Question about Plantronics .Audio 995 Digital Wireless Stereo Headset
Usb 995 for headset wireless plantronics flashing and dosent work
5 Suggested Answers
keekus
  • 83 Answers
SOURCE: No Program folder for Plantronics application / driver.
The CS50-USB from Plantronics extends wireless freedom to your softphone. It’s the first wireless headset for VoIP applications with remote call detection and answer/end capability via PerSonoCall software (built-in).
Enjoy yourself without bothering about software!
Posted on Jul 18, 2009
keekus
  • 83 Answers
SOURCE: I am getting feedback with Plantronics CS70 Wireless Headset
Echo is usually caused by the transmit (speak) level on the unit being set too high.
1. First, try lowering the volume of the telephone. If you still hear an echo, adjust the volume of the headset itself.
2. The master transmit controls of the headset are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting.
3. You can fine tune this setting with the plus (+) and minus (-) buttons on the back of the charging base.
4. If this doesn't fix the echo, try moving the configuration dial on the left side of the charging base. The recommended setting for most phones is 1.
vanherringto
  • 1738 Answers
SOURCE: Can one get the plantronics audio 995 USB headset
I believe it should work...
You may want to review this guide for connecting a bluetooth headset to a PS3:
(Click here)
http://boardsus.playstation.com/playstation/board/message?message.uid=26900460
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!!
Posted on Feb 07, 2010
HDI Headsets
  • 537 Answers
SOURCE: My Plantronics .Audio 995 wireless
It sounds like the battery is dead in the headset. That headset has a non-replaceable battery. If the .Audio 995 is still under warranty you should have it replaced. I have included this link to the Plantronics .Audio 995 User's Guide.
Good luck from Headsets Direct!
Posted on Sep 08, 2011
Plantronics audio 995H wireless headset not charging when plugged into computer. It does not show a red light for charging. When turned on it stays blue for several seconds then flickers red for 2 or
38cafd7a-6060-4717-bc4f-b4db91cc266a.jpgI recently fixed my 955 headphones... it's probably not going to be attempted by most folks, but it saved a great set of headphones from being tossed and replaced.
Basically you need to remove the right side padding and take out the 3 screws. This gets you access to the battery. The battery is a standard 3.6V lithium battery. Pretty much the same that is in most cell phones and many small toys. You can simply replace the battery with something like:
http://dx.com/s/3.7v+li
Or... here's what I did... add a lithium USB charger to the battery.
http://dx.com/s/li+arduino
Now, if the battery dies I can plug it into USB and the phone will work while it charges.
Nov 12, 2013 | Plantronics .Audio 995 Digital Wireless...
Tip
Power button not turning on headset
I'm guessing at some point I pressed down too hard on the power button and either broke something or mis-aligned it to what mattered. <br /> If this happens to you: <ol> <li>Plug the headset into the (connected) USB power cord</li> <li>Blue light comes on</li> <li>Unplug - Headset should remain on</li></ol> <ul> <li> If you leave it plugged in until it turns red (charging) then it will turn off when you unplug it.</li> <li> If your headset doesn't show a blue light or any indication of life, something beyond the power button is wrong.</li></ul>
on Apr 08, 2011 | Plantronics .Audio 995 Digital Wireless...
CAN I GET A REPLACMENT USB FOR MY PLANTRONICS 955H?
No plantronics have replaced 995h a model with 995h b model.
They use different dongles. Very good reason to hack the protocol
Jul 31, 2012 | Plantronics .Audio 995 Digital Wireless...
Is it possible to pair my Plantronics audio 995 with a cell phone? After all it is blue tooth
unlikely as it seems to use blootooth technology but doesnt expose the passcode for the connection. see below.
How do I pair my headset to its USB adapter?
Procedure
Your headset and adapter are already factory pre-paired, and should automatically connect with each other. Should your headset and adapter become unpaired, you can initiate pairing manually. To Pair Your Headset and Adapter:
  1. Start with your headset powered off. Press and hold the power button for about 4 seconds, until the status light rapidly flashes blue. Release the button and set the headset aside.
  2. While the USB adapter is plugged into the computer, pinch the connect/pair button for about 4 seconds, until the status light rapidly flashes blue. Release the button.
  3. The headset and adapter will automatically attempt to pair. If the pairing is successful the status lights will glow solid blue; if unsuccessful, both headset and adapter will stay in pairing mode.
If the pairing was unsuccessful and you want to try to pair again, you must first take your headset and adapter out of pairing mode:
  1. Turn your headset off.
  2. Single press the connect/pair button on the adapter.
  3. Repeat the "To Pair Your Headset and Adapter" procedure, above.
If your headset and adapter are separated and lose their connection after being successfully paired, they will automatically reconnect when they come back into range of each other. If they remain out of range for more than 30 seconds, the headset will go into sleep mode, but will reconnect automatically with the adapter once it is back in range. If the headset is out of range for more than 15 minutes, it automatically shuts off.
Jun 11, 2012 | Plantronics AUDIO 995 WIRELESS HEADSET US
I ordered this wireless headset from amazon few days back and received just yesterday. as per instructions I charged the headset with USB given and plugged in the adopter expecting to have a nice skype...
check if the adapter has any switches , check their initial setting and change one by one, had a similar issue with a wireless headset in the past where the switches were in wrong position
if you can confirm the make and model may be able to help more
Mar 21, 2017 | Plantronics .Audio 995 Digital Wireless...
My Plantronics .Audio 995 wireless headphones refuse to charge with the cord provided me or any other one I substitute it for.
Apr 16, 2011 | Plantronics .Audio 995 Digital Wireless...
Can one get the plantronics audio 995 USB headset (with microphone) to work with the PS3? The headset uses 2.4GHz, not bluetooth, so it's not a bluetooth pairing issue.
(Click here)
Dec 14, 2009 | Plantronics .Audio 995 Digital Wireless...
Computer can't discover wireless device
I want to use it on a PS3. Can I and if so, I've lost my pin#. How can I find out what it is?
Nov 08, 2009 | Plantronics .Audio 995 Digital Wireless...
Jan 05, 2009 | Plantronics CS50-USB Professional Headset
Plantronics .Audio 995 Digital Wireless Stereo Headset Logo
78 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
Ed Nelson
Ed Nelson
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
