Question about RCA L32WD12 32 in. LCD HDTV
I have a RCA L32wd12YX7 it has red light on with power to it but no green power when press power button on and no picture comes on.
    New Friend:
You have to press AND HOLD the power button for several seconds to turn this type of TV on.
Posted on Jan 21, 2013
4 Suggested Answers
rulds2008
  • 3866 Answers
SOURCE: Polaroid 4011-tlxb. Power to tv and it was turning
if you replaced the supply board then there is issues with the decoder board as you would need to chec kthat and see if its not the issue.
Posted on Sep 22, 2009
budmrtn
  • 11361 Answers
SOURCE: No picture; dark screen. Red light turns to green
I would check output voltage of the power supply first to make sure that you do have DC 5v, 12v, and 24v. If you do then the problem can be in the inverter board. The inverter board also has a couple surface mounted fuses on it. You can check www.shopjimmy.com for parts.
Posted on Jan 05, 2010
ginko
  • 19396 Answers
SOURCE: I have an RCA L32WD12YX7
Hi.
Unless there is a determined flashing pattern, the light switching from red to green, then back to red, indicatest simply that there is an internal fault; that the incorrect voltage has been detected, and that the TV has been forced to stand by to prevent further damage.
After you click several times the TV turnson: This is common. Depending on what component is damaged, the TV may overcome the problem once a determined circuit has fully discharged; when a circuit is fully charged and stabilized, or even erratically because of a bad soldering joint or wiring.
This kind of problem is commonly caused by PSU or inverter. This parts use big charge reservoirs (the capacitors) to store charge. When one of the capacitors is faulty, the other parts in the circuit can compensate for a certain time the problem, allowing startup. The problem will get worsening in time as components in circuit will go will start blowing soon. The result will be a TV staying in forced standby and not starting.
Parts must however be tested before replacement. Even if PSU is more common problem, there are more parts that may need testing. In this particular model SMPS must also be tested.
If power supply stages are OK, testing will follow on digital board, inverter and other parts.
Since the TV is occasionally starting, voltages may be OK. Testing will start at component level in this case.
Repair must be done by a trained technician.
If you need to contact a technician, or if you want to verify warranty status, please contact the RCA phone number listed in the user manual.
Here parts for this TV
See also Contact - RCA Television
Posted on Nov 10, 2010
I have a RCA 32" Flat Screen TV that shut off and
The sound was came from the clicking of the relay. This kind of symptoms is an indication of out-of-regulation condition on the power supply section. This is caused by faulty electrolytic capacitor. It will dropped the supply voltage and will trigger that kind of symptoms.
Faulty electrolytic capacitor mostly has a physical indication of fault like bulged/dome at the top and can be easily identified. See sample picture of faulty electrolytic capacitor below.
capacitor with bulged/dome at the top.
Check these parts on the power supply section. Once found, replaced it with same capacitance and working voltage which is printed on its body itself. Click this LINK for more info regarding electrolytic capacitor.
If you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to look for a qualified TV Technician to isolate the faulty parts.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 05, 2011 | RCA L32HD31 32 in. LCD HDTV
I have a problem with getting the tv started (power on). When we first got the tv 5 years ago it would not start with the global power on button on the remote. We would have to move the botton on the...
Most likely you have the problem in the power supply. In most cases you can actually see small capacitors swollen . IF you replace these with new ones your problem will likely be solved. It does require soldering.
Feb 21, 2011 | RCA L32WD12 32 in. LCD HDTV
My Loewe Aconda TV will not turn on - buzzing noise.
My Loewe Aconda 81 HDR TV will not turn on. When I press the power button the green light comes on but the red light stays on with it and after a few seconds the green light goes out and the red light stays on. Any help please.
May 15, 2010 | Loewe Aconda ACO9383 38" TV
No picture, just a red blinking light
First make sure to hit the menu button on the TV's remote and if nothing is there then friend while the set is on turn a bright flashlight on and shine at angle into the set push the TV menu button if you can see a image then your back light is not working.
Cost backlights around 150.00 and power supplies around 100.00. Well this should help you friend.
Feb 07, 2010 | RCA Televison & Video
Tv will not turn on
I turn on tv green light comes on and gos off and no picture.
Feb 04, 2009 | RCA D52W19 52" Rear Projection Television
Rca d52w23 hdtv will not turn on
unplug it for about 10 minutes and then plug it in and try it
Jan 19, 2009 | RCA HD50LPW175 50" HDTV
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
RCA L32WD12 32 in. LCD HDTV Logo
532 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
