questions answered. Topping of my list of necessary things to understand about your situation would be to understand why you would want to spend any time or money on this system? Are you going to actually use it after the ram upgrade? If so your money would go a lot further getting a used 2010 computer which would still be obsolete but may come with the 2gb ram right right from the factory. Maybe you should hit your local Craigslist and grab a $20 computer or take one a friend is sending to be recycled?
Dec 11, 2017 | Intel Desktop Board D845GLLY Motherboard
DDR or DDR2
DDR 266 is DDR, not DDR 2 . The 266 is the frequency value in Mhz.
Try having the memory refunded or resell it on Ebay, so that you do not lose your money.
Here is supported memory, many older motherboards do not accept modules of over 512Mb each, ask to the seller:
PC2100 Memory DDR266 DDR-266 184-Pin Upgrade (266MHz) Memory Upgrades
Aug 22, 2009 | Computers & Internet
Ddr or ddr2??
your RAM memory is not DDR2 It is DDR1 so if you want to upgrade you should buy DDR1 RAM .
I want to upgrade Ram
Hello there.
Upgrading your computer can be a complicated task, as there are lots of different types of memory available. Luckily there are means to make it much easier.
What i would suggest is clicking here and running the memory scan, it will tell you what memory you have exactly already and let you know which new memory is compatible and best suited for this system.
I have purchased and used crucial memory for a lot time, it has free delivery and lifetime warranty. If you do not want to buy it online, print out the page it shows you and take that into your local store, they will be able to choose similar memory.
Hope this helps.
Jun 29, 2008 | Computers & Internet
yes there are different types of ram available but since u have a ddr 1 type of ram ddr2 wont match in ur maotherboard.and also do try to get the same type of ram available presently so u dont have problem with the clock speed.
May 12, 2008 | ASUS P5S800-VM Motherboard
RAM Support
Please post the model number of you're Gigabyte board. This is key in order to answer you're question. The model number can be found on the board, if not written in bold white lettering on the board it will be found on one of the PCI (white) slots.
Apr 16, 2008 | AMD Sempron 2500 CPU (Box) and Motherboard...
IBM NetVista A40 Memory Upgrade
It would be advisable to go to the IBM website and then to their support link, find the manual for your system and see what it says about memory upgrade of your system BPCS
Dec 28, 2007 | IBM NetVista A40 PC Desktop
Asrock 775VM800 Motherboard Logo
156 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
