Question about Husqvarna 21" Lawn Mower with Honda GCV160 Engine HVL 7021RH
How do I replace a recoil assembly on lawn mower
  • 3 Answers
Its typically only two or four screws to replace the entire assembly. But I would try to replace only the cord or spring first
Posted on Jul 22, 2011
3 Suggested Answers
  • 4 Answers
SOURCE: I have a cub cadet lawn mower broken pull cord
just rewind the spring starting with the outer end and fill it back into unit. I always have the rope extended and rewind it back in and reinstall
Posted on Jun 07, 2009
  • 3600 Answers
SOURCE: lawn boy mower bought used wouldnt start then the rope broke
there are 3 bolts that you remove and thatwill allow the coil houseing to come off pull off buy new rope and wind the rop onto the rope holder then roll the spring to it's tighest postion put pull handle on and tie know it rope burn the end of the rope with a lighter to keep it from comming apart, be sure to thread the rope threw any holes before tieing knot. then replace it back on and bolt it together. and your set.
Posted on Jun 22, 2009
Lawn mower recoil spring
Remove mounting nuts, pry recoil off fly wheel. Purchase new recoil assembly at mower repair store.
Jul 10, 2013 | Garden
How do i replace a starter rope on a briggsand stratton lawn mower
Remove the 3 nuts holding the recoil assembly to the flywheel. Observe how the old rope is attached and wound. Rope is sold by the foot at mower repair shops. 3-4 ft should do. The rope is held in the recoil assembly by a knot and held in the handle by a knot.
Jun 19, 2013 | Garden
Homelite ohv 140cc
Remove recoil assembly. Observe cord installation. Remove old cord. New cord is sold by the foot at mower repair shop. Replace cord, reassemble recoil assembly.
Jun 18, 2013 | Garden
Pullstart cable broke
Remove nuts mounting recoil assembly. Observe how rope is wound around pulley. Find end knot in pulley wheel. Cutoff end knot and remove old rope. Find end knot in handle, use needle nose pliers pull thru old rope. Rope is sold by the foot at mower repair shops. Replace rope as observed before removal. Cut to size after wrapping recoil assembly and attaching thru handle at proper length if at recoil assembly or on mower handle. Ensure good knot in hole of recoil assembly and handle.
Sep 22, 2012 | Toro Power Lawn Mower
Removing recoil assembly on Lawn Boy 20" mower. Appears to be riveted on. Do I need to snap rivets?
you can drill them out and replace when done or remove the whole cover and repair the recoil on the cover bolts and lock nuts can replace them if you must take it off just make sure they don't hit the flywheel
Aug 20, 2012 | Briggs & Stratton Garden
Broken pull chord
Remove recoil assembly from top of engine. Observe recoil wheel and find knotted end of rope in wheel, Observe direction of rope wrapped around wheel, cut knot off wheel end of rope remove rope. Rope purchased by the foot at mower repair shop. Feed new rope end into hole in recoil wheel wrap around in correct direction, feed rope thru recoil cover, remove old rope from handle, feed new rope thru handle to proper length, Knot rope to stay in handle.
May 14, 2012 | Toro Power Lawn Mower
I can't start it because the pull cord is stuck and it happened after I installed a new blade.
If the recoil assembly has three screws holding it in place, remove them, lift the recoil assembly off and see if it works off the mower. If it does, reassemble.
Gary
Jun 09, 2011 | Poulan "" Push Mower
I need to replace the pulley and recoil spring assy on my victa statesman mower,how do i do it?
Most recoil assemblies are secured with three machine screws that once removed, allow the assy to be lifted off. The new assy simply reattaches in the same location.
Gary
Jan 06, 2011 | Garden
Pull string won;t recoil
The recoil spring has broken. These are available at any lawn mower parts supply store. The process of changing the spring is tedious but can be done by anyone with average mechanical ability. If you removed the recoil assy (and air shroud if it is riveted on) and took the assembly to a Lawn Mower Repair shop usually they will change out the spring while you wait. If you can't get the recoil assy off take the mower with you to the repair shop. Again most shops will fix it while you if wait but if they are very busy usually they are serviced within 24 hours.
If you do attempt this yourself check in the tips section of FixYa on how to change the recoil stater rope after replacement of the spring.
I highly recommend you replace the pull rope at the time of the recoil spring replacement.
One final note... there is a possibility that the pull rope spool has been damaged where the spring attaches.
Thanks for using FixYa,
Kelly
Apr 28, 2010 | Mtd 22" Yard Machine Push Mower
Jun 07, 2009 | Garden
Husqvarna 21" Lawn Mower with Honda GCV160 Engine HVL 7021RH Logo
370 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
