Question about Technics SA-DA8 Receiver
Where's the fuse on my technics model sa-da8 reciever
SOURCE: I have a Technics SA-GX190.
My dear friend the cause are the audio amplifiers IC's are damaged.
Posted on Jun 01, 2008
SOURCE: Technics SA DA20
I have a Technics SA DA20 control receiver. I was given it by an electronics workshop and it has this same error of OVERLOAD coming into the display when switched on. I removed the plates from underneath and re-soldered as far as I could all the points along the stereo amplifier ICs and as far as access would allow. The unit then worked normally for several hours. I was very pleased, and went out shopping!. But on my return after it had been off for about an hour, the same problem has come back. But my boss at the electornics workshop thinks it it just a dry joint, or series of dry joints. The unit is complex to dismantle, so patience and care is required in taking it apart and making a note or diagram of how it comes to pieces and how to re-assemble it after the board has been re-soldered. It does not appear to be a component problem or fault with the SVI power amplifier ICs.
petertaussig33@hotmail.com
Posted on Jul 13, 2009
  • 118 Answers
SOURCE: I have a technics reciever - model SA-GX670 --
depends on whether it works or not
Posted on Nov 03, 2009
SOURCE: Sa-da8 overload and off
I had the same problem. What I did was hard wire the fan so it runs whenever the unit is on. I had the reciever set for low impedance, when I turned this off all works fine. (Low impedance is only for speakers with an impedance of 6 to 8 homs or less)
Posted on Feb 21, 2010
  • 4 Answers
SOURCE: technics sa-gx670 reciever sound drop
it could be that your amp chips are gettin hot
Posted on Jul 23, 2010
Tip
Keeping your SA-DA8 cool
When I first bought this I noticed that it runs very hot even on low volume levels. I took it in for repair and told the tech that the fan didn't come on even when hot. He said "works as designed - the fan is output-power-driven, not temperature driven."
Wishing to prolong the life of ma SA-DA8, I used an old computer power supply and muffin fan. Plugged the PS into the controlled AC output of the amp, and the fan into the PS. Jumpered the "power-on" pins of the PS. Laid the fan on top of the amp, padded with some foam tape, and it now stays a lot cooler (and the fan is very quiet, though not silent.)
on Nov 05, 2011 | Technics SA-DA8 Receiver
My Technics SA-GX100 Reciever worked for a minute, but when i set it up with all the speakers and attachments, it says "muting". i dont have a remote, so how do i UNMUTE it?
According to my Technics SA-R210 manual to UNMUTE without the remote....do the following......PRESS BOTH THE VOL UP & DOWN CONTROLS & THE LOUDNESS SWITCH ON THE UNIT AT THE SAME TIME......Not sure it will work for your model but that is what it shows for The Technics SA-R210 model, so it should be pretty much the same
Sep 04, 2010 | Technics SA-AX720 Receiver
I want to buy a Technics SA-DX940 reciever
ebay cheap as chips just keep your eye out for them there always about look for the sa-ax730 aswell more or less the same
Jul 23, 2010 | Technics SA-DX940
Sound just stopped all of a sudden .....unplugged it for 30 secs still did not work....fan was on but it felt a little hot on top
Power amp output IC have an overheat. Cool it down and restart at
low volume. Send your e-mail if this did solve your problem.
Sep 25, 2009 | Technics SA-DA8 Receiver
SA8 5.1 receiver overload comes on with no sound
Try checking your fuse if it overloaded then it probably blew it
Oct 22, 2008 | Technics SA-DA8 Receiver
Be sure that the EQ settings aren't accidentally putting you over the top as far as demand is concerned. Bass-heavy material? Same conditions apply...accordianman
Jan 21, 2008 | Technics SA-DA8 Receiver
Sa-Da8 Overload and power off
you mite be pushing too much power, try unhooking a few speakers or check the wattage cuz that mite be your problem
Jan 12, 2008 | Technics SA-DA8 Receiver
Technics SA-DA8 Receiver Logo
65 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
