Question about GPS
It tells me it must be restartedto increase performance then goes back to main menu
  • 10,515 Answers
This means that there is a firmware update specifically for this model. Unless you uploaded that, this message would re-appear.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 03, 2010
Gigabyte G31
It is impossible to increase the performance of a built-in video card except increasing the video RAM. The more RAM you add the less main RAM will be allocated to the main memory. The reason is the video card uses Shared RAM.
To increase the video RAM go into the BIOS setup - video display - memory allocation.
The best way to improve is to install a video card in the AGP expansion slot, you may need to disable the on-board video in the BIOS.
Apr 06, 2012 | Gigabyte Intel G31 775 DDR2 )
Tip
Increase Your Laptop Battery Life
Hey Guys!!! wanna know a secret on how to increase life of your laptop battery...
It's too simple but most of us do this mistake which results in declining life of the battery...
Let me tell you what not to do....Never overcharge your laptop battery, ya u heard it correct whenever extra charge goes into your battery it really affects your battery life and performance...In other words as soon as your battery is charged unplug the charger immediately ...
on Feb 02, 2010 | Computers & Internet
COMPUTER WONT TURN ON when i press the button it goes green then quickly flashes blue then yellow then goes straight back to stanby
change the main wire look weather there is any problem in the main coputer wire slot
increase he ram even if you repair ir and don't increase the ram the same problem will continue after some days. the same thing happend to me please vote.
Nov 03, 2009 | Sony Playstation 3 (PS3) Console
My emachine is beginning to take a longer time to come back after the screen times out and goes black. Also, when I tried to install a game or program from a disc, the screen goes black and I have to press...
I would suggest that you take this case seriously and perform some normal maintenance checks like these ones that I would tell you.
First, open my computer, right-click on your hard drive, and select properties, then select tools tab, then under the tools tab, you should see error-checking, then click on "Check Now", then select the 2tabs under this and click on start.
It will tell you that it will be done at the next system restart, so click on OK. and restart your system.
Next, Defragment your hard Drive, by going to
the same place, and instead of error checking, you should click on Defragment Now.
All these things are going to take you a lot of time to finish but I'll tell you the truth...they are worth it.
After all these, you can now optionally improve the performance of your system by going to this place : Right-Click on my computer, Properties, then Click on Advanced, then under the performance tab, click on settings, and select 'adjust for best performance'.
This will change the appearance of your system and significantly increase your system speed.
Hope this gives you a great solution.
Jul 13, 2009 | E-Machines eMachines Desktop PC
Permanent Storage Write fail HP CP3525x problem no: 68
It appears that there is a problem with either the internal hardrive if you have this option installed, or the removeable Jet direct card if you have one installed, thirdly, it could be bad memory or the main board.
Go to HP's website and perform a firmware upgrade for your model if there is one.
I would first remove any add on option like networkcard, memory .... then turn the machine back on and see if the error goes away. You can also go through the menu and perform a fatory reset, this however in the process loose your IP address.
Onece you have aliminated the options I would move onto the main board or FIRMWARE
Jul 07, 2009 | HP Color LaserJet CP3525x CC471AABA...
Can you tell me how you get your sound to go higher and make the writting larger on this phone please
on all phone the sound increase / decrease button is located on the left hand side push up for increase push down for decrease .
for writting enlargment go
main menue
settings
main settings
writting size
change size to large
Apr 06, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Screen goes white
The main driver board, or the main processor board most likely has a failure. The authorized Panasonic service rep can replace the defective boards and perform the necessary adjustments to match them up.
If the set is out of warranty it may be expensive to service. Using the set with a defect can cause more damage, and thus may increase the cost of the final repair.
Jerry G.
Oct 11, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Not connecting to pc
You may want to get a new USB cabel.
I have had the same problem before.
Apr 19, 2008 | Samsung YP-Z5 MP3 Player
Contrast Menu appears after switch On
Contrast Menu appears after switch...
Jan 02, 2008 | Philips Standard 105S Monitor
GPS Logo
14 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
