Question about Teac PD-H300 CD Player
The CD drawer refuses to open when I push the open button.
I know this sounds a little brutal for what is after all is a delicate piece of hi-fi; I've just fixed mine by turning it upside down and giving it a good shake, knocking the underside a couple of times. The tray jumps out of its guide track, you're just shakin it back in.
Posted on Feb 18, 2011
Brilliant advice. Just sorted out my Teac cd player which had exactly the same problem. Thanks Neil!
Posted on Apr 04, 2015
I just wiggled the tray up and down a few times when closed and it opened. I had the same problem as you with it not opening.
Posted on Apr 06, 2013
Thank you, Neil. I was just about to bin this CD player, having been told by John Lewis that it would cost more to repair than it was worth. It really works!
Posted on Apr 02, 2013
The display flashes "closed" and I can't open the cd drawer when pressing the open/close button. Is there a reset please ?
Try removing power from the unit, let it set two minutes without power and power it up again. See if the problem continues.
Make sure the cd drawer is complete closed and flush with the front panel. If not, something could be stuck inside.
Turn off power and remove cord from wall for next step:
There is a small hole generally on the flat face of the cd drawer through which a bent straight paper clip can be pushed gently until you hit a mechanical stop. Pushing slightly harder at this point should cause the cd drawer to move open mechanically. Gently pull the cd drawer open until you can remove any CD still inside.
Gently push the drawer closed again and restore power to the unit and see if the problem returns.
Would be nice to have manufacturer and model number of the CD player.
Apr 08, 2015 | Audio Players & Recorders
NEW LAPTOP CANT OPEN CD DRAWER, WHERE THE HELL IS THE BUTTON, IT SEEMS STUCK.
When first powering on this laptop, you should push the button on the left side where the CD/DVD drive is located. You should also push F10 to stop it from loading an OS and it will enter into bios where the CD tray can be opened.
Feb 24, 2014 | Compaq Presario X1000 Notebook
Opening cd player
What about opening the cd player?
Are you saying the cd drawer will not open when you push the button? If so, try the steps below.
Take a paper clip (Gem Clip) and straighten it out then get in front of the cd drawer where you place the cd. Look for a small tiny hole on the drawer and insert the paper clip (Gem Clip) into the tiny hole and push it in while you press the button on the drawer. Don't worry about breaking something, use a little force to push the paper clip in, that's why that hole is there.
May 31, 2012 | Samsung Computers & Internet
Cd tray tries to open butacts like its stuck
Take a Norwegian paper-clip.
Straighten one end.
Insert that end into the small hole in the faceplate of the CD-drive, until you feel resistance.
Push it another 1 centimeter (1/4 inch) against the resistance.
This will "unlock" the drawer.
Push the open/close button, to fully open the drawer.
Remove any CD disk.
May 09, 2011 | Computers & Internet
Five discs keep spinning; will not stop. Cannot open drawer
they button maybe stuck or the switch that open the cd player sticking try to push button to open then pull on drawer not to hard u brack then see if u can clean swith
Mar 22, 2009 | Sony CDP-C445 5-Disc CD Changer
CD door will not open. Does not respond to the open close button. Cd is incside player. Was put in correctly. How do I open cd drawer without breakin it.
the cd drive should have a tiny hole under the drawer. push a small screwdriver into the hole and it will release the drawer.
Mar 16, 2009 | Aiwa Audio Players & Recorders
Dell Modem CD Drawer Won't Open
Yes. There should be a very small hole on the front of the CD/DVD drawer. Insert a straightened paper clip into this hole until you feel it push a button, and this should manually release the drawer.
Nov 05, 2008 | Computers & Internet
Cdr20 drawer is jammed ERROR message
Try taking the unit apart it mostlikly jamed or jumped track try re ajusting it that would prob work, another thing is to try messing with the gears that could aslo work
Oct 18, 2008 | Harman Kardon CDR20 CD Player
CD problems
hi you push the button and it dosent work? maybe the button went bad push harder pull the button out ( if possible) and push with something small and hard you hear anything after you push? if soo then the drawer is stuck or the engine is about to die (not enough power to open the drwer) take a flat screwdriver and shove it (gently) between the carack of the drwer and try helping the drawer out maybe a plastic wheel will brake from this soo be careful in the end these system are ment to start dying after 5 years soo if this is the case sorry wont do any good have a good one
Mar 26, 2006 | Sony CMT-HPX9 CD Shelf System
Teac PD-H300 CD Player Logo
568 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
