Question about Maytag MMV5165 Microwave Oven
Neither the display or oven operate. I look this problem up in the manual and had already tried all of the suggestions and none of them worked. I plugged other appliances into the outlet the microwave is plugged into and they work. I plugged the microwave into another outlet and it doesn't work. I left it unplugged to several minutes and plugged it back it, It still doesn't work. This is the second time it stopped working today and after flipping the circut breaker the first time it worked but that hasn't helped the second time.
    President:
  • 2,777 Answers
It sounds like this microwave has control unit (an actual board inside the microwave) problems... it sounds like the control board is starting to fail for sure. There is no simple fix for this and installing a new board is quite difficult if you've never done such appliance repairs before.
Let me know if you want to attempt it yourself and I will try to locate the part for you.
Thanks Tim
Posted on Oct 03, 2010
3 Suggested Answers
SOURCE: The power is not on anymore.
It ended up being just a $2.50 fuse. Thats all. Glad I didn't have to pay someone $80 to walk through the door and tell me that. Don't you hate that!
Posted on Mar 24, 2009
heatman101
  • 43501 Answers
SOURCE: microwave oven powered off during
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ';';
Posted on Apr 22, 2011
Am looking for a operation manual, where can access/
[PDF]Operating Instructions - Panasonic
service.us.panasonic.com/OPERMANPDF/NNSN797.PDF
Panasonicreduce the chance of injury, and tell you what can happen if the instructions ... Thank you for purchasing a Panasonic Microwave Oven. ..... m Warning Label ...
Free Microwave Oven User Manuals ' ManualsOnline.com
kitchen.manualsonline.com > Kitchen Appliance
Free kitchen appliance user manuals, instructions, and product support information. Find owners guides and ... Agilent Technologies Microwave Oven Manuals.
[PDF]Owner's Manual - GE Appliances
products.geappliances.com/MarketingObjectRetrieval/Dispatcher?...
oven surface when the microwave oven is in operation. ? Do not ... cooking time. ? See door surface cleaning instructions in the Care and ..... Foods calling for a dry lookor crisp surface after ... changed. Press and hold the AM/PM pad.
[PDF]MICROWAVE OVEN - Whirlpool
www.whirlpool.com/.../Use%20and%20Car...
Whirlpool Home AppliancesRead all instructions before using the microwave oven. ... If there is any damage, do not operate the microwave oven ..... Microwave oven door looks wavy. ?.
Jan 04, 2016 | Microwave Ovens
Can't get out of demo mode Westinghouse oven WVE916SA!
DEMONSTRATION MODE – PROGRAMMABLE CONTROLLER MODELS
For display purposes, the appliance has a demonstration mode to enable demonstration of oven functionality without consuming power. In demonstration mode, the display, the light and the fan only are operational.
When the appliance is in demonstration mode and the display is switched on, the clock symbol will be on.
If the appliance is in demonstration mode, to operate the appliance normally the demonstration mode will need to be deactivated.
To deactivate demonstration mode:
1. Ensure the oven is off by pressing the ON/OFF button. 2. Press and hold the ON/OFF button until the display turns
ON then OFF and a single ‘beep’ is heard. Immediately after press and hold the ‘Timer’ and ‘–’ buttons simultaneously, until a triple beep sounds to confirm
the operation.
Nov 15, 2013 | Microwave Ovens
Just purchased our Cuisinart Stainless Microwave, plugged it in, read the operational instructions and set the clock. As a test, we tried to heat water....does not work. Any suggestions?
Yes! Take it right back to the store for exchange, cause could be a bad magnetron "that heats food" and a couple parts that work together with the magnetron,or there may be issues with the keypad, none of these will be cheap to fix.
Jan 30, 2011 | Cuisinart CMW-100 Microwave Oven
The display says Reset but none of the buttons will work.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If it still won't work, you probably have a bad keypad.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Aug 19, 2010 | GE JE1540 Microwave Oven
Samsung Microwave Oven shows -SE- on the display. Why?
-SE- error means you have a shorting membrane keypad.
Since it's less than one year old, it would be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
You can find your nearest Samsung-authorized service center here or call Samsung's Service Division at 800-932-3837.
Jun 14, 2009 | Samsung Microwave Ovens
We have a GE Spacemaker 2.0 Over-The-Range Microwave Oven. It has power, and the keypad display appears to be normal at first glance. None of the keys or buttons are operational, however. In all...
You can download GE owner's manuals and installation instructions here.
You will need your model number, which will be something like JVM1840WH01, etc.
You may need a hard reset. Unplug the unit for a minute or so then try again.
Aug 28, 2008 | Microwave Ovens
Microwave
Prototech@usa.com has links all over the internet advertising a simple fix for microwave displays. I ordered one and they never sent it. Had to file a claim with Paypal. No communication until I threatened them, then they said it's on its way. I waited another week and it sitll didn't come. After six weeks of trying to get my money back, I finally got a refund. Now I have to start all over. Any suggestions for replacing a display BESIDES this sham operation?
Aug 06, 2008 | Dacor DMT2420SS Microwave Oven
Kenmore Microwave 62622 display says "locked" and will not operate
hold your finger on the locked button till the light goes out
Jul 04, 2008 | Kenmore 62622 Microwave Oven
Maytag MMV5165 Microwave Oven Logo
102 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
