Question about HP PhotoSmart C4385 All-in-One Printer
Can not connect to the http://0.0.0.0 to turn on my c4385 all in one wireless printer to work with my wireless network
professor_sc
  • 180 Answers
SOURCE: I have a laptop run
For this specific issue about installing the printer to a wireless connection. You need to install the software first as a usb connection. After the successful installation of the usb connection then you can add a device and it should work.
Step one: Gather the necessary hardware and information Follow the procedure below before obtaining your wireless network:
  1. Obtain your network SSID and WEP. To simplify this process, press the Wireless button on the all-in-one, and select Restore Network Defaults . This turns wireless off and sets the all-in-one's SSID to hpsetup .
  2. Press the Wireless button to turn wireless back on. Look for hpsetup when you select your network.
  3. Make sure that wireless is enabled on the all-in-one.
  4. Make sure that the computer that will be using the all-in-one has access to the router/access point.
You will need the following to set up the product on a wireless network:
  • A wireless 802.11 network that includes a wireless access point.
  • A desktop computer or laptop with wireless networking support or a network interface card (NIC).
  • Broadband Internet access is required for some features of the HP software to function. Cable Internet or DSL are examples of Broadband Internet access. NOTE: If you connect the unit on a wireless network that has Internet access, HP recommends that you use a wireless router (access point or base station) that uses Dynamic Host Configuration Protocol (DHCP).
  • The network name, or Service Set Identifier (SSID). NOTE: The SSID is obtained from the wireless router or access point using the embedded web server on the router. See the documentation provided with the access point for more information.
  • The Wired Equivalent Privacy (WEP) key or Wi-Fi Protected Access (WPA) passphrase, if needed. CAUTION: To prevent other users from accessing your wireless network, HP strongly recommends using a password or passphrase and a unique SSID to your access point. Your access point might have been shipped with a default SSID, which can be accessed by other users using the same default SSID. For more information on how to change the SSID, see the documentation that came with your access point. NOTE: The WEP key and WPA passphrase are obtained from the wireless router or access point using the embedded web server on the router. See the documentation provided with the access point for more information.Some access points provide more than one WEP key. Use the first WEP key (index 1) when setting up the wireless network.
  • If the network is set up with an Apple AirPort base station and you are using a password instead of WEP HEX or WEP ASCII to access this network, you need to get the equivalent WEP key. See the documentation that came with the Apple AirPort base station for more information.
  • If IP address filtering is set up, verify that the unit address is listed.
  • If MAC address filtering is set up, verify that the unit address is listed. NOTE: HP cannot set up or change the SSID, WEP key or WPA passphrase. This information is required before connecting the HP All-in-One to the wireless network.
Step two: Connect to an integrated wireless WLAN 802.11 network Follow the procedure to connect the unit to the wireless infrastructure network:
  1. Insert the software CD.
  2. Click Install .
  3. Click Next on the Please Allow All HP Install Wizard Processes screen.
  4. Select Easy Install on the Choose Easy Install or Advanced Install screen.
  5. Select Through the Network on the Connection Type screen. Figure 2: Connection Type screen c01160788.jpg
  6. When it doesn’t find your device, click Next . Figure 3: Using Network Setup c01164746.jpg
  7. Plug in your device via USB (it will tell you when to disconnect later). Figure 4: Making a connection to your all-in-one c01160790.jpg
  8. Select your network from the list, and click Next . Figure 5: Wireless Network Setup c01160791.jpg
  9. Enter your WEP key (if applicable). Figure 6: Specifying your network security settings c01160792.jpg
  10. Once it has completed connecting to the network, click Next . Figure 7: Network connecting completed c01160793.jpg
  11. Disconnect the USB cable from the computer and the All-in-One . Figure 8: Disconnecting the USB cable c01160794.jpg
  12. Click Finish to complete the software installation process. Figure 9: Software installation complete c01160795.jpg
Posted on Aug 05, 2008
leroyal
  • 2120 Answers
SOURCE: Lost setup disc for HP C4385 printer
Go to www.hp.com and let the website auto-detect your printer.
Posted on Jan 11, 2009
  • 34 Answers
SOURCE: Hello,
download the drivers straight from hp theres an error in one of the files
Posted on Nov 20, 2009
Semi-Driver
  • 434 Answers
SOURCE: I have a HP Photosmart C4385 All In One Printer
Choose your Operating system > Download full featured software
HP Photosmart C4385 Downloads
Posted on Dec 26, 2009
michaelshaun
  • 126 Answers
SOURCE: My wireless photosmart C4385 won't let me scan.
try doing a copy from the printer it copies fine then its a sotware issue and if it does not copy its a hardware issue
if its a hardware issue please go to the following website and try the steps :
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01718925&cc=us&lc=en&dlc=en&product=3651156
if it copies fine try the steps from the below mentioned URL :
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01843437&cc=us&lc=en&dlc=en&product=3651156
hope this should resolve the problem
thanks
hamid
Posted on Feb 18, 2010
How dow I get an install cd to setup wireless printing
1. Turn on the wireless radio on the printer.
2. On your laptop, open the list of wireless networks that you can connect to. You'll see a network named 'hpsetup'. You'll need to connect to this network. Ignore any security warnings and proceed with the connection.
3. Wait for 1 minute after this is done. Then print a network settings page from the printer. It should have an IP address starting with 169.254. This means that the printer is connected.
4. Click on the Support & Drivers link at the top of this page and download the drivers for the Photosmart C4385, and install it.
Mar 23, 2016 | Canon PIXMA MG3222 Wireless Inkjet Photo...
How do I set up the wireless connection on my hp c4385 printer?
Welcome to Fixya Support
I am Michelle, and i will be assisting you regarding the issue
Please click on the below link that has the officially recommended steps for wireless setup.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02283937&tmp_task=setupCategory&lc=en&dlc=&cc=us&product=3651156
Nov 19, 2010 | HP PhotoSmart C4385 All-in-One Printer
Reset Hp C4385 All in one printer to new ATT 2Wire router?????
Turn on your Wireless printer. You can use the touchscreen in the wireless printerto connect your wireless network. On the touchscreen, press the right arrow key and press setup. Select Wireless Setup Wizard from Network menu, it will search for the wireless routers in the range.
Feb 22, 2018 | HP PhotoSmart C4385 All-in-One Printer
My wireless photosmart C4385 won't let me scan. It's worked in the past and now it won't. It says "USB or wireless not connected." How do I fix this. If it has something to do with my network, please tell...
thanks
hamid
Feb 18, 2010 | HP PhotoSmart C4385 All-in-One Printer
Wireless Printer will not print wireless or connected
do you have the program disc if you do then inset it to the computer and hit restart installation and then follow the steps but make your you know your router name (SSID) first.
Mar 30, 2009 | HP PhotoSmart C4385 All-in-One Printer
I HAVE PRINTER HP C4385, I CANNOT CONNECT WIRELESSLY.
The easiest way is to reinstall the printer software and tell it your installing a network printer. It will prompt you on information it needs. Follow the user manual instructions.
Nov 19, 2008 | Office Equipment & Supplies
I have a sony vaio laptop running xp sp2 connected wirelessly to an HP C4385 printer. I can't get it to print in this wireless mode and I can't get a response from the printer when I put the printers IP...
I suggest you network the printer and access it through the wireless access point.
Also, I do not mean to insult your computer smarts, but if you do not have a driver installed, you will not be able to talk to the printer at all.
Aug 14, 2008 | Computers & Internet
HP PhotoSmart C4385 All-in-One Printer Logo
52 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
