Question about Dell E172FP 17" LCD Flat Panel Monitor
Power button has failed - Dell E172FP 17" LCD Flat Panel Monitor
  • 11,361 Answers
Cna you feel it clicks? More likely to have circuits failures than the broken switch.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Posted on Oct 03, 2010
Micromax a90
Hi, try these. press power and volume down button for 10 sec. Then try to power up it by briefly pressing power button. if fails, press power and volume up, be carefull , when the screen comes live - not to select any other option but only normal boot. To select a option press volume up button, it will power off, then power on again by pressing power button. it may fail by keep trying and in between keep charging ..
Thanks
Jan 16, 2014 | Android Cell Phones
How do you know when the power supply is failing?
Actually its not the matter with the Power Supply,but with the CPU Cabinet Power Button.I recommend that you should replace the Cabinet.It will surely help,and for the freezing problem it's your Hard Drive problem,you can also try re installing Windows...!!
But for the Power Button problem you should definitely replace the cabinet
Aug 21, 2012 | ASUS A7V400-MX Motherboard
Why does my laptop power button, battery 1, battery 2 stays on on power up? nothing further, cannot see the logo for Sony and the fan is silent
The easiest solution is to press power button for 10-15 seconds. Release it and try to start it again. If this fails, then remove battery and try to start the laptop without it. If this also fails, try without ac power, only battery. After trying all that and still fails, you have to go to the repair shop, sorry.
May 14, 2011 | Computers & Internet
Cannot turn on.
Since you have power to the clock display- there is power to the unit. The "power" function button has failed because the momentary switch on the circuit board below the touch pad has failed. These little push switches have a short service life.
I suggest checking a source who sells the control circuit board for Soleus Air LX-140. Might be similiar component.
KT
Jul 30, 2010 | Soleus LX-120 Air Conditioner
Laptop fails to start up when the start up button
The pwr supply is not properly connected to boot up. might be a h/w or s/w issue also. check with the service center
Mar 04, 2010 | Toshiba Satellite Pro L300 Notebook
On/off button for hp pc fails
I worked on an older system and it could be a bad motherboard
Nov 14, 2009 | Computers & Internet
I have a stuck power button on an HP 5850. It is
Try using a needle to pop the button back up. If this fails then most likely the spring for the button has failed and you'll have to use your new parts. Another method is to tap the button with a teaspoon handle lightly several times.
Sep 21, 2009 | HP DeskJet 5850 InkJet Printer
Computer won't turn on
check that the switch on the power supply has not been accidentally bumped.
It should be on the - side... not the o side.
There could be a variety of other problems including the power switch.
Possible reasons a PC will not power up:
Failed Power Button.
Power strip breaker tripped - are there other items plugged in that work?
Failed memory Module.
Failed CPU.
Failed CPU Cooling fan.
Failed power supply.
You will need to test each item with a Digital Multi Meter (DMM) and verify 12VDC at each item. CPU and Memory can only be tested externally by a shop with a reader.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 18, 2009 | E-Machines T3958 (827103050974) PC Desktop
Standby button fails to go green
if there is a remote control does it work from it?
have you tried removing power from the wall for a few minutes then retry, sometimes the computer inside gets scrambled brains and a hard power reset might wake it up.
Feb 09, 2009 | Philco 841.169 Turntable
Dell E172FP 17" LCD Flat Panel Monitor Logo
21 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
