Question about Pinnacle Studio Plus Version 11
This no longer works correctly and I have tried to uninstall but without success,states that I need Windows Net Framework 2 to be installed.I did not have this when the programme was installedI have the insatallation discs to re install but this does not happen because of the previous installation I have tried Reg delete for Studio but no success.I am willing to purchase if necessary version 14 but not sure if this would work alongside a corrupt version 10.8 plus. I am using Windows XP Any help would be appreciated
  • Pinnacle Master
  • 13,433 Answers
Okay, we have two ways of going about this
1. install the net framework
2. remove the program with 3rd party tools.
Lets go with installing net framework 2 as its a good program to have installed on the computer in any case.
net framework is available here http://www.microsoft.com/downloads/en/details.aspx?FamilyID=0856eacb-4362-4b0d-8edd-aab15c5e04f5&displaylang=en
Just click on the download button on the page, ones its downloaded double click the file and run the setup, use default settings don't change anything, when its done, try running the uninstall again - you may have to restart the computer first.
If that doesn't help then run revouninstaller FREE http://www.revouninstaller.com/revo_uninstaller_free_download.html
download the free version from the above website. There is a pay for program also there, just go with the free one.
After you have installed the program, run it, select the program from the list that you want to uinstall and uninstall it.
Use the Advanced option when you are offered multiple options on uninstalling. Click next.
Select all entries related to the program, and delete. click next, Select all files related to the program and click next. follow instructions on screen.
When the uninstall is finished the program should be gone, just to be sure, restart the computer and go look into the uninstall programs tab in control panel, is it still there?
Then try installing the new program.
Let me know if you need further assistance .
Posted on Oct 03, 2010
Installing print shop 23 on windows 8.1 get framework incompatibility error. what should i do?
I now have PrintShop 23.1 up and running on my Windows 8.1. This is what worked for me:
1. First, RIGHT CLICK on the Printshop icon on your desktop, select Properties, click on Compatibility, and make the selection to run the program in Compatibility Mode for Windows 8. Click Apply, then OK to exit.
2. Double click the Printshop icon on your desk top to open Printshop. If it works - great! However, if it does NOT work, it means the .NET framework required to run the program was uninstalled or corrupted by the Windows 8.1 upgrade and needs to be reinstalled, so please do the following.
3. From your Control Panel, select Programs and Features; in Programs and Features, uninstall Printshop. (You get to the Control Panel by clicking on Settings in your desktop popout taskbar, usually on the right side.) 4. Check to make sure the Microsoft .NET framework is also uninstalled. If not, attempt to uninstall. If you have recently gone to Windows 8.1, it may be partly or fully uninstalled because the 8.1 upgrade might have removed (or damaged) part of it. If it will not uninstall, don't worry! Proceed . . . 5. Follow this step even if you see no sign of the .NET framework in Programs and Features. It is almost certain that you have debris from it on your computer because this is a known problem, and Printshop will not reinstall unless the debris is removed. THEREFORE, clean your computer by using the Microsoft .NET Framework Cleanup Tool found at the following link:
.NET Framework Cleanup Tool http://blogs.msdn.com/b/astebner/archive/2008/08/28/8904493.aspx
6. AFTER Printshop is once again installed, it will very likely NOT RUN unless you follow Step #1, above, to run it in Windows 8 Compatibility Mode.
Dec 20, 2013 | Broderbund The Print Shop 23 Deluxe
Lexmark productivity studio
Hi, in Windows 7 Microsoft.net framework 3 is installed and newer versions can be installed on it. If you try to install an older version, it will block your installation.
1-Try to download it from Microsoft\'s website and install it with administrator account privilege.
2-Go to the control panel, find out if Windows features are on or off. Try to check
Microsoft.net framework and then restart Windows. Then reinstall it.
3-If you have still problems, go to www.microsoft.com and search microsoft dot net framework 2 in windows 7.
kind regards
Apr 17, 2013 | Office Equipment & Supplies
Microsoft Framework 3.5SP1 willnot load through my Turbo tax soft
please perform a recovery and then witout updating please install the turbo tax software
Feb 26, 2010 | Microsoft Windows Vista Ultimate Edition
I tried to install Grey's antomy video game for pc and this is what popped up.C:windows/microsoft.net/framework/v2.0.5727/mscorwks.dll could not be loaded Is there a way i could get my game ti work
It sounds like you have an application that is using the .NET Framework. Uninstall .NET Framework v2 from Control Panel, Add-Remove programs.
Re-install the .NET Framework software by running your windows update. Don't forget to rerun the windows update until there is no more update. Throughout the process you will need to reboot. Once completed reinstall your game.
Nov 24, 2009 | Computers & Internet
Can not install Net Framewoek 3.0 because of
Sir,
Run the cleanup tool to clean out temporary files, run the .NET
Framework cleanup tool, Run the installation file, then reboot and try to install it again and see if it works. If not try the below following steps....
Step One:
1. Go to Add or Remove Programs, try to remove all .NET Framework.
2. Please download and install the Windows Installer Cleanup utility
from this link:
http://download.microsoft.com/downlo...BD/msicuu2.exe
3. Then, please run it from Start-> All Programs-> Windows Install
Clean Up.
4. Please remove all Microsoft .NET Framework shown there and click
Remove.
Step Two:
1. Click Start->Run, type INSTALLER and click OK.
2. In the open folder, click View menu and select Details.
3. Right-click the Date Modified column header.
4. Click Comments
5. In the Comments column, locate the cached Windows Installer file
that displays Microsoft .NET Framework 1.1 (English) RTL x86 enu.
6. Right-click the cached Windows Installer file and then click
Uninstall.
7. Close the window.
8. Delete the cached Windows Installer file.
Step Three:
1. Restart your computer.
2. While your computer is booting up, press F8 to invoke the startup
menu.
3. In the startup menu, choose Safe Mode.
4. Log on as an administrator.
Note: In Safe Mode, your system display and Desktop will look and
perform differently than in Normal Mode. This is only temporary.
5. Delete the folder C:\WINDOWS\Microsoft.NET
6. Delete the folder C:\WINDOWS\system32\URTTemp
7. In the C:\Windows\System32 folder, locate the file mscoree.dll.
Right click and rename it to mscoree.old
Step Four:
1. Click Start->Run, type REGEDIT and click OK.
2. Navigate to the following registry key by expanding the "+" beside
the registry tree in the left pane:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\.NETFramework
3. Delete this key in the left pane.
4. Repeat steps 2-3 to delete the following key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup
5. Restart your computer to Normal Mode
Step Five:
1. Please download the Microsoft .NET Framework Version 1.1
Redistributable Package from the following link and save it to C:
http://www.microsoft.com/downloads/d...DisplayLang=en
2. Click Start->Run, type "c:\dotnetfx.exe /C" (without quotation marks
and there is a space in this command) in the open box and click OK.
3. Click Run, and type "C:\.NET Framework 1.1" (without quotation
marks) in the open box click OK
Note: If you are prompted to create this folder, please click Yes to
continue.
4. Locate the folder C:\.NET Framework 1.1 and double click the file
netfx.msi in it to install .NET Framework components.
If .NET Framework 1.1 can be successfully installed, we can go on to
install .NET Framework 1.1 Service Pack 1:
Microsoft .NET Framework 1.1 Service Pack 1
Step Six:
If the above two can be installed correctly, please download KB886903
from the following link and install again:
http://www.microsoft.com/downloads/d...displaylang=en
If the problem still exists, please describe the error message when
installing Microsoft .Net Framework Service Pack in further detail
Thanks
Good luck
Nov 07, 2009 | Microsoft Computers & Internet
Microsoft lifecam 2.07 installation problems - Infinite loop
In my case the LifeCam 2.07 installation problems on Win XP SP3 were related to Microsoft .NET Framework. Figured this out by looking into the temporary directories LifeCam installation creates - it seemed like it was repeatedly extracting and trying to install .NET 3.0 without success. Fixed this by installing .NET Framework 3.5 SP1 and all following updates from Windows Update first. Then the LifeCam installation worked fine.
Jun 20, 2009 | Microsoft LifeCam NX-6000 Webcam
.Net Framework 1.1 sp1 Install Fails
You need to uninstall and install the latest version of .net frame work
You can download it from www.microsoft.com/downloads
Apr 15, 2009 | Microsoft Windows Vista Home Premium with...
Can't run Print Shop Deluxe version 23
You will need Microsoft .NET Framework to run some instances of Print Shop Deluxe. If you install it, the patch will not work without .NET Framework installed.
Feb 05, 2009 | Computers & Internet
When I try to open HP Director, I get a FATAL ERROR message; CLR error 80004005 How can I fix this? Bob
All I can uncover is it may have something to do with the .NET Framework. My suggestion would be to uninstall the 3.0 .NET Framework through the control panel's Add or Remove Programs. (Are you running Vista? If not, you don't need 3.0)
Reboot and see if it corrects the problem.
If not, uninstall the .NET Framework 2.0. Reboot. See if it works.
Then download .NET Framework 2.0 and reinstall. (I would go through Windows Update to do this.)
Reboot. See if that corrects it.
Oct 29, 2008 | HP Office Equipment & Supplies
Pinnacle Studio Plus Version 11 Logo
41 people viewed this question
Top Pinnacle Computers & Internet Experts
AL Schehr
AL Schehr
Level 1 Expert
Alun Cox
 Ian Kayhan
Ian Kayhan
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
