Question about Acer Aspire 5315 Notebook
My screen has a horizontal line through the middle. And sometimes puts vertical lines from there down, and then you cant see anything. Is it the screen that needs to be replaced?
  • Acer Master
  • 629 Answers
Sounds like the LCD panel may need to be replaced. To further check it, try to test if the same issue happens when you connect an external monitor to the laptop. Also, go to the BIOS screen and see if the same line are showing. If no issues with external monitor and line also shows in the BIOS, it would confirm the issue is specific to the LCD of the laptop. If within warranty, you can refer to Acer for repairs and/or replacement. If out of warranty and in doubt, see if you will get other advise from other users, or have a local tech verify it, whichever works for you.
Posted on Oct 03, 2010
Red line down middle of television
Try putting a litte pressure on your screen where the red line is,if it goes away then check for a loose pin connection where that line was...
Sep 19, 2011 | Vizio P50HDTV20A 50 in. Plasma HDTV
When i turn it on it has an horizontal blue line in middle of screen then comes on, when shut down it has the colors in the middle in tight formation then suts off. is it the picture tube
the set having blue scteen when the nosignal condition so blue horizontal line due to failure in vertical deflection section and system control detect the vertical delection failure . so system control farce to set to shut down pls repair the vertical section and system should be ok
Aug 26, 2010 | Samsung SlimFit TX-S3082WH 30" TV
Horizontal lines across middle of screen sometimes
Vertical problem coming from bad solder, or vertical circuit problems!!!
Check for bad solder and capacitors problems in vertical circuit.
Aug 30, 2009 | Hitachi 60SBX78B 60" Rear Projection...
Erratic problem
need to have the vertical output IC pins resoldered.
Jun 13, 2008 | JVC AV-27730 27" TV
Insignia 32" Tube TV NS-RTV32
The vertical output IC LA7847 is failing. It will likely fail permanately and you will have just the horizontal line. The set will require service. Just do not run the set very long in this state. That thin white line can likely burn into the crt phospher and will show all the time thus ruining the glass picture tube...
Jun 05, 2008 | Televison & Video
No picture just line in middle of screen
Is the line across-vertical failure or up and down-horizontal failure.Don't have make/model of set.
Apr 27, 2008 | Televison & Video
Nopicture
No vertical deflection. Vertical output IC, caps.
Nov 25, 2007 | Televison & Video
Horizontal line across the middle of the screen
replace the vertical ic,when your vertical ic is defective you can see the horizontal line across your screen
Oct 19, 2007 | Gateway FPD2275W LCD Monitor
Mitsubishi cs-35401television
HORIZONTAL FAILURE AND LINE DOWN THE SCREEN. REPLACE T5A1 LOCATED ON PCC-3-PCB. PT#349P145030(FOR CS-35401,CK-35402 ONLY) Hope this helps! Troy
Sep 11, 2007 | Televison & Video
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
Acer Aspire 5315 Notebook Logo
131 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
