Remote control code for bush tv model LT32M1CA
SOURCE: URC22B universal remote controller 15 in 1
Doing some searching I came across this, I hope it helps.
From instruction booklet
Power on the control device or VCR and put the tape in.
Press on the SET key continuously,then press the device key you want to set.For example, TV1/2,or VCR1/2,or SAT/CBL or AUX.
Then the LED is on, release the key you press.
Press the SET key again and release it,then you will go into QUICK SEARCH MODE and the LED will flash all the time.
Press the POWER key once at the device,URC22B will send another POWER signal of the next code.(If VCR/AUX, you will press the POWER or PLAY key). Observe if the device works(POWER OFF or PLAY),if it works, go to next step , otherwise repeat the step
whenever you want to leave SEARCH MODE,please press the device key,(TV1/2,or VCR1/2,or SAT/CBL or AUX.)
then the LED is off.
Then check other keys like [CH+/-],[VOL+/-] if they can be controlled.If cant be controlled,go back to the step
Posted on Feb 22, 2008
Benimur
  • 6966 Answers
SOURCE: Master Remote Control codes
Hi XX,
My sincerest apologies, I am not familiar with either the Strand Master 3 in 1 remote control or the Bush Television RF2185NTSIL/A.
However, a quick Google disclosed that a great many TV sets use the code 0065, 065 or 584.
Additionally, you can try 0742, 0157, 246, 263, 377, 037, 064, 065, 310, 300, 383, 399, 391, 402, 547, 292, 239, 312, 609, 322, 339, 515, 236, 389, 035, 191, 232, 245, 064, 0377, 0037, 0064, 0310, 0300, 0383, 0391, 0402, 0547, 0292, 0239, 0375, 0312, 0609, 0389 and finally 0339.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 01, 2008
SOURCE: bush tv remote code
need codes for universal control bush
Posted on Apr 13, 2008
  • 45 Answers
SOURCE: masterplug tvrc4n 4 in 1 remote control
bush has 1 code which is 022
Posted on Jul 25, 2008
1Guru
  • 61 Answers
SOURCE: codes for daewoo tv, ge remote model 24912
Codes for Daewoo are: 0451, or 0092
If this doesn't work with your new remote there is always the way that I have done it in the past and that is to use the find the code function on your new remote. It is a pain but can be done and is quite effective. Each remote is slightly different, but for the most part you would hit the set up botton and hold it in until it starts flashing then hit the T.V. Button and then hit the first code it tells you to hit and then hit the power switch if it doesn't turn off your T.V. then you hit the increment button up, (this is different for each remote so it is important to follow the instruction manual on this part) You bassically keep hitting the incriment button until your code comes up and then it will turn off your t.v.! Then your done. Note: It may take up to 400 pushes of the increment button, but it will work.
Posted on Dec 14, 2008
Bush LCD tv model No LT32M1CA keeps switching itself off & on randomly (about 7 years old)
This is usually a problem with overheating.
Make sure there is sufficient airflow and there is no dust blocking the vents
Oct 26, 2016 | Bush Televison & Video
Need code for my remote control for my Bush Tv
Codes are in the remote. Finding the code depends upon knowing the "brand" of remote and whether it is universal (URC-???).
Feb 01, 2016 | Bush 42" LCD TV 1920x1080, 50 Hz, Freeview...
Have lost my remote control where can I get a another for my Bush DVD144RC
RCA universal remote control will have setup code for Bush TV. You have to check which model sill suit your TV. Check it setup code list.
May 30, 2012 | Televison & Video
Remote Sky+ handset
I systematically tried hundreds of codes and by chance this method worked for me...hope it works for you too! Press TV then hold select and red til LED flashes twice. Enter 3 digit code 253 then press select again. Good luck! Sara
Dec 26, 2008 | Acer AL2671W 26 in. LCD Television
TV CODES
The following code: 253 will work on Sky remotes for the following tv:
Bush LT42M1CFA
Bush LT32M1CA
Sep 12, 2008 | Televison & Video
Remote code required for UK Bush tv model WS6680SIL/C7
Found the correct code for my TV & Sky remote... I searched a fair bit more on google for... "WS6680SIL/C7 code" and found... http://www.sjstv.co.uk/skycodelistNEW.html which the correct code for my Bush TV - 0742. Others you may want to try are Bush 0157 246, 263, 377, 037, 064, 065, 310,300,383, 399, 391, 402, 339. or Beko 0125 514, 398. Further, Alba Group are the firm whom own Bush brand amongst others. Google Alba Group to get their site and links to Bush sites.
May 20, 2008 | Bush WS6671 28" TV
Remote control code list
The Konig IR9982 is not a universal remote control so there is no code to make it work your Bush TV. It is actually a direct replacement (electronic clone) remote for some Hitachi models.
You will need a direct replacement for your particular model, try http://www.remotesreplaced.co.uk/television/remote-control-bush.htm
Feb 19, 2008 | Universal Remote Control DIRECTV Universal...
Sky remote code
codes for bush are
107
031
codes for bush uk are
005
038
140
018
052
143
020
058
152
022
085
169
031
107
172
036
121
175
015
043
141
019
053
144
021
078
156
026
099
171
033
109
173
226
196
hope this helps
Dec 08, 2007 | Directed 434MHZ Remote Control
Bush tv remote code
i have a bush lcd tv 27 inch an its stuck on stand by i have an urc7740 one forall remote how can i take my tv of stand by with this remote.
Aug 26, 2007 | Televison & Video
Televison & Video Logo
356 people viewed this question
Top Televison & Video Experts
