Question about New Bright Bright 1 14 RC FF 96v Off Road Monster Truck
I would like to buy replacement parts for my off road monster truck, example i would like to by front tire, rim & spindle as they are one assembly component on the truck. How & were can i purchase parts. Regaurds Vern
    Problem Solver:
  • 16 Answers
You could try www.fueled4wd.com. They sell off road truck parts. They might have just what you need.
Posted on Aug 13, 2013
    Problem Solver:
  • 16 Answers
You can call the company from where it is made or look on their website on how to purchase replacement parts
Posted on Oct 03, 2010
Why would my car shake no matter what rim and tire I use?
you don`t say if you had the wheel/tire balanced. you could have damaged the CV joint on that side causing a binding in the bearing.
Jul 11, 2015 | 2006 Hyundai Sonata
Front tire size?
With a tube type laced wheel:
WHEEL SIZE & POSITION = 21 in. - Front RIM SIZE & CONTOUR = T21x 2.15 TLA TUBE SIZE =Side Valve Tube MH90x21 TIRE SIZE = DUNLOP D402 MH90 - 21 54H
With a CHROME ALUMINUM PROFILE LACED RIM:
WHEEL SIZE & POSITION = 21 in. - Front RIM SIZE & CONTOUR = T21x 2.15 MT TUBE SIZE = Center Valve Tube MH90x21 TIRE SIZE = DUNLOP D402 MH90 - 21 54H
With a Tubeless Cast Wheel:
WHEEL SIZE & POSITION = 16 in. - Front RIM SIZE & CONTOUR = T16 x 3.00 D Rim Valve hole diameter = .035 inches MH90x21 TIRE SIZE = DUNLOP D402 MT90B16 72H
Jul 11, 2014 | 2006 Harley Davidson FXSTDI Softail Deuce
I ran off the road into a field to avoid hitting a deer. It was abrupt & bumpy. Now my front passenger tire is bent inward and steering wheel must be sideways for the truck to run straight. What are...
If the tire on the rim is still holding air and the rim isn't obviously bent it should be alright if you go nice and slow but would still be a better idea to put a spare on it if you got it. Slamming off the road though it's possible you just threw it out of alignment which would be great, but then again you could have bent part of your steering linkage.
Nov 10, 2012 | 2001 Ford Explorer Sport
I have 1998 toyoto corolla what kind tire should i use and what size
This depends a lot upon what size rims you have, and what your driving conditions will be. Generally, the type of tire that is already in use on the car should be fine (the tire type and size are printed on the side of the tire ... usually something like "P175 65R14" or something like that -- it's in big lettering on the sidewall). The "P" in my example is for "Passenger" cars ... the first number (175 in the example) is the width of the tire tread in Millimeters ... the second number (65 in the example) measures the depth of the tire -- the distance from the rim to the tread ... "R14" gives you the radius of your rim.
The width of the tire affects the handling of your car (wider tires give you better handling) but can also contribute to road noise -- the wider the tire the noisier it is. If you've heard the noise from a Jeep with mudders (extra wide tires for driving in muddy conditions), then you understand the noise. With a Corolla you will probably not be facing too many off-road situations, so between 145 and 185 should be fine for a first number.
With a corolla, I would always recommend a passenger tire ... other ratings are for trucks and load-bearing vehicles.
The depth of the tire can also affect handling and road noise. The second number (65 from the example) gives you the depth. If you are looking for low-profile tires, this would be a smaller number. Although this does affect the handling and noise, it is mostly about the look of the tire. If you desire to have a family-car look, go far something in the range of 65 ... A little more or less will not have much effect that you will notice, but a larger number will make the car jolt less whan you hit a pothole or a bump in the road.
"R14" from the example is the most important number, and the only one that cannot change without changing the rims. This is the radius of the rim, and MUST match or the tire will not fit, or will pop off the rim while driving. Read the sidewall of the tires you have now, and use the same R number. Generally, anyone mounting tires will make sure that you have the right size before they will put the rubber on the rim for you -- it is as dangerous to mount a wrong-size tire as it is to drive on one.
If you have more questions about your tires, I would recommend visiting a tire retailer and speaking with someone directly -- they are generally well trained about tire specifications, and can give you more detail about the effect that each aspect of a tire will have on your driving experience. Having driven a few Corollas, I always used P175/65R14 on mine (I think it is pretty standard) but please be sure to check your tire to make sure you have the same size rims.
May 23, 2011 | 1998 Toyota Corolla
Denali GMC 700C Women's road bike wrong tires!!!
Can you explain why you think the tires are too big? Do they NOT fit the rims? What condition was this bike in when you bought it? If the brake pads line up with the rims then the wheels are correctly sized for the frame.
May 06, 2010 | GMC Denali 700cc Women's Road Bicycle
The front end shakes bad at 40 miles per hour on my 1993 ford f-350 crew cab 4x4
You may need your steering realigned, also, make sure you have your wheels bolted on straight. If those clear, get your spindles checked, along with your shocks.
Mar 18, 2010 | 1993 Ford F350
What is the proper tire size for a 2000 caravan
If you want to know the correct tire size for your vehicle. Open the drivers door and look on the edge of the door under the latch. You should find a data plate that will tell you size of tire for your van and proper air pressure for front and back tires.
Oct 14, 2009 | 2000 Dodge Caravan
How do you remove the front tire from a Honda crf 150 cc dirt bike?
The axel has a nut on one end and two bolts or one pinching the shaft on the other. Jack the wheel off the grond unscrew the nut loosen the pinch blots pull out the axel and the wheel falls out Watch wher the spacers go as they have to go back turned the right way. the brake rotor has to be lined up with the caliper to put it back in as you don't push the brake with the wheel off as the pads will have tobe pried open to get the rotor back in. Tring to fix a flat? same as a bicycle except use soapy water don't forget to use water to cheak for leaks then put on the powder on the tube before it all goes back good tire irons come from bike dealers and bike parts suppliers. Screw drivers cause more troble than thier worth. Road going bikes chage the tube patches are Illegal DOT
Aug 15, 2009 | 2005 Honda CRF 150 F
Tires scraping my outer rim on the driver rear side !!!
the problem is that your car is sitting to low you will need to go to a machanic to get a lift kit for your car so that it will stop rubing against the rim or get smaller tires and it will work just as well
hope this helps you
Jun 27, 2009 | Cars & Co X Pattern Off Road Tires 1/8...
Back tire
often times the inner hub of the rim seizes up in the spindle. use the wd40 on the studs and the rim hub and let sit for an hour then your going to have to use you foot to kick the tir on the top and the bottom of the tire untill it works loose. also have somehelp you by using a big sledge hammer to hit the back side as you hit from the front of the tire this will work quite well. in no time tyhe tire and rim will come off . then use a anti seize on the spindle hub not on the studs when you replace the tire.
Apr 18, 2009 | 2002 Oldsmobile Bravada
New Bright Bright 1 14 RC FF 96v Off Road Monster Truck Logo
150 people viewed this question
Top New Bright Toys Experts
Colin Stickland
Colin Stickland
MeAndMyBrain
Level 1 Expert
Tom Chichester
Are you a New Bright Toy Expert? Answer questions, earn points and help others
