We have a rth2310b thermostat and it was saying filter on the screen and we changed the filter but it still has that filter word on the sceen. Does this word stay there???
Press and hold the "Filter" button on the thermostat for 3 or 4 seconds. That should turn off the filter indicator. After another 500 hours of operation, the "Filter" indicator will display again reminding you to change the filter. You see, it doesn't actually sense when you change the filter, it is simply an automatic reminder for you to do so. Hope this helps!
Posted on Jul 18, 2011
Honeywell rth2310b 5-2 day is not working. light stays on and buttons dont work, how can i fix it?
Honeywell has a help line They have access to all of their codes and understand your problem. Google them for the phone number.
Sep 01, 2014 | Honeywell RTH2310B 5-2 Day Programmable...
The temperature falls 3 or 4 degrees below the set temperature before furnace kicks on
There is a Span setting on the thermostat causing that, most newer thermostats have a adjustable span from 1 to 5 degrees, if your thermostat has a option menu, scroll through the options and see if you find a option called Span if its at 3 or 4, change it to 1 or 2, then your furnace will cycle on sooner. If you have your owner manual still for it that should show you how to do it.
Nov 18, 2013 | Honeywell Rth2310b 5-2 Day Programmable...
Rth2310b not keeping tempeature set for heat
Not maintaining the set temperature is not always a fault of the T-stat. I'm not sure about what you're saying because there could be a problem with the other parts of your unit. Remember, the T-stat is only a switch, but look at any of these anyway
Nov 09, 2013 | Honeywell Rth2310b 5-2 Day Programmable...
Rth2310b wiring
More than likely, this is what you have:
Red- Power- (RC/RH)
White- Heat- (W)
Green- Fan- (G)
Blue- Cool- (Y)
Usually, the only times you need more than 4 wires are:
1. You have a HeatPump system.
2. Your new digital thermostat does not use batteries, which then you have to have a common wire to power the thermostat.
May 26, 2012 | Honeywell Rth2310b 5-2 Day Programmable...
Installed a RTH2310B to replace an older model honeywell. All wires do not match. only 3 do r, w1, and g do and o and e do not. what should i do?
The Honeywell RTH2310B is a standard thermostat and is not compatible with a heat pump system. The terminals O and E are for a heat pump system. I am assuming that the terminals you described that do not match are from the old thermostat. What you will need to do is get a heat pump thermostat. Sometimes it can be hidden within a lot of other descriptions on the front of the box, but it will say heat pump and either 2 heat/1 cool or 2 heat/2cool. You should just need the 2 heat/1 cool heat pump thermostat. Hope this helps.
Aug 17, 2010 | Heating & Cooling
Connecting New thermostat with two existing red and white wires
sounds like a heat only system,not all stats work heat only make sure it will(should say on packing)
Dec 02, 2009 | Honeywell Programmable Thermostat Heater
PB on Imac sceen
I just looked at my System preferences, In the one for desktop, there is a little box that says 'change picture'. Make sure to un-check that box.
Mar 13, 2008 | Apple iMac G5 Desktop
Heating & Cooling Logo
73 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
