Question about Acer Aspire 6930-6771 Laptop
My wireless is disconnected. It says" my button for it is on the side or front of the computer." There is no such button-how do I turn on the icon on the panel?
  • Acer Master
  • 629 Answers
Try going to the network properties through the control panel, then right-click your wireless connection and click Enable. If it is enabled already, right-click it and click Connect.
Posted on Oct 03, 2010
Turning on wireless
Maybe you don't have your wireless turned on. Look onboth sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can togglethe wireless on or off. Normally you would Press and Hold the FN functionkey located at the lower left of the keyboard, then hit the correct F1 thru F12key that toggles the wireless. The correct F1 thru F12 key to hit willhave the wireless signal icon )))) on it. Or it might have the icon of a towerwith the wireless signal icon )))). Normally the screen will displayWireless On or Wireless Off when you toggle the wireless.
On some laptops there will be a button just above the keyboard or on the side or in front of the laptop..
Jun 09, 2012 | Toshiba P000413700 QOSIMO G10 G15 SERIES...
Knocked my msi u135DX off table, now my wireless will not turn on and off using fn and f11, any ideas how else i can get it on? please
On some laptops there might be a button above the keyboard or on the sides or in front of the laptop to press to turn the wireless on.
Jun 04, 2012 | Computers & Internet
How to switch on wireless connection on the msi s420
On some computers there might be a button above the keyboard or on the sides or in front to press to start the wireless.
Where do i find the wireless connection button on a vaio
Some laptops don't have wireless buttons. You toggle it by the keystrokes described above. If there is a wireless button it will be located above the keyboard, on the sides or in front of the laptop.
According to your manual, the wireless switch is on the side of the laptop. See page 15 of the manual. I have provided a link below for the manual.
http://www.docs.sony.com/release/VPCEC3_series.pdf
Jun 03, 2012 | Sony VAIO VPCEC3CFX/WI 17.3 LED Notebook -...
Lost wireless capability
Why is there no lan? Did you somehow turn the wireless off? Are other computers able to connect to the wireless if so that means your wireless is probably off.
Maybe you don't have your wireless turned on. Look on both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
Some laptops will have a button to push that toggles the wireless. it might be located on either side or front or just above the keyboard.
If no other computers are able to connect then go to the wireless router and unplug it for 30 seconds, then plug it back up. If you have a modem and a router, you only want to unplug the wireless router.
Jun 03, 2012 | Acer Aspire Z5600 PC Desktop
Wireless capability won't turn on
Make sure you Press and Hold the FN function key then hit the F2 key.
Some laptops might have a wireless button instead of a wireless switch located above the keyboard or on the front or sides.
Jun 02, 2012 | ASUS K40IN Notebook
Where do I find the wireless button on an IBM thinkpad X31?
Some laptops don't have a wireless button or switch. If that's the case they control the wireless by keystrokes. Look onboth sides and in front for the Wireless Switch and turn it on. Look on both sides and in front for a wireless button. Look just above the keyboard for a wireless button.
Jun 01, 2012 | Computers & Internet
I can't find the wireless switch on dell latitude e5500
Go to the start menu and click where it says run or type in right above the start button in the white field and type ncpa.cpl then push enter. Where it says wireless network, right click on it then click enable. If needed, right click again and view wireless networks or Connect/Disconnect then connect to the wireless network. Also there could be a tiny switch on the right side of the computer where you turn on the computer, there might be a button to click to turn it blue. Hope this helps
Sep 30, 2010 | Dell Latitude E5500 Laptop
The wireless icon on top of the computer is marked with amber light (Deactivated). I would like to switch it on again, but don't remember how. The HP support says 'activate the wireless button' on the...
There should be a little button on the front or side of the computer to turn on the wireless adopter on the computer it usually have the wireless symbol next to it. You should check again and carefully because all modern laptops has one, the symbol look like this.
Aug 16, 2010 | Computers & Internet
Wlan is disconnected. How do I get it conected please. Thank you Julie
If it is showing that it is "Disconnected" that simply means you are not connected to a wireless network. To connect to a wireless network simply double click on the wireless icon by the clock (bottom right side, looks like a computer monitor with waves) and select the wireless network you wish to connect to.
Oct 21, 2009 | Acer Aspire 5315 Notebook
Acer Aspire 6930-6771 Laptop Logo
27 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
