Question about Lexmark X5650 ALL-IN-ONE PRINTER
Install my Lexmark X5630 printer - Lexmark X5650 ALL-IN-ONE PRINTER
4 Suggested Answers
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: my lexmark x5630 has been showing paper jam but
    Hello. Try removing all sheets of paper from the printer. Make sure to check in the feeder by peeking inside it. Clear any foreign objects. Open the printer cover, and remove the cartridges. Clear any foreign objects around the cartridge carrier. Close the printer cover without the cartridges. Unplug the printer from the power outlet. Plug the power back after 10-15 seconds. It should power on automatically. When printer asks for the cartridges, load them back in. Close the cover down. Printer will print an alignment page. Just let it finish print the page. When there's no more error, try to make a copy or print from the computer to check. Hope this helps.
    Posted on Mar 17, 2010
    rcw1962
    • 2571 Answers
    SOURCE: ho do i install my lexmark x5630 printer ?
    Yes it is, i dont know where you looked, but it took me 10 seconds to navigate to the drivers.
    http://support.lexmark.com/index?locale=en&segment=DOWNLOAD&startover=y&userlocale=EN_UK&question=x+5630&productCode=LEXMARK_X5630&page=answers&detectedProductFacet=CMS-CATEGORY_REF.LEXMARK.PRODUCTS.ALLINONE.LEXMARK_X5630&searchid=1280157230301#2
    Posted on Jul 26, 2010
    SOURCE: My Lexmark 4 in 1 X5630 printer is saying carrier
    I got an amazing solution to this problem that worked for me.......my printer is working now :)
    just sharing with you............
    "Someone tried for hours to reattach my encoder strip, and finally figured out the way to do it after reading many web postings, and my own trial and error. The key is to use a "dental mirror" that you can pick up at a pharmacy or hardware store for about $5. (Perhaps a small compact mirror may also work.) And you need to focus light back there. (I used a head lamp.) The problem is you just can not see the small slot through which the encoder strip must be threaded from the front of the printer. It sits in back of the ink cartridges. This thin slot "tunnel" goes though a rectangular piece of plastic. You can feel the rectangular piece of plastic in back of the ink cartridges, and looking with the dental mirror you can see how small the slots are on the right and left side, through which the encoder strip must be threaded. After "seeing" these small slots using the dental mirror, you then can feel them with the tip of a fingernail, and know exactly what you are aiming for as you then feed the encoder strip through. (It doesn't make any difference of you feed the strip from the left or the right, but the down arrow end of the encoder stip must end up on the right when you later attach it to the wire tab.) I fed the strip "blind" after I had formed a strong mental image of exacly what I was trying to do, and now being able to feel the small slot I was aiming for with the tip of a fingernail. (It is tough working in the small space in back of the ink cartridges, and if you have really big hands and fingers it may be impossible. I did not want to use forceps or tweezers because of a fear of damaging the encoder strip.) The encoder strip then must be attached with the down arrow end on the right attaching to a flimsy looking wire on the right side of the printer. The left end of the encoder strip must be attached to a metal tab on the left side of the printer. You will need to hold tension on the encoder strip, and manually push the sliding ink cartridge back and forth out of the way as you attatch both ends. (It's probably a good idea to gently clean the encoder stip of all your fingerprints and any smudged ink with a tissue after you get it back in place. Also be sure to clean the metal bar the ink cartridges slide back and forth on, so you don't get error message 0502.) Be prepared for this to be a very frustating experience! You will be maddened by how many times it will take to thread the encoder strip though the slot, how difficult it will be to catch the end of the encoder strip on the wire and metal tabs, and how you will have to figure out how to hold tension on the encoder strip so one end won't fall off as you attach the other end. But once you use the dental mirror to see where you have to thread the encoder strip, and once you see the wire and metal tabs to which the ends of the encoder strip must be attached, then YOU CAN DO IT! It just takes persistance."
    Posted on Jul 28, 2010
    My Lexmark X5630 does not switch on, what can I do?
    1 Press to turn the printer off. 2 Disconnect the power cord from the wall outlet. 3 Gently remove the power supply from the printer. 4 Reconnect the power supply to the printer. 5 Plug the power cord into the wall outlet. 6 Press to turn the printer on.
    Make sure the cord on the back of the printer is pushed all the way into the socket, it should only fit one way. If that fails, check that there is power at the outlet you are using.
    Sep 08, 2017 | Lexmark Office Equipment & Supplies
    Memory info retrieving from lexmark x5630 fax machine
    Usually, faxes are temporarily sent to the printer's memory when one of the cartridges' ink level is not substantial for printing at the instance of receiving the fax. When this happens, try to replace the cartridge(s), *without navigating away from the message "fax sent to memory", by opening the printer cover and replacing the low-ink or empty cartridge(s). After the new cartridge is installed, close the printer cover and press the OK button. Your printer should then print the fax stored in the memory.
    *Make sure not to navigate away from the "fax sent to memory" message, otherwise, data will be lost.
    Dec 30, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
    Hi I have refilled my Lexmark X5630 , BUT IT STILL SHOWS THAT THE CARTRAGE NEEDS TO BE FILLED ;PLEASE ADVICE
    Lexmark does not recommend the use of refilled/remanufactured cartridges. They tend to degrade print quality and printer/cartridge performance.
    Note that once a cartridge is refilled, it can no longer register its ink level.
    Aug 31, 2011 | Lexmark X3650 Printer
    I have a lexmark x5630 printer. Since last week whenever i try to photocopy a document, it only copies 1/4 page, not the full page.I have tried to change the "Resize" or "Size" but...
    If you're using the Lexmark X3650 printer, try to reset the printer to its Default Factory Settings. Please follow the steps below:
    1. On the printer operator panel, press Setup button.
    2. Select Defaults.
    3. Select Set Defaults.
    4. Select Use Factory.
    Then try to make a copy again to verify that the problem is fixed.
    Aug 22, 2011 | Lexmark X3650 Printer
    I get "Access is denied"
    Log in as administrator. You may have to enter safe boot to do this. If the installer won't run in safe mode, go into the Accounts control panel and give yourself administrative privileges. Be sure to set your account back after the printer is installed - it is easier for evil software to corrupt your computer if it is run under the account of an administrator.
    Feb 08, 2011 | Office Equipment & Supplies
    How do I install my lexmark X5630 into my computer
    To install Lexmark X5630 you need to drivers/ software which you can download from Lexmark Official Support for X5630
    Visit the above link, select the Operating System (OS) to get the drivers. After downloading the
    drivers file, double-click the file to run it and follow the on-screen instruction to install the printer drivers/ software
    Let me know if any further clarification/ assistance is required.
    Good Luck!
    Appreciate generously, if the solution could have been of any help!
    CreativeTECH
    Jan 10, 2011 | Lexmark (12T0157) Print Server
    Lexmark X5650 ALL-IN-ONE PRINTER Logo
    252 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
