Aurora DT820P Direct Key------need to know Battery size or the battery number-----and how to set it up when I get power? Thanks
3 Suggested Answers
  • 162 Answers
SOURCE: what is the battery size for an Aurora DT920P
LR1130 sized battery
Posted on Jan 03, 2011
SOURCE: I have an old Aurora EB964 Fold up Big Number Dual...
GP189
Posted on Jul 06, 2010
P1684 code mean 2004 jeep liberty
what engine, gas or diesel.?
tech answer.:
Battery Has Been Disconnected Number of Trips to Set Code: 1
Trouble Code Conditions:
Key on, and the TCM detected that it had been disconnected from the Battery Direct (B+) circuit or its Power Ground circuit. This DTC will also set during the scan tool Quick Battery Disconnect procedure. Note: Due to the integration of the PCM and TCM, the transmission part of the PCM has its own specific power and ground circuits.
Possible Causes:
  • Quick Learn procedure was performed with scan tool
  • TCM battery direct (B+) circuit is open or disconnected
  • TCM power ground circuit is open
  • PCM/TCM was disconnected or it has been replaced
bar room answer.
your battery was dead, or removed, or is was bad.
battery is old and cold starts, allowed it to drop battery voltage way too low, (weak battery, or just too cold out, is this in Klondike?)
left head lights on, and battery drained too low and this code sets.
gal at bar says, what should i do?
answer. sell the car. (nah)
reset the code with an $9 scan tool and drive, see if it comes back.
if comes back and battery seems week. bingo, end of life battery.
Dec 13, 2013 | Jeep Cars & Trucks
Battery AND FAN
the only battery I know that is in a desktop is the bios battery, located on the mainboard/motherboard and is a little round silver battery about 1 inch (25mm) in diameter carefully remove this and replace with a new one. You may have to reset any bios settings you had, like the time and date but if you don't know what other setting were then when you switch on to access the bios you tap the "del" key or it could be "F2" on some machines, it is normally displayed in the bottom of the screen when you boot which key it is, just keep tapping it until you get the bios settings, once you get into to bios select the "restore to default" setting. It is possible you wont have to alter anything and if you replace the battery quick enough it will hold your original settings, so a quick tip is to get the number off the battery and get a replacement before you remove the old one. The other thing that could cause your problem is that your power supply is faulty, but go for the cheaper option before you go buying a new supply. As a last thought, I don't suppose you are using a UPS (uninterrupted power supply)? I don't think this would cause the problem but if you are remove it and go direct just to try it.
Nov 27, 2013 | Dell OptiPlex 745 Core 2 DUO E3600 186GHz...
Stater replacement for 2001 4.0 Aurora? How many hours and is the starter under the Intake Manifold like the lexus? No click and poer drained when I turn the key. Wonder if the motor seized. Noted power...
If motor was seized, there would be a big power drained when trying to start it, check make sure battery is fully charge, and have good battery terminals connection's, starter labor flag time is 2.4 hrs.
Jul 21, 2010 | 2001 Oldsmobile Aurora
96 Olds Aurora wont start nothing happens when i turn the key,battery is good.
CHECK THE INSTRUMENT CLUSTER FOR POWER TO GAUGES TO SEE IF THEY WORK WHILE IGNITION IS IN THE ON POSITION.IF NO CHECK THE 40 AMP IGNITION FUSE.IF FUSE GOOD IGNITION SWITCH IS BAD OR HAS A LOOSE OR BROKEN WIRE.IF FUSE GOOD ALL GAUGES IS WORKING.I BE LOOKING AT STARTER AND STARTER SOLENOID.REMOVE THEM HAVE AUTO ZONE TEST STARTER.OR YOU CAN GET A REMOTE STARTER SWITCH AND SET OF BATTERY CABLES.HOOK BATTERY CABLES TO A BATTERY.WITH STARTER OUT OF CAR TAKE BATTERY CABLES HOOK NEGATIVE BATTERY TO STARTER BODY FOR GOOD GROUND.TAKE POSITIVE BATTERY CABLE HOOK TO STARTER POSITIVE TERMINAL WHERE POSITIVE BATTERY CABLE GOES.THEN HOOK THE REMOTE SWITCH RED WIRE TO STARTER POSITIVE TERMINAL AND THE OTHER REMOTE SWITCH WIRE TO THE S OR SWITCH TERMINAL ON STARTER SOLENOID.PRESS THE REMOTE SWITCH IS STARTER RUNS GOOD WITH NO FUNNY NOISES ITS GOOD IF STARTER DONT RUN THE STARTER SOLENOID OR STARTER IS BAD. THE PROBLEMS IN YOUR CAR COULD BE A BAD KEY TRY ANOTHER KEY YOUR CAR HAS THE THEFT DETERRENT MODULE SYSTEM BEST TO HAVE CAR SCAN TO CHECK THE THEFT SECURITY MODULE AND THE TRANSMISSION NEUTRAL SAFETY SWITCH IF ITS BAD STARTER WONT WORK.ALSO CHECK THE THEFT DETERRENT MODULE RELAY. BEFORE REMOVING BATTERY CABLES TURN OFF RADIO SO YOU WONT LOSE YOUR RADIO PLAYING CODE.
May 20, 2010 | 1998 Oldsmobile Aurora
I started having problems with my car 3 months ago, its a 2001 dodge stratus. First, it started off by my car not wanting to start, so we thought it was the starter and it wasnt, it was the alternator,...
Trouble Code: P1684 (2.7L V6 VIN U Auto)
Battery Has Been Disconnected Print this code dataprint_icon_codes.gif Number of Trips to Set Code: 1
OBD II Monitor Type: CCM Details
Indicators: MIL Details
Possible Causes:
May 12, 2010 | 2001 Dodge Stratus
Cmos checksome error
I don't know what kind of unit you are useing.
You need to watch the screen when it boots up.
It will say check sum error, press ? F-2 to continue or F-1 to enter setup.??
Enter the setup screen and change the date and time.
Save ? F-10 and exit.
I hope this has helped you.
Oct 05, 2009 | Intel D102GGC2 Motherboard
572 people viewed this question
jasbo
jasbo
