Question about Maytag Dryers
Making loud unusual sound & is causing black marks & rips/tears in clothing
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It seems to be the belt that has gone bad and to resolve this it should be replaced. Please check this video on how to replace the belt in dryer. Also check the tensioner pulley and replace it. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 03, 2010
Whining noise on Volvo 240 when in neural and park
A common cause of a whining or buzzing type noise when not in gear (neutral and park) is a WORN PUMP in the transmission. How many miles are on the car??
A noisy pump is just noisy and won't cause a breakdown until it becomes MUCH louder. If the noise is not that loud at this point, just keep driving it for now, and chalk it up to normal wear & tear. But DOOO make sure your transmission fluid is topped off. The amount of fluid between the LOW and FULL marks is about one pint. DON'T overfill OR allow it to get below the LOW mark. Transmissions are VERY fluid-level-sensitive.
Sep 18, 2016 | 1988 Volvo 240
Loud noise when spinning black marks on clothes leaves drum circle marks on clothes
it sounds like the bearings have gone ...are the marks on clothes oil marks ? or grease marks ? this is a sign of bearings. if there rubber marks it will be your door seal thats gone ( dose it leak )
May 05, 2015 | Beko Washing Machines
Whirlpool washer rips my clothes and wash rags
Worst case. The usual cause of this is that the drum bearings have callapsed and there is now a lot of "play" between the wash drum and the outer drum catching the washing inbetween them as the drum turns. This would be accompanied by a a very loud noise.
Best case. clothes gaurd has broken and tearing at the washing at the drum turns.
Oct 03, 2014 | Washing Machines
My Bose Cinemate series ii is making very loud intermittent crackling sounds
Usually made from interference of some sort. Make sure that all wire connecting from both the input on the receiver and the output devices are properly secured and have no rips or tears in them. Also make sure there is nothing close the receivers with a powerful magnet (big subwoofers, powerful speakers, computers, etc) those can also cause interference. Hopefully this helps.
Sep 25, 2012 | Bose 318842-1100 - Cinemate Series Ii...
Hotpoint wf640 makes too much noise whilst spinning level of machine is balanced perfectly makes same noise on every selected speed
sounds like the bearing but could also be the drum support bearing more likely discontinue use until it is sorted or it will collaspe completely or you will experience black oil marks on clothes or tearing, if in guarantee call the manufactuer.
Mar 31, 2010 | Washing Machines
Left front wheel binding and loud click
CHECK THE CV AXLE FOR A RIPPED RUBBER BOOT OR UNUSUAL PLAY. IF YOU NEED TO REPLACE IT, CHANCES ARE THE PASSENGER SIDE CV AXLE IS SURE TO FOLLOW BY MAKING THE SAME SOUNDS. I HOPE THIS SOLVES THE PROBLEM. THANKS FOR USING FIX-YA. PLEASE KEEP ME POSTED
Sep 02, 2009 | 2005 Dodge Durango
Black stains on white dress shirts
The rollers, guides, or wheels that are used to support the clothes drum may be worn out. When this happens, it may cause the drum to drop down slightly in the front or rear. Clothes can get caught between the front or rear of the drum and the dryer interior. This can cause clothing to have marks and/or tears. Check out the rollers, guides, and wheels for excessive wear or damage. Sure hope this helped ya!
Jul 20, 2009 | Whirlpool WGD5900S Gas Dryer
Clothes are getting caught on edges of drum
you need to replace the felt on the dryer
Dec 19, 2008 | Dryers
Dryer Noise & Black Marks On Clothes
Most likely the front drum bearing part number 5303937139 needs to be replaced. Instructions come with the kit.
May 31, 2008 | Frigidaire FDE336RE Dryer
Rips and tears in clothes
The washer could be developing a transmission problem. As the washer agitates, the plastic tub is suppose to remain still. If the transmission is starting to slip, it will also try to spin during the agitate cycle, thus making the clothes become tangled under the agitator.
Sep 26, 2007 | Maytag Performa PAV3200
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
