Question about Singer 7422
The top thread is not picking up the bobbin thread. Singer Model 7422
    Genius:
  • 1,788 Answers
Check your needle and make sure it is not bent, needles should be replaced after about 8 hours of sewing and that they are the right size for your project. Also use the same weight of thread, do not mix ie. cotton or polyester. Then check your threading, did some thread get tangled? Or sneak out of a guide? Hope this helps.
Posted on Oct 03, 2010
Singer advance 7422 bobbin jumps
Did you get it fixed? Here is a video that may help.
Mar 20, 2014 | Singer Advance 7422 Electronic Sewing...
Top thread won't pick up bobbin thread
The machine's timing may be off and you can take the machine into a repair shop or contact the manufacturer through their web site.
Dec 05, 2013 | Singer 7422
Singer 7462 will not pick up bobbin thread
You need to adjust the needle timing - called "timing the needle".
How do to that is usually included in the service or repair manual for your model of machine. There are various online shops where you can order this.
Also, the machine is pretty similar to the Single 7422, and there's an ehow article on how to adjust the timing on that model that you might find useful.
http://www.ehow.com/how_7799647_adjust-singer-7422-sewing-machine.html
Dec 01, 2013 | Singer 7462 Mechanical Sewing Machine
Top thread will not pick up bobbin thread on my model 7422
try a new needle--make sure it's the right needle for the fabric
being sewed.
try rethreading the machine top and bobbin --make sure to use
every thread guide
try a different bobbin
it's also possible that the machine could have a timing problem
and needs to be checked
here's a free manual if you need one just click on the link
http://www.singerco.com/uploads/download/f3eff19dd0b1966512ad6a6bd24e3d8a74926fca.pdf
Dec 06, 2012 | Singer 7422
7422 singer will not pick up the bobbin thread
try changing the needle
rethread the machine top & bobbin
use every thread guide
here's a link for a free manual
http://www.singerco.com/uploads/download/465_7442_efs.pdf
if these suggestions don't help then it's possible that the machine could
be out of time
Apr 22, 2012 | Singer 7422
Bobbin tension is too loose
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Dec 08, 2008 | Singer 7422
Singer advance 7422
My Singer 7422 seems to be jammed. When I start to make a stitch, the thread from the needle gets caught on something on the bottom and the thread goes over the bobbin.
Jul 16, 2008 | Singer 7442 Mechanical Sewing Machine
Bobbin case turns in its place
You need to remove the needle plate and take out the bobbin case. Examine it for any rough spots, scratches or burrs. When you find them, you will need to remove them with an emery stick and then buff it with very fine steel wool. Reinstall the bobbin case and the needle plate. Put the bobbin in the machine so that it turns counter clockwise when you pull the thread. Rethread the top of the machine and change the needle. Hold the needle thread , turn the handwheel and see if the bobbin thread is picked up without snagging anyplace. If it's okay, sew away.
sewman7
Jul 14, 2008 | Singer 7422
Singer 7422 Logo
335 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
