Question about Kodak Easyshare C813 Digital Camera
When I turn on the camera it says lens error 111,0,0,0 then it says lens error 221,0,0,0 then it turns off..can you please help resolve this problem?
  • Kodak Master
  • 4,738 Answers
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Posted on Oct 03, 2010
    Guru:
  • 377 Answers
Go to the support page for your camera:
http://www.kodak.com/global/en/service/p...
Go through the guided troubleshooting guide and see if there is any help there. If that doesn't help, the guide should direct you to the contact info for service support.
I have a Canon PowerShot A430 camera. When I turn it on, the lens doesn't open and it shuts off. The message on the screen says " Lens error, restart camera." Please advise. Thanks
The Lens Error is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
You can reset the Camera back to factory default by performing the following steps:
Press the power button.
Press and hold the MENU button for more than 5 seconds. Default Settings will get displayed.
Use the arrow buttons to select OK and press the FUNC./SET button. This will reset all the settings back to factory deafult.
This should resolve the issue. If the issue persists, service may be required.
Thanks for contacting FixYa
Aug 10, 2011 | Canon PowerShot SD500 / IXUS 700 Digital...
When I turn on my digital camera the lens opens and closes and then the screen appears and says system error and shuts off compleatly what do I do?
Remove any storage cards that may be in the camera, replace the batteries (or put on charger if not replaceable). Try to turn the camera on, if you still get the error, contact Sanyo for help in trying a master reset for the camera. If the error resolves itself, turn it off, put the storage card back in. If the error appears again, then you have a problem with the storage card. Replace the storage card with a different one, and see if error resolves.
Aug 17, 2010 | Sanyo Cameras
Help with the Olympus FE-280 8.0 megapixel, please!!
this is a tipically problem, of a pressure on the lens, if the lens go out. or if the camera are dopped. to resolve this problem alone you must have specifically knowledge.
the cost of the reparation is high. so if you want prove withe the exact model number, search on the ebay international seller the komlet lens with ccd for you camera. any american seller if you buy the lens, can give a guide to change the lens block. but this is not a symply job. if you make one error you loose the camera and the lens. the price of your lens block can go from 25 to 35 euro, if you can change it alone you have resolved with this money. ok.?? sorry for my bad english if you want help can you write me and i will help you
May 30, 2010 | Olympus FE-280 Digital Camera
Nikon Coolpix S5 camera. Lens shutter remaining open.
From the manual: "Turn camera off and then on again. If error persists, contact retailer or Nikon representative."
Nov 18, 2009 | Nikon Coolpix S51c Digital Camera
Will not stay on
Will the lens extend when turning on? , can you see any message on the LCD? it is possible there could be a system error or lens error (lens error if jammed all the way in closed position, usually makes the camera shut off right away)
Sep 02, 2008 | Nikon Coolpix L11 Digital Camera
Says lens error!!!!!
The best solution is to take it to Best Buy and have them look at it. The Kodak camera could still be under warranty.
Jun 30, 2008 | Kodak Easyshare M753 Digital Camera
Lens error
Hey Wiggs12485,
This error message appears when the camera detects a problem with the lens when it's turned on. This is often caused by the user pressing on the lens when it is trying to extend, or the camera is being used in a dusty or sandy environment. When this message appears turn the camera off and back on, and this should resolve your issue. If this message continues to appear you should have the camera looked at by an authorized service technician because there is probably a problem with the lens.
Sincerely,
Allan
Go Ahead. Use Us.
May 04, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
A lens error requires to be sent into repairs. Give them a call at 800-706-2534 option 2.
Apr 02, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Restarting the camera
this would be because there is something stuck in the lens..could be the rubber protection stuck not enabling your lens to pop bback into position.i tried gently tapping the lens an gently twisting it to enable movement in my lens
Aug 13, 2006 | Canon PowerShot A420 Digital Camera
Kodak Easyshare C813 Digital Camera Logo
439 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
