Question about Husqvarna Forest & Garden 125bt Backpack Blower
My backpack blower won;t start. I replaced the spark plug and it still won't start. Can you make a suggestion?
  • 22 Answers
Check and make sure the rubber hoses coming out of the fuel tank are not broken and look inside also if not that carb is cloggged up maybe pull the fuel hose off and spray some gumout up into it to open up the jet, spray some gumout in the carb and see if you get a sputter out of it then you know your not getting any fuel.. carb needs cleaning
Posted on Oct 03, 2010
Backpack blower will not shut off when knob is pushed to "stop". Have to disconnect spark plug boot to shut off blower.
Your off switch may be wet or disconnected. You can try spraying it with a little bit of contact cleaner or WD to clear the moisture. If this doesnt work you can pull a cover and trace back the wire and see if it just fell off or melted. Good luck and be safe!
Oct 04, 2014 | Stihl Br 320 340 400 420 Backpack Blower...
My echo packpack blower won't start
How long has it been since its been started? If its been a while go to Home Depot and get some fuel stabilizer follow the instructions - if it hasn't been to long go to home depot and get a new spark plug and replace the old one as well as clean the filter -make sure to put fresh oil/gas ratio in the tank - use stabilizer if needed
Oct 25, 2012 | Echo 50.8cc Backpack Blower
Gas and oil mixed in 4 cycle backpack leaf blower
If it is a 4 cycle blower, you do not mix oil with the fuel....It takes straight Gas. there is an oil cap to put engine oil in crankcase, this only usually takes 2,3,4 oz. of oil. Sounds like your Spark Plug probably fouled out from having oil mixed in your gas. I would recomend changing your Spark Plug and put some Fresh GAS only in the blower, dump the old stuff out !!! You should be on your way Blowing in No Time !
Nov 27, 2011 | Troy-Bilt 32cc 4Cycle Backpack Blower
Ran last year, won't start this year. Changed fuel and replaced spark plug. Checked spark and attempted to start with battery and tried with pull cord but no start. pulled plug and it had fuel on it so...
It might have tipped over on its side. Look at the air filter, if you see oil or gas on the filter then you might have to remove and clean the carburetor. I would start by cleaning/replacing the air filter and trying it again. If its getting fuel and the spark plug works then the only other side of the fire triangle is air.
Jun 05, 2011 | Ryobi Backpack Blower 25.4cc
My backpack leaf blower wont star. It was working fine yesterday now it wont star at all. Any suggestions?
Hi! Look for the spark plug,take it out and replace it with a new one,and then try to start it up.Also check if you have fuel and oil mixture right.
It is the most common failure in such hardware.Good luck!
Mar 06, 2011 | Ryobi Backpack Blower 25.4cc
Unable to start my 155BT blower. Have changed
Is the new spark plug wet? If not, the machine is not getting fuel (fuel filter, carb, etc.) If the plug is wet, you may not be getting spark (bad ignition module, short in switch/harness, bad plug (yes it does happen with even new plugs)), or flooding due to incorrect starting procedure or clogged airfilter. Stale fuel can also cause an engine not to start as it lacks volatility. If in doubt, take it to your local dealer.
Oct 22, 2009 | Husqvarna 155bt Gas Backpack Leaf Blower
I have a UT08580 Mighty Lite backpacker blower with a missing spark plug, I need to know what plug goes in it.
The Homelite part number for this spark plug is 870174001. This number crosses to Champion spark plug RCJ6Y which can be bought at any Home Depot, Lowes, Ace Hardware, etc for about $3
Oct 20, 2009 | Homelite Consumer Products Backpack...
Echo pb-260l won't spin up. replaced carb, plug, fuel filter and
i have aecho pb 260l backpack style leaf blower and it will not start. it turns over well and has spark and reasonably new fuel. any thoughts
Jul 17, 2009 | RTO Echo 25.4 Cc Backpack Leaf Blower -...
Ryobi RY08576 25.4cc was started without mixed fuel
If the engine is sticky ie harder to pull it might have to be pulled apart new piston and honing of cylinder. not difficult just a pain. If it doesn't seem any harder to pull, Drain all of the unmixed fuel. Put a few drops of 2cylinder oil in the spark plug hole and pull the starter a few times with the plug out of it. Put a few more drops in repeat. Replace the plug (new plug) Put in mixed fuel prime the system cross your fingers and it should start up for you.
May 12, 2009 | Ryobi Backpack Blower 25.4cc
Husqvarna Forest & Garden 125bt Backpack Blower Logo
782 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
