Question about Linksys Computers & Internet
During my linksys install, the software validates my connection and fails everytime. I do not have an adapter on the computer I am installing the software on. This PC has direct cable connection to internet. I have another PC located in the house which has an adapter. I need to setup the linksys router and bypass the connection to an adapter test.
  • 4,349 Answers
You need to have the router connected directly to the computer to do this setup. If you are directly connected to the internet you cannot communicate with the router and most everything will fail. Remember to set wireless security on the router, give a ssytem name and consider setting channels to 11 or so to not compete with wireless home phones.
Posted on Oct 03, 2010
I don't have my user name and password for my wireless network and need it to connect a wireless printer
If you have the CD that comes with the adapter then you can try uninstall Linksys software and install only the drivers of the adapter.
Remove the Linksys Adapter and un-install the Linksys Software from Programs menu. To re-install the Drivers insert the Linksys Setup CD into your CD-ROM drive. When the Welcome screen appears click Exit. Connect your USB adapter to the computer. When the Found new Hardware Wizard window appears, click Install the software automatically (Recommended) then click Next. Click Finish when the installation is complete.Try to connect to the wireless network again. See if that works. You can also download the latest drivers from Linksys website on any other computer. Save it on a Flash drive and transfer the drivers on your computer.
Oct 10, 2011 | Linksys 2.4 GHz 802.11b Wireless - B...
During my linksys install, the software validates my connection and fails everytime. I do not have an adapter on the computer I am installing the software on. This PC has direct cable connection to...
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Oct 03, 2010 | Linksys WRT160N Wireless Router
Everytime I try to connect using the WUSB54GSC it
You need to Update the Drivers for your Wireless Adapter...Download the Drivers from here
After downloading the drivers you need to unzip the file...After you unzip the file you should un-install the adapter drivers/software from Programs menu...Leave the adapter connected to the PC and reboot your computer...Once the computer is rebooted you should see a message "Found new Hardware"...Select the option Install it from a specific location and click Next, then select Include this location in Search and browse to the place where you have unzipped all the files and select the Driver folder and click O.k...Then click Next and it should install the adapter drivers...
NOTE : This installation doesn't install the software(Linksys Monitor)...
Once the Adapter is installed, Click on the Start button >>> Control Panel >>> Network Connections- Right click on the "Wireless Network Connection" icon and select "View Available Wireless Networks"- If you see your wireless network in the list, highlight it by 'single' clicking on it- Now click on the 'Connect' button below- If your wireless network is secured, it would ask you to provide the network key- Provide the wireless network key and confirm it again in the confirmation box and click "Connect"...It should connect to your Network and Internet...
Jun 16, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
WPC54G wont install power light is on
The problem is that the PCI slot/socket where the wireless adapter is snapped/connected is not not compatible with the adapter. I suppose that the adapter is more more faster than than socket so it can hardly function as it should. I recommend that you return the adapter and get a slower version of the adapter. Make sure that the drivers are properly installed by removing/uninstalling any previous software from the system.
Apr 28, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
Installed wireless adapter to windows 2000 computer it still says offline
After installing the wireless adapter, did you check if the software that manages the Linksys adapter picks up any signal or network that you can connect to?
Apr 09, 2009 | Linksys Wireless-G WMP54G 802.11g/b
Problem with installaion of WUSB54G Adaper. computer keeps reboot
Normally this means that its either an IRQ or basically conflicting with another device. or there is something wrong with your USB ports. Can you try antoher port on the computer?
Feb 06, 2009 | Linksys Wireless-G WUSB54G 802.11g/b
I need to know how to install my Linksys Wireless-G Notebook Adapter v4
On the Linksys adapters you have to install the drivers first, then install the adapter.
First, un-install the drivers and power off the computer. Remove the adapter . then boot the computer . Reinstall the drivers and power off, re-install the adapter.when the computer boots up it will find the adapter.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Sep 20, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
"WPC54G is not installed"
Those install programs that Linksys uses are terrible. This happens all the time.
You probably can't use the linksys program to install the software on a Windows 2000 machine you should be able to install just the driver you need. I have never used wireless networking on a Win 2000 computer before. Win XP has sotware already built into the operating systems to deal with wireless networking.
Uninstall all Linksys wireless networking software. Restart you computer with the wirless network card install and let Windows search for the correct drivers on the CD.
Jun 22, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Installed WMP54GS and am getting the following error from Linksys Wireless Network Monitor Access violation at address 0040744D in module WMP54GSv1_1.exe'. Read of address 00000368
Possibly you have installed the WLAN monitor also that is why it is creating the error...try these settings... Reboot your computer in SafeModeUninstall the software for the Adapter from start >> All programs/Remove the Drivers from Device Manager...Turn your computer Off and connect the adapter in a different PCI Slot...Reboot your computer in Normal Mode...
>> Insert the Setup CD in the cd drive>> Click on Exit when the
Linksys welcome screen appears>>Click on start. Unplug & replug adapter ...>> There should be a "" Found New Hardware Wizard ""
that pops up on your screen>> Click on “Install software
automatically “, and then click on next. Once the installation is
complete>> Right click on the wireless network connection icon in the
system tray besides the clock >>Click on view wireless networks and
then connect to your network name...
May 01, 2008 | Computers & Internet
Computers & Internet Logo
43 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
