Question about Cub Cadet Op's Manual Model Lt1042 Lt1045 Lt1046 Lt1050
Front tire is off rim. Can this be fixed? - Cub Cadet Op's Manual Model Lt1042 Lt1045 Lt1046 Lt1050
    Brigadier General:
  • 3,911 Answers
Find a local lawn mower or small engine repair shop in phone book and take it to them.
Posted on Oct 03, 2010
2 Suggested Answers
SOURCE: craftsman 13.5 HP mid engine rider
ADD SLIME TO TIRE GOOD STUFF
Posted on Jul 06, 2009
Figure out why my car is wearing the outside of my tires . ihave to put new ones every 6 months
Too much toe in adjustment. The tires are pointed toward the center, I use an expandable retractable tent pole, with normal weight on the tires I check as high as possible without obstruction against the rim evenly front and back same distance from the ground and try to get as close to zero as possible. When there is the same amount of resistance without the length of the pole being changed when held against the rim on one side and brushed across the rim on the other end of the pole first checking the front of the front rim from side to side then the back of the front rim side to side you should see a great improvement in tire life if you have to lean one way or the other slight toe in is better than toe out. I try for zero running radial tires. Keep the pole level and straight as possible.
This should be done with the tires pointed as close to straight line forward as possible while the entire weight of the vehicle rests on the tires. I like to sight down the sidewall of the tire from the front of the vehicle looking toward the rear axle to determine if the tires are pointing straight. I measure adjustment against the rim to avoid differences in tire lettering. There are more ways to do this measuring but this is the only way to do it one manned that I know of without an alignment rack. The rim should be very true running when spinning on the spindle but even a bent rim can cause this method to be inaccurate. If a bent rim is all you have then you must just pick one spot on the rims and then rotate it to the front measure then to the rear then measure.
Feb 15, 2015 | Cars & Trucks
Front tire size?
With a tube type laced wheel:
WHEEL SIZE & POSITION = 21 in. - Front RIM SIZE & CONTOUR = T21x 2.15 TLA TUBE SIZE =Side Valve Tube MH90x21 TIRE SIZE = DUNLOP D402 MH90 - 21 54H
With a CHROME ALUMINUM PROFILE LACED RIM:
WHEEL SIZE & POSITION = 21 in. - Front RIM SIZE & CONTOUR = T21x 2.15 MT TUBE SIZE = Center Valve Tube MH90x21 TIRE SIZE = DUNLOP D402 MH90 - 21 54H
With a Tubeless Cast Wheel:
WHEEL SIZE & POSITION = 16 in. - Front RIM SIZE & CONTOUR = T16 x 3.00 D Rim Valve hole diameter = .035 inches MH90x21 TIRE SIZE = DUNLOP D402 MT90B16 72H
Jul 11, 2014 | 2006 Harley Davidson FXSTDI Softail Deuce
What are the wheel and tire sizes front and rear for my 99 1200 sportster?
Fitment for 1999 XL Tubeless Cast Wheels:
Wheel Position and size = 19 inch Front; Rim Size and Contour = T19x 2.15 MT; Rim Valve Hole Diameter = 0.45 inch; Tire Size = Dunlop D401 ELITE S/T 100/90-19
Wheel Position and size = 16 inch Rear; Rim Size and Contour = T16 x 3.00 D; Rim Valve Hole Diameter = 0.35 inch Tire Size = Dunlop D401 ELITE S/T 130/90-16
Wheel Position and size = 19 Inch Front; Rim Size and Contour = T19x2.50 TLA; Rim Valve Hole Diameter = 0.45 inch Tire Size = Dunlop K591 S&FR Elite SP 100/90-V19
Wheel Position and size = 16 Inch Rear; Rim Size and Contour = T16x3.00 D; Rim Valve Hole Diameter = 0.45 inch Tire Size = Dunlop K591 S&FR Elite SP 130/90-V16
Tire Fitment for 1999 XL Tube Laced Wheels:
Wheel Position and size = 19 Inch Front; Rim Size and Contour = T19x2.50 TLA; Tube Size = MJ90-19 Tire Size = Dunlop D401 ELITE S/T 100/90-19
Wheel Position and size = 16 Inch Rear; Rim Size and Contour = T16 x 3.00 D ; Tube Size = MT90-16; Tire Size = Dunlop D401 ELITE S/T 130/90-16
Wheel Position and size = 21 Inch Front; Rim Size and Contour = T21x215 TLA; Tube Size = 3.00 x 21; Tire Size = Dunlop Touring ELITE II MH90 - 21 56H
Wheel Position and size = 16 inch Rear; Rim Size and Contour = T16x 3.00 D; Tube Size = MT90-16; Tire Size = Dunlop Touring ELITE II MT90 - B16
Tire Pressure - All Models:
Cold up to 300 Lb. Load (includes rider, passenger and cargo)
Front = 30 psi (2.1 bar)
Rear = 36 psi (2.5 bar)
Up to GVWR maximum load
Rear = 40 psi (2.8 bar)
Jul 07, 2014 | 1993 Harley Davidson XLH Sportster 883
What are the wheel and tire sizes front and rear for my 99 883 sposter?
Tire sizes. Front 100/90-19
Rear 130/90-16
Wheel sizes front laced - 19 in.
rim width and contour - T19 X 2.5 TLA
Tube size - MJ90-19
Wheel size rear laced - 16 in.
rim width and contour - T16 X 3.00 D
Tube size - MJ90-16
Wheel diameter tubless rim front - 19 in
rim width and contour - T19 X 2.5 MT
Wheel diameter tubeless rim rear - 16 in.
May 26, 2010 | 1993 Harley Davidson XLH Sportster 883
The front drive train is wobbleing, i've tightened the nuts for my driver side tire and it appears that it was not the problem. In more detail, when the car gets up to 45 mph it starts to shake in the fwd...
Jack up the front and spin each of the front tires by hand, look at them from the front. I'm sure either you have a bad tire or a bent rim.
Bad tire- only the tread will move up/down or side to side.
Bent rim- the rim will move up/down with the tire.
Apr 17, 2010 | 2003 Pontiac Sunfire
2001 Jeep wrangler, at 45-50 mph, the front end and steering wheel shakes real bad.
I would start by first making sure you dont have a bent rim. Check the tires for any bubbles in the sidewall or any deformation in the tire as this would suggest a broken cord inside the tire. If that checks out, get the tires balanced and see if that solves the problem.
Jan 21, 2010 | 2006 Jeep Wrangler
Craftsman 30'' mower front tire off rim can't put back on
hello...is the tire loose but still on the rim...the sidewalls no longer engage the rim tight to hold air but still aroung the rim loose....If that's the case, get a jack, can of fix a flat, and a small ratcheting hold down strap.....jact the tire off the ground.....wrap the strap around the tire and ratchet it tight to get the beads of the tire to touch the rim....then commect the fix a flat or, if you have ,,,air from compressor to inflate the tire,,,,might have to work it a little to get the tire to reseat on the rim....this should work for you....once the tire is seated on the rim....stop inflating the tire until you remove the strap or you migh have a problem getting it to release from the tire if fully inflated....
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Overcharged for cleaning front rims
you were ripped a good one!!!!
find another mech!!!
Apr 11, 2009 | 1999 Oldsmobile Alero
Cub Cadet Op's Manual Model Lt1042 Lt1045 Lt1046 Lt1050 Logo
228 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
