Question about Saeco Royal Digital Plus Coffee Maker/Espresso Machine
When I press the Large coffee button it grinds the beans and then starts to flow the water through, then when a small amount of coffee is in the cup it stops. The Medium and Small coffee buttons work well just as normal. There are a lot of people use this machine is there anything I can check on the programimg side that may have been tampered with??
  • 1,089 Answers
Just needs to be reprogramed. Try reprogramming the machine. Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button.
If that doesn't fix it, then you might need a new flow meter.
Posted on Oct 03, 2010
Why is my coffee weak?
If it is a drip maker, only gravity drives the hot water thru the coffee grinds. If the coffee is ground too fine, it immediately packs up and doesn't let water flow thru it and the water flows around the coffee instead of thru it.
Try using a coarser grind, and if not you can use a lot smaller amount of coffee and water. A smaller amount of coffee is easier to diffuse thru than a large amount.
Another thing is to slow down the water speed entering the coffee basket. I found the best way to do that is to use water just above freezing and place that extra cold water in the reservoir. The cold water takes extra time to be heated up by the coffee maker so less water is released over the coffee grinds per minute.
If your coffee maker overflows a lot, that is a good indicator that the grind is too fine and/or your coffee filters are too flimsy and are plugging up the channels in your coffee basket and the coffee can't enter the flask, so it overflows.
But the easiest way to check out your coffee maker is to use extra cold water and just run half batches (5 cup) of coffee instead of 10 cup
Feb 25, 2015 | Coffee Makers & Espresso Machines
How many tablespoons of ground coffee are needed per cup of water in the Smart Brew coffee maker?
For ground coffee, use 1-1/2 (one and one-half) tablespoons of beans per 6 ounces of water.
For whole bean coffee, use two tablespoons of beans per 6 ounces of water.
Coffee strength is a very personal preference, so use these numbers as a guideline for middle-of-the-road coffee, and adjust to make the coffee that you like to drink.
Sep 30, 2010 | Black & Decker DLX900 12-Cup Coffee Maker
Is my "brew group" broken.
Remove the brew unit, under the white plastic valve you will notice a small chamber that might be filled with coffee grounds and water. Clean chamber.
Dec 01, 2009 | Saeco Vienna De Luxe Espresso Machine
My saeco machine is not functioning in the right order, it grinds after it makes the pad. So I first hear the clicking sound (meaning it is making the pad first with old grinded coffee) and then it grinds...
HI
Read the first then go to the bold letters.
To program your Magic Dlx: Press and hold the steam and small espresso buttons at the same time, then push the energy saving button (top right). Water Hardness. The large coffee button programs the water hardness. Press the button once and you will have one light in the top row, left side. Press it again and you should have two lights lit. Press it three times and you have three lights lit. Four and you have four lights lit. Press it a fifth time and it goes back to one light. Each light represents your water hardness. So if you have a water hardness of 3, press it until you have three lights lit. Press the energy saver button to exit the program and save your hardness level in the machine’s computer. It will now tell you when you should descale your machine. Pre-infusion. Press the medium coffee button to activate and you should see the light come on. Press the button and turn the light off to deactivate the pre-infusion. Pre-grinding. Pre-grinding is turned on with the cup warming button. When it is lit, the pre-grinding is on. Press the button to turn it off.
Nov 14, 2009 | Saeco Magic De Luxe Espresso Machine
How do i make bigger cups of coffee . I push the "large button but the amount of water is for a very small cup of coffee. is there a way to change the water level?
Hi
Nov 10, 2009 | Saeco Magic De Luxe Espresso Machine
My palazzo only works when i press the button for expresso?it doesnt work when i push the button for the bigger cup ?
HI
If it works for espresso, but it doesn't work for the large cup, try holding the large cup button down and keep it down. Let it go through the grind, the clicking, and if it starts to dispense coffee , still don't release it until you have the desired amount in your cup. Then release it.
If one of the coffee buttons is held down for 3 seconds or more and then released, the water program goes back to zero. No water. You have to reprogram the button like we did above.
Nov 08, 2009 | Solis Palazzo Espresso Machine
Machine has major problem with grinding beans.
Try removing all beans from bean holder - then use a vacumn machine to remove the bits down amongst the grinder "teeth'. You may have had a small stone in your coffee and if so it may have jammed the grinder.
Once it looks clean, try making a cup of coffee without the beans in the hopper - you should be able to see and hear the grinder revolving and also hear the brew unit moving between the grinder outlet and the water inlet. If it all seems ok now, then add a small amount of beans back into the beans hopper and try making a coffee. If it still will not work, get it serviced. There's not much the average person can do inside these units other than to do more serious damage or kill themselves with an electric shock.
Nov 05, 2009 | Saeco Magic De Luxe Espresso Machine
Beans ground but continuous grinding but not brewing
The grind switch is stuck. Try to free it and clean it.
Mar 15, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Small coffee and coffee not dispensing?
Try to program it, press and hold the small cup button. When you have enough of coffe, release the button.
Now try to make a cup of small coffee.
Hope this will help you.
Best regards
/Mirran
Aug 31, 2008 | Saeco Royal Professional Espresso Machine
Saeco Royal Digital Plus Coffee Maker/Espresso Machine Logo
132 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
