Question about Irons
Morphy richards jet stream iron
Calc light flashing dont know why
  • Anonymous Mar 21, 2014
    trips electric how do I remove covers to get to elements and gaskets
  • Anonymous Mar 27, 2014
    Intellidome iron lcd panels flashing emfill water tank but tank is full
We have a water filter and softened water. Our iron is clean and went after 2 months.
A Morphy Richards Jet Stream Elite pro.
It is just the steam generator that has gone.
Posted on Oct 28, 2008
  • 304 Answers
Make a solution of half water and half white vinegar. Fill up your iron and get it good and hot then let it sit a couple hours. flush out and repeat as necessary. Hope you find this helpful. Please give me a fixya rating If this works for you. It works very well as long as it is not completely filled with scale. Once you have it good and clean By a gallon of bottled water at the market and use that for your Iron and you will never have a scale problem again. I learned how to do this 20 years ago from a 80 year old woman from england. If it is really bad you can up the vinegar concentration but do not go higher than 2 cup to 1.
George
Posted on Jul 24, 2008
Why is there No steam from morphy Richards 42247 model steam generator?
It may be calcified or have lime scale. If the heater is "gummed up", it cannot heat properly. Try using either vinegar (takes longer) or an iron cleaner. You pour it in and it breaks up the scale. CLR works quite well too. Use pipe cleaners to clear out the holes in the sole plate.
Jun 02, 2014 | Morphy Richards Jet Stream 42271 Iron
Brown muck coming out of the iron
Use CLR the r stands for rust It will descale the iron for lime while it is there. It would be better to own a quality iron that uses stainless steel or other non ferrous metal.
Nov 28, 2013 | Morphy Richards Jet Stream 42271 Iron
Descale
Soak and/or run vinegar or CLR through it. They also make a steam iron cleaner.
May 11, 2013 | Morphy Richards Jet Stream 42271 Iron
How to descale your morphy richards jet stream 42271 iron
you must read your owner manual section maintenance or troubleshooting , or get contact support from the factory, via chat or phone.
God bless you
Sep 23, 2012 | Morphy Richards Jet Stream 42271 Iron
MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON does not provide steam
My MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON has stop producing steam. I have changed the filter and although it heats up, it does not produce any steam.
Feb 29, 2012 | Irons
The iron will not steam and the standby button is constantly flashing
Always switch off the unit and allow to cool before cleaning or storing. .... If your steam generator does not work, check the following points: ... working temperature, the LOW STEAM ICON will flash whilst the heating cycle takes place ... steam. 9 When ironing is complete, press the POWER. STANDBY button.
Jul 27, 2011 | Morphy Richards Jet Stream 42271 Iron
Refilling water reservoir
The Instruction Book for your Morphy Richards 42298 Iron can be found here:
http://www.morphyrichards.co.uk/Downloads/InstructionBooklets/IB42298.pdf
Make sure that before you attempt to slide the water tank back that you operate the Tank Release Knob.
See the instructions for an illustration of your iron and the positioning of the Tank Release Knob.
Sorry someone has not responded sooner.
Jun 04, 2010 | Morphy Richards 42298 Iron with Auto...
buy a new iron at Walmart for $20
Apr 02, 2009 | Irons
Irons Logo
1,578 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
