Question about Toshiba Satellite A215-S7444 Notebook
System recovery disk will not load vista on my Toshiba Satellite A215. I get following message the instruction @0x77d62613 referenced memory @0x00d2188a. DMI.EXE error: 03-EEEE-0000
  • 4,336 Answers
Ohhh not good. and you may not have needed a reload. Try removing and replacing the RAM, if issue remains, try replacing RAM with "known good" ram. Ram does fail. If still no go, time for a bench diagnostic by a technician.
Posted on Oct 03, 2010
Error : 10-FC12-0570 when i try to reinstall with the cds
Error 10-FC12-0570 on Toshiba satellite This error message means that the recovery utility was not able to read the data from the disc correctly, or wasn't able to write it to the hard drive.
The problem could be with the disc, the CD/DVD drive or the hard drive.
Solution:
Try copying the second disc using another system. If it's impossible: order for a new disc. If you can copy it, try using the copy to do the restore.
Try using a third party disk checker to verify the problem, is or is not, with the hard drive.
The best way would be to load the Windonws Vista discs, format the pc and reinstall.
(Vista Recovery Boot Cd is available free by Microsoft). Download it burn the Image .iso and run that disc. That disc will not restore the OS: run diagnostics on the HDD; once disk check is completed and repaired, proceed with the Recovery disks that you have.
Nov 22, 2010 | Toshiba Satellite A215-S7422 Notebook
How to recover a toshiba a215-s5822 without a cd recovery disk
check here hopefully you can find a copy of the recovery disk http://www.user-guides.co.uk/Toshiba/ToshibaCDDownloads.asp?keywords=Toshiba%20Download%20Manual%20Drivers%20CD%20ISO%20PDF
Aug 27, 2010 | Toshiba Satellite A215-S5822 Laptop
Recovery Disc will not load OS on HD
laptop panasonic toughbook bios password pro
Apr 07, 2010 | Toshiba Satellite Pro L300 Notebook
I´ve a toshiba Satellite a215. How can I get the recovery disks?
As far as many of us know, you has to buy the recovery cd, but, instead of going to all the trouble, since you might has to either call or contact them via e-mil.
Since you already clean the system, why not go to the site and download all the drivers for your specific system, is very simple, and you get to load just the programs you need.
Drivers are a must, here is the direct link, choose download then choose your system > system model>"GO"
the next page would be all of your drivers, you can use your other system or a friend, put then on a flash drive or burn into cd.
Before you do any driver install, you should make sure you are connected to the internet, and do the windows update, as there should be new drivers for your system.
You should also do an "intel INF" update if not provided at the toshiba site, use google and downloaded it, make sure it applies to your system.
After you done the inf update and windows update, now you install all of the drivers and utilities that are available to you at the site.
sorry can't be of more help, below is the link to the site
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
Feb 06, 2010 | Toshiba Equium 100 PC Desktop
I have a toshiba 305 and get the error message the instructions at 0x760f6770 referenced memory at 0x760f6770. the required data was not placed into memory because of an i/o error status 0f 0xc000000e.
It is memory related issue.
First check in back side of laptop and refix RAM memory .
Also you have remove bugs in harddisk for that boot your laptop with recovery disk or bootable winxp disk then enter in recovery console mode then type in prompt "chkdsk /r" then press "y' then it fix error on harddisk.
For refix RAM you have open 1 small plate in back side of laptop it is for RAM module.
Aug 18, 2009 | Toshiba Satellite L305D-S5904 Laptop
I am coming up with error 10-fc12-0570 on the toshiba satellite a215-s7422 i used the both recovery disk and this was the error code
The error message is telling you that the recovery utility was not able to read the data from the disc correctly, or wasn't able to write it to the hard drive. The problem could be with the disc, the CD/DVD drive or the hard drive.
but usually error 10-FC12-0570 is pertaining to a bad HDD or memory
First, try copying the second disc using another system. If you can't copy it, order replacements from Toshiba Customer Assistance: 1-800-457-7777. If you can copy it, try using the copy to do the restore.
You can try using a third party disk checker to verify the problem is or is not with the hard drive. But since the system is under warranty, you're going to have to arrange to have it repaired anyhow, so it may not be worth the effort to verify whether it's the hard drive or CD/DVD drive. It's probably not the CD/DVD drive since you got all the way through the first disc. Contact a Premier (not regular) ASP for service from here: http://pcrepair.toshiba.com
The best way would be to load the Win Vista discs n format the pc...and reinstall...iam telling this because u have a tried the recovery disk as well....
I know most users will not have the Vista CD with you but the Vista Recovery Boot Cd is available free by Microsoft just google...
Download it burn the Image .iso and run that disc. Since that disc will not restore the OS all it does it lets u run diagnostics on ur HDD and allows u to install the OS. Once disk check is completed and repaired, proceed with the Recovery disks that you have.
thank you
have a nice day
Jul 08, 2009 | Toshiba Satellite A215-S7422 Notebook
Looking for toshiba satellite A215-S7422 disk driver
You should be able to download individual drivers by going to http://support.toshiba.com, but if you are looking for a copy of the original disk I would suggest trying ebay or the following website.
http://www.recovery-cds.com/
Mar 20, 2009 | Toshiba Satellite A215-S7422 Notebook
Bluescreen
You can do the sytem recovery by loading the first disk then turn your NB off. Please hold down F12 after power on then select CD/DVD drive then Windows will be loading files. Select the first options for each prompt. You will be asked for the second disk later. Plug in ac adapter since it will take around an hour. Hope this helps.
Oct 19, 2008 | Toshiba Satellite A215-S7422 Notebook
Toshiba Satellite A215-S7444 Notebook Logo
425 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
