Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
Posted on Oct 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I HAVE A2150 POULAN CHAINSAW THAT THE HOSES ON THE CARB HAVE BROKEN OFF FROM THE PRIMER BULB I SEE WHERE THE SMALL ONE GOES BUT CANNOT FIGURE OUT WHERE THE OTHER ONE HOOKS UP I ONLY SEE ONE SPOT FOR A HOSE TO HOOK UP NOT TWO
Anonymous
Level 2:
New Friend:
  • Expert 95 Answers
  • Posted on Mar 15, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
95
Questions
0
Helped
23070
Points
173
Your primer bulb must have 2 lines coming off.One goes to the tank and one to the carb.If it doesen;t it must have broken off.if so it needs to be replaced the bulb will say tank and carb on the back of it.In very small letters.
How reassemble fuel line Poulan chainsaw P4018WT
OK, you should have three hoses, the main fuel delivery hose with the filter in the tank on it this hose goes to the carb connection on the right hand side of the carb body, the hose from the left hand side of the carb body goes to the fuel purge bulb with the short connection ( suction side ), the longer connection on the fuel purge ( pressure side ) goes back to the tank, so to recap the bulb pulls fuel from the carb and dumps back to the tank, the common miss conception is that the bulb is a primer and pushes fuel into the carb.
How to rout fuel lines to primer bulb on poulan 14" chainsaw
Short line on primer bulb goes to the left side of the carb. The long side on the primer bulb goes to in the fuel tank as the return line.
Poulan Woodshark 1950 14" Chainsaw Family: WPWES
Checked all the parts lists, they seem to use the same primer through all types no.s part no. 530047213.
7helpful
Walbro WT891 carb on a Craftsman chainsaw. Carb is brand new, all fuel lines and fule filter replaced. I prime the carb with the little plunger, chainsaw starts up and runs out of fuel within 30 seconds....
Who connected these hoses? the normal routing for a machine with a primer is like this, the fuel hose from the tank with the filter on the end goes to the carb fuel inlet nozzel ( not to the primer ) nearest to the pump cover ( cover on carb held with one screw ) the pipe from the metering side of the carb connects to the shorter nozzel on the primer bulb ( suction side ), the longer nozzel on the primer ( pressure side ) connects to the pipe going back to the tank, just remember the primer pulls fuel from the carb,into the bulb, and pushes it back into the tank, it is not actually a primer it is a purge. because it is connected this way it is impossible to flood the engine no matter how many times the bulb is pressed.
Let me know if it starts and runs.
2answers
Carburetor overflowing
Gas line from primer bulb to carb may be cracked or broken. Check gas lines for damage. If not that then there maybe an overflow problem in side the carb caused by the float shut off not seating correct or worn "o" ring etc.
3helpful
I have a chainsaw carb problem
clean out the two gas hoses with a pipecleaner then check replace the in-tank fuel filter if the carb still does not recieve gas your fuel float in the carbretor is not rising to let in the gas this will require disassembly of the WT324 carbretor
3helpful
Poulan 2150 fuel line routing wt324 carb
the large hose from the tank goes to the suction side of the primer bulb. The large line from the out put side of the bulb goes to the bottom inlet of the carb.
the small line goes from the top outlet tube on the carb back into the tank near the primer bulb.
6helpful
Routing of fuel lines from tank to primer bulb to carb
Line with filter goes to carb inlet,
Line from carb goes to inlet side of bulb.
Line from bulb goes to tank
11helpful
2answers
Walbro wt hose routing on poulan saw
Carb has 2 nipples. top nipple gets line with filter on it from tank, bottom nipple receives line from bulb other side of bulb returns to tank
Top Poulan Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Poulan Garden Expert? Answer questions, earn points and help others
