Motorola RAZR V3 Cellular Phone
Problem for Motorola RAZR V3
Voice record memory full, reformatting my v3
By jaypee on May 27, 2008
hi, i was wondering how to reformat my motov3, bcoz whatever i press, it displays "voice record memory full". The problem exist when i accidentally dropped it. I can still receive messages and calls... but could only answer calls...
can you please help me... please please please... i love this phone for it was given to me as my birthday present so im not gonna buy a new one over my v3.
Comments:
May 28, 2008
- That is the problem... bcoz i cant get to the menu... coz everytime i press a key... "voice record memory full" appears... meaning i cant do anything to it just open and shut off (when you press the red key for some seconds)
May 29, 2008
- yeap i already tried... i think there was a reset switch at the back... but cant seem to see it...is there?
Same Problem
Mar 11, 2009
-   Out of nowhere, my razr shifted to "voice record" mode (which I had never used) and kept recording until it reached "voice record memory full". Now nothing works, and that message appears whenever the phone is turned on. I have tried removing the battery; no effect. Help. -   zorro1031
Nov 24, 2008
-   same here.
-   Guest
Oct 17, 2008
-   Same problem...power on/off works, but the rest of the keypad does not work. only time it operates is after you hit the hang up button and another key, then it says voice record memory full. any answers yet?-   aadyajeet
Sep 09, 2008
-   Same problem...power on/off works, but the rest of the keypad does not work. only time it operates is after you hit the hang up button and another key, then it says voice record memory full. any answers yet?-   sm97
Jul 23, 2008
-   YES - having the same problem. Cannot use any buttons except on/off and can only receive calls because none of the buttons work to make calls. -   Guest
Best Solution
posted on Sep 12, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
thank you brain your solution really worked for me.. the only diffirence i had was my vioce records was in organizer
Solution #2
posted on Sep 07, 2008
Somewhat Helpful)
PinkFlamingo
Rank: Apprentice
Rating: 74%, 3 votes
I'm not a technician, but I had the same problem. After reading some people got the phone wet, I remembered I'd been in a heavy rain two nights ago. I had the keyboard locked with "voice record memory full" (after it filled up). My wife was baking a pie and I warmed the phone up on the top of the stove where the oven exhausts holding the voice record button on the right side of the phone at the top. In a few minutes I shut off the phone (the only thing that worked) and turned it on again and the problem went away. I just did this so it may not be permanent.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Jun 30, 2008
Somewhat Helpful)
kcbpinky05
Rank: Apprentice
Rating: 70%, 1 votes
Yes, but how do you do that, when none of your buttons are working in order to delete the voice recordings. Basically all I can do is turn the phone off and on. (yes, I've taken the battery out, waited a minute, put it back in, I've even tried taking the sims out.) None of it works, my buttons won't work, it just says Voice Record Memory Full. Now I'm trying to hook it up to my computer to hopefully delete some files so it will work, but I can't pull up a window or figure out how to get my computer to aknowledge it. Please help.
Was this helpful?
Yes
No
Solution #4
posted on May 27, 2008
Somewhat Helpful)
bbtoast
Rank: Guru
Rating: 91%, 271 votes
Hi
I hope I can help you!
Please try this:
Push the center button near the 4 arrows, this should bring up your menu, then arrow down to 7) TOOLS.
Select TOOLS, then arrow over to 3) VOICE RECORDS then select.
Push OPTIONS, then arrow down to Delete all. When prompted, to delete all, select YES.
You are done!
Please let me know how it goes!
Brian
Comments:
May 29, 2008
- Have you tried to remove the battery, then wait for 1 minute at least, then put the battery back in, then try above procedure.
Let me know how it goes.
Was this helpful?
Yes
No
Solution #5
posted on May 03, 2009
Not Rated)
jubly
Rank: Master
Rating: 75%, 9 votes
Try the link . . . http://www.Motorola.com/Razav3
For find best solution.
9
Was this helpful?
Yes
No
Solution #6
posted on May 02, 2009
Not Rated)
eiarp
Rank: Master
Rating: 86%, 14 votes
Hi Friends,
Having problem with Motorola RAZR V3? Main problem of Motorola RAZR V3 is hardware problem. Such as won't charge, black screen etcFor solution of these hardware problem just click here.
For any other problem of Motorola RAZR V3 like software problem or other just click here.
Was this helpful?
Yes
No
Solution #7
posted on Oct 12, 2008
Not Rated)
dikoemy
Rank: Apprentice
Rating: 100%, 1 votes
ok this really works! listen up.... first remove everything. the bat..and the sim card. then get a replacement phone (your old one) and use your sim there. let it sit for a week or so 2 weeks is even better.
now put back the sim and presto! you have a working phone!...again!..lol remember it will only work for at least a week then it will freeze again. so best thing is after it works go to menu >tools and select voice record and delete everything. hope that works. i have not tried this koz i bought a new iphone..lol
but it was good for a week or so. enough to just trasfer my pics to my album.
Was this helpful?
Yes
No
Solution #8
Not Rated)
sm97
Rank: Apprentice
Rating: 0%, 0 votes
I took mine to the Cingular store and he said they could not even hard reset it because in order to do that you need to get to the menu. Sooooooo, I bought a go phone from walmart for $14 and dropped the sim card in...everything works fine in the new phone (i save my phone numbers to the sim vs the phone).
FYI - even a new sim card in the razr won't work as the phone is completely locked up. Good luck with it...this was a pain.
Was this helpful?
Yes
No
Popular Solutions for Motorola RAZR V3 Cellular
Questions and Unsolved Problems for Motorola RAZR V3 Cellular
Do you recommend Motorola RAZR V3?
Answer
Answer
unable to send picture in texts can receive pictures in texts,what can I do to correct this
Answer
i plug the charger, it off itself and show insert sim
Answer
sync will not let me down load my contacts to pc for motorola razr v3. help
Answer
I can't get the keyboard back light to turn off when the phone is closed. Battery life isn't very... (More)
10 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jul 22, 2008
HELP!! When i turn the phone on when i press any buttons it just says voice record memory full i have downloaded the photos from the phone and the videos but to no avail!! I cant give up .... anyone had any luck ??
Comment by jwf16, posted on Jul 17, 2008
same exact problem. only the power on and off key will work. I also receive the voice record memory full error.
Comment by purpleclam, posted on Jul 03, 2008
Hi, I have teh same problem. It happened after my baby used the phone as a teether. (Oops.) Function came back after a day, but then a week later the voice record problem returned out of the blue. Have not found a solution!
Comment by kcbpinky05, posted on Jun 30, 2008
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Cellular Phone Experts
Top Cell Phone Repairmen
CPR
(800) 818-8800
We offer hight quality OEM such as travel charges,...
CPR
(918) 955-1100
The Cellular Phone Repair Center opened in March...
cellularphonerepaircenter
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
