Question about Gateway FPD2185W 21 in. LCD Television
My Gateway FPD2185W monitor goes on for about 1 minute and then goes dark. I have replaced 8 capacitors on the main board. How do I fix this problem?
  • Jimmy Dale Satter Oct 15, 2010
    Apprentice,
    Thanks for the imput, I'll do it and let all know if this solves the problem. I also have a new problem, it appears that in the process of unpluging the the monitor from the mother board, one of the wires has come loose from the grey connector. If you have a suggestion on how to reconnect the wire and/or replace this connector, please let me know. My email address is jdsatter@sbcglobal.net.
    Thanks again for you help,
    JD Satter
  • Jimmy Dale Satter Oct 16, 2010
    Sprint6,
    I really appreciate hearing back from you. I just hate the thought of having to trash a $600 monitor. I would be open to use Yahoo Messenger except the computer I'm on doesn't have it installed and the owner would rather not have it. I have sent you a duplicate pos, including my phone # and a pic. to your email: ru4rehab@yahoo.com.
    That being said, I'll attempt to describe my problem a bit further, as you have requested. There are 5 groups of wires that connect the screen of the monitor to the motherboard of which I have disconnected(unplugged) each time (4) that I have accessed the motherboard. If you lie the monitor down, face up, with the screen removed, on the right-hand side, there are 4 places where 4 groups of wires connect to the motherboard. If you look at the back-side of the screen, you will see two of the groups have 2 wires each(both white) while the other two groups have 4 wires each(each consisting of a yellow, black, Lt. blue and a pink wire), at least on my monitor. These groups of wires have been further grouped into 2 groups by the use of thin chrome tape wrapped around joining a group of 2 wires with a group of 4 wires. These two groupings of wires plug into the mother board right next to each other. Hopefully this all makes sense to you so far.
    My problem, aside from having the monitor light up for about a minute and then go dark, is that it appears that while I was disconnecting one of the small 2 wire groups from the mother board, I inadverntly pulled out the small white wire from the gray female plug used to connect the two white wires of that group to the mother board (see pic.). My mind says that all I have to do is snip the other wire, get a new female plug like the one used, strip a little of the plastic coating off each wire, secure each wire into the new plug and then I'll be good to go for re-connect.
    If this is correct, would you know the name of that kind of plug/connector and where could I get such a plug. Also, regarding my orignal issue, can you be a little more explainatory regarding the diod you recommend me replacing? To me, a diod looks like a resistor. How do I know what to get? I would think that I should be able to get both at Allied Electronic's which is where I purchased the caps that I have already installed.
    Again, thanks for your time and willingness to help me save my monitor. I look forward to hearing from you soon.
    Sincerely,
    JD Satter
  • 36 Answers
Try replacing the diod located within the group of caps you have already replaced
Posted on Oct 15, 2010
  • Rodger Hale Oct 15, 2010
    Saw your post “Apprentice, Thanks for the input, I'll do it and let all know if this solves the problem. I also have a new problem, it appears that in the process of unplugging the monitor from the mother board, one of the wires has come loose from the grey connector. If you have a suggestion on how to reconnect the wire and/or replace this connector, please let me know. My email address is jdsatter@sbcglobal.net. Thanks again for your help, JD Satter”
    Not sure what you mean by unplugging the monitor form the mother board connector.
    If you could explain the problem a bit deeper, of have a photo of the connector in question, would be a great help.
    If you would like for me to call, which is the best way to figure out what may be involved with your unit , please give #, and when best to make contact.
    Also you can use yahoo messenger to get a quicker feedback, ru4rehab@yahoo.com
    Full ViewMy Gateway FPD2185W monitor
    To: ru4rehab@yahoo.com
    Sprint6,
    I really appreciate hearing back from you. I just hate the thought of having to trash a $600 monitor. I would be open to use Yahoo Messenger except the computer I'm on doesn't have it installed and the owner would rather not have it. I have sent a duplicate of this post including my phone #, best time to call and a pic. to your email: ru4rehab@yahoo.com.
    That being said, I'll attempt to describe my problem a bit further, as you have requested. There are 5 groups of wires that connect the screen of the monitor to the motherboard of which I have disconnected(unplugged) each time (4) that I have accessed the motherboard. If you lie the monitor down, face up, with the screen removed, on the right-hand side, there are 4 places where 4 groups of wires connect to the motherboard. If you look at the back-side of the screen, you will see two of the groups have 2 wires each(both white) while the other two groups have 4 wires each(each consisting of a yellow, black, Lt. blue and a pink wire), at least on my monitor. These groups of wires have been further grouped into 2 groups by the use of thin chrome tape wrapped around joining a group of 2 wires with a group of 4 wires. These two groupings of wires plug into the mother board right next to each other. Hopefully this all makes sense to you so far(see pic. attachment).
    If this is correct, would you know the name of that kind of plug/connector and where could I get such a plug. Also, regarding my orignal issue, can you be a little more explainatory regarding the diod you recommend me replacing? To me, a diod looks like a resitor. How do I know what to get? I would think that I should be able to get both at Allied Electronic's which is where I purchased the caps that I have already installed.
    Sincerely,
    JD Satter
Why does my gateway fpd2185w monitor screen go black after showing my desktop for about 1 minute
David
That problem is calle,refresh, thats happend when the monitor try to refresh the page or "clean" the page, you can set that in your video driver options. but if you don't have a video driver for your particular video card already installed, you don't have a right refresh rate and this delay, may happend.
Carl
Mar 22, 2016 | Gateway Computers & Internet
When power is connected the blue light blinks for a minute and then stays on but no picture is available at all. Is it the capacitors? thanks
could be capacitors but then again if the capacitors aint leaked its defo the tuner board or in other words the main board
Mar 26, 2010 | Gateway FPD2185W 21 in. LCD Television
I HAVE A Gateway FPD2185W that goes on for a split second then goes black I have already changed the 8 capacitors that i was told to change is there anything else i can do because it still does the same...
make sure there are no briged solder connections. make sure all the inside connectors were properly inserted into the connection on the boards. Check to see if you have the correct input settings by pressing the pushbuttons on the right lower side of the monitor. check all cables or switch to dvi or agp cables.
Nov 26, 2009 | Gateway FPD2185W 21 in. LCD Television
Gateway FPD2185W
The next thing to try would be to resolder all of the connections on the transformers in your monitor. If you can take a few pictures of the board and email them to me I will mark the points to check and send it back to you.
Buddy
Corporate Computer
www.ccl-la.com
Aug 14, 2009 | Gateway HD2200 LCD Monitor
Gateway fpd2185w capacitor fix question
to take solder off you can get some cross wire called DESOLDER this copper wire soaks up the old solder, by heating this new desolder the old solder will jump into it and clear your way. I like the Techspray #3 no-clean model 1822-5f
and its made in the USA!
Jan 15, 2009 | Gateway FPD2185W 21 in. LCD Television
When you say that you replaced "all the capacitors" what are
you referring to? There are 8 identical capacitors in the corner
of the Power Supply/Inverter board that go bad, but there are
also 3 capacitors in the corner of the Main board nearest the
connector that goes to the power supply that can also go bad.
These are associated with the part "U15" nearby, which is the
3.3 Volt voltage regulator for the main board. If these caps go
bad, this regulator can fail to operate, and you will get no display.
Oct 02, 2008 | Gateway FPD2185W 21 in. LCD Television
Trying to fix lcd Gateway Monitor.
There's a couple capacitors you need to replace. On the video board, not the power supply board. There is (3) 470uf16v on the video board. They have to be the smaller ones, you can not use the larger ones (they will not sit flush onto the board) Any questions, e-mail me at Andrew@CreativeAudio.biz
Jul 04, 2008 | Gateway FPD2185W 21 in. LCD Television
Screen only stays on for 1 sec
Assuming you changed all the caps and did it correctly.
IF you get flickering, It could be a transistor on the inverter board.
OR !!! and probably more likely,
It could be one of the bulbs in the lcd itself is failing. It only takes one bad bulb to stop an inverter from firing up !! You can check them one at a time if you have another working monitor.
If you do unplug a good bulb from the good monitor and try each of the questionable ones, one at a time.
Doesn't have to be a gateway monitor to test it, just needs the same backlight plug.
ebays bammbammfran
Jun 05, 2008 | Gateway FPD2185W 21 in. LCD Television
Open Questions:
See all Gateway FPD2185W 21 in. LCD Television Questions
Gateway FPD2185W 21 in. LCD Television Logo
358 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
