Question about Panasonic PanaFax UF-8000 Laser Fax
Paper struck sir, 5-6 paper is printing smoothly 3-4 times but after next step when i give the print command if stucks middle near fuser unit,what is the reason for this
    Sergeant:
  • 284 Answers
One- dont ever do a shipment set unless its a very last resort and that would not fix the fuser problem.
two- have you tried changing the toner cartridge that could be the problem
three- what error codes are you getting when the paper jams
good luck
Posted on Sep 10, 2008
    Genius:
  • 2,120 Answers
Fusing rollers are not turning, Grease the bushings / bearings.
Perform Shipment Set.
Posted on Aug 28, 2008
When print command given to printer a screen appeared that fix unit error code E000 0000 every time .so give solution
good day sir.this a fuser temp error. These units are notorious for having fuser temp errors when there is dirty or unstable power, especially if the customer is running off a generator. the best way to fix this is to replace or rebuild the fuser assembly. goodluck!
Apr 25, 2011 | Office Equipment & Supplies
Error code 6A00
Step by Step troubleshooting canon pixma MP800 error code 6A00
The Problem Canon PIXMA MP800 Error 6A00
1. The print head cartridge keeps locking itself up on the right hand side.
2. Frequent 5100 errors even when the printer is on standby
3. Even when I wipe up the print cartridge, the next print will
mess up the bottom of the print cartridge with ink again.
Step for troubleshooting canon pixma MP800
1. Opening the cover and wait for ink carriage to center
2. Pull out power cord
3. Pushed carriage to far left (should slide easily)
4. Used paper towel and wiped purge unit a lot of times
(press down to soak paper towel with ink). Repeat until the paper towel is relatively clear.
5. Used diluted napisan (oxygen-based cleaning agent in the
ratio of 1:3 with powder:water) and soaked paper towel
6. Repeat step 4 with wet paper towel. Repeat until purge unit is near-white.
7. Pulled and pushed clear plastic wiper (north of purge unit) and wiped it down
8. Slided carriage back to original position
9. Removed Print head cartridge and wiped out excess ink stuck on bottom.
Mar 01, 2011 | Canon PIXMA MP800R All-In-One InkJet...
Error code 6A00
Hope this helps.
Feb 10, 2011 | Canon Pixma MP800 All-In-One InkJet...
Several sheets entered the printer at the same time and stuck. can't pull them forward or backward.
Step 1 Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
Step 2 To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
Step 3 For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
Step 4 Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
Step 5 Try printing another document
Jan 13, 2011 | HP PSC 1600 InkJet Printer
Error code 6A00 shut down machine. How do you fix it?
Oct 26, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Printing on a customise continuose paper
Check the printer settings about page length by the procedure given in the user manual.
If OK check your software if it is giving soft commands to adjust paper lengths.
Sep 28, 2009 | Epson LX-300 Matrix Printer
Ghost printing
Hi for ghost printing basically it is
1)fuser roller surface wear n tear
2)check any fragment of paper stuck at the fuser unit.
3)fuser unit is located near the printing output.
Sep 05, 2009 | Canon imageCLASS D761 Copier
Carriage jam on hp photosmart printer
The print carriage may get stuck on either side or in the middle of the printer. The Carriage Jam: Open Door, clear carriage jam, and then press OK to continue error message may display on the front panel of the all-in-one.
Solution
The print carriage is the device which contains the print head and moves left to right during printing.
Figure 1: Carriage Assembly
To resolve this issue, follow the steps below in the order presented.
Step one: Print a Self Test
Follow the steps below:
1. Press the Setup button.
2. Select Print Report and press OK .
3. The self-test page should print. If it prints a test page, there is no need to follow the remaining steps, as the error message may be false. Make sure the printer now prints from the computer (if installed on one). If it does not print, proceed to the step two.
Step two: Clear the paper path
Follow the steps below to clear the printer of any jammed paper and reset the printer.
1. Leave the printer on and then disconnect the power cable and the USB or Ethernet cable from the back of the printer. Do not reconnect them until instructed to later.
NOTE: Make sure the printer is on before disconnecting the power cord. Failure to disconnect the power cord from the rear of the unit can cause damage when removing jammed paper.
2. Open the top access door.
Figure 2: Opening the top access door
3. Make note of where the carriage is stuck and look for jammed paper. A paper jam can cause the error message and the carriage stall. Some paper may be jammed in different locations than those shown in the photos below.
Figure 3: Paper jammed on the left side
Figure 4: Top view of paper jammed on the left side
Figure 5: Paper jammed on the right side
Figure 6: Top view of paper jammed on the right side
NOTE: Do not use any tools or other devices to remove jammed paper. Always use caution when removing jammed paper from inside the unit.
If the carriage is stuck on the right side:
a. Check for any paper or object that may be restricting the carriage.
b. Move carriage all the way to the left side.
c. Check the paper path all the way to the right side and remove any paper still in the printer.
If the carriage is stuck on the left side:
d. Check for any paper or object that may be restricting the carriage.
e. Move carriage all the way to the right side.
f. Check the paper path all the way to the left side and remove any paper still in the printer.
If the carriage is stuck in the middle:
g. Check for any paper or object that may be restricting the carriage.
h. Move carriage all the way to the left side.
i. Check the paper path all the way to the right side and remove any paper still in the printer.
j. Move carriage all the way to the right side.
k. Check the paper path all the way to the left side and remove any paper still in the printer.
4. Remove the rear access door or duplexer (if installed) from the back of the printer.
5. Check for and remove any paper still in the printer.
6. Replace the rear access door, and close the top access door.
7. Reconnect only the power cable. If the printer does not automatically turn on, press the Power button.
NOTE: The printer may go through a warm-up period of up to two minutes. Lights may flash and the carriage may move. Wait until this warm-up period is complete before going to the next step.
8. If the Power light is on steady, print a self-test page as done in Step one.
If the Power light is not on steady and the carriage is still in a stalled position, proceed to the next step.
Step three: Plug the printer directly into a wall outlet
Verify that the printer is properly connected to a suitable power source by following the instructions below.
1. Verify that the computer and the printer have a three-prong power plug.
2. Remove the printer cable from any power strips or surge suppressors, and plug it directly into a grounded (three-prong) wall outlet.
3. Try the print job again to see if this step resolved the issue.
NOTE: If the printer prints when plugged directly into a wall outlet while disconnected from any power strips or surge suppressors, the power strip or surge suppressor may not be allowing sufficient voltage to reach the product.
4. If this did not resolve the issue, proceed to the next step.
Step four: Service the product
If you have completed all of the steps listed above and are still experiencing a problem, service your product.hope this helps
Jan 05, 2009 | HP Office Equipment & Supplies
Paper stucking
most times when this machine starts jamming at the fuser, it is time to replace the fuser,
May 28, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Brother HL-5250DN printer paper light won't go off
I had the same problem on 4 Brother HL-5250's, I checked the whole printer, and couldn't find a paper jam, yet the red printer light wouldn't shut off. I finally followed the instructions on Brother's website for removing a paper jam, and the solution for all 4 printers was paper stuck in the fuser cover. See below on how to open the fuser cover.
Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
  2. Hint
  3. There are 2 kinds of covers at the rear of the printer. Please make sure to open both the back cover (step 7) and the fuser cover (step8).
Here's the link from HP, on how to open the Fuser Cover.
http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faq/000000/000000/000026/faq000026_007.html?reg=eu&c=eu_ot&lang=en&prod=hl5250dn_all
Oct 05, 2007 | Brother HL 5250DN Laser Printer
Panasonic PanaFax UF-8000 Laser Fax Logo
78 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
