Question about One For All URC 7740 Remote Control
Code for Palsonic 6830TG TV
I have tried the code that comes with the remote however I can only put the volume down but not up and cannot change the channels up either - so both the + buttons, one for the volume and one for the channels do not work!
I have tried every single code for the Palsonic that it states in the book!
Any suggestions?
Cheers!
E
    Sergeant:
    Champion:
  • 346 Answers
If the volume down ts working then that means the remote is working if the volume + does not work and the channel + then they need to be cleaned with isopropyl alcohol using a cotton swab, that means you will have to open up the remote control
Posted on May 28, 2008
Want code for palsonic TV model No tftv6839dt to match one for all remote
An applicable code would be in the remote. Use code search to find it. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not contain all possible codes.
Jan 21, 2017 | One For All Televison & Video
I have a palsonic model no: TFTV492LED and I can't change it off AV1. I want to put it on HDMI I have no remote either.
Try the front panel button labeled Source; it's the second button from the left. (The first button is the Power button.) All of the buttons are on the right hand side of the bottom frame of the TV. Use the Channel Up/Down arrows to navigate through the list of inputs. Try waiting for the selection to take effect. (The documentation says press OK or the Volume Up button. Sometimes, the Source button on the TV functions as an OK button. This isn't clearly identified for the Palsonic.)
If the HDMI input is greyed out, the TV may not be seeing a compatible signal from the source. Try turning on the device when the TV is off, then turn on the TV. I'm not sure if this TV will correctly see the signal from a computer. However, on some laptops, you'll need to enable the external video first. This is disabled to save power. Then turn off the computer. Finally, turn on the TV before turning the computer back on.
Palsonic has the manual available for the TFTV492LED on the product (discontinued) site under the Downloads tab. See http://palsonic.com.au/archive/led-tv/tftv492led.htm . The direct link to the manual is http://palsonic.com.au/customer_service/led-instruct/Palsonic_TFTV492LED_Manual.pdf .
I hope this helps.
Feb 29, 2016 | Televison & Video
I need sansai urc-l969 universal remote palsonic tv code
Codes to check with Palsonic are: 0152 0161 0166 0207 0249. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Oct 11, 2014 | Televison & Video
Why doesnt the volume on my remote control work?
The wrong code on the remote has been used. Though some codes will work parts of the system only the right code will operate all.
If you don't know the code for the TV, then you will have to try ALL the codes until you find one that operates all the controls.
Aug 09, 2017 | Charter Ltd Ocap-4 C4000 & S4000 4-device...
Need a remote for a PALSONIC 32'LCD TV Model no PLCD32HD Thanks
Universal remote control setup codes to Palsonic brand TVs are 028,019,092,082,045. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts. Setup code list and setup instructions to some popular model remote controls are given.
Mar 07, 2013 | Televison & Video
I have a Palsonic 6568pft TV model and my remot at
i need more information with respect your tv or device, because in internet i dont know look your model of tv
Mar 07, 2010 | Televison & Video
I m trying to program my RC64 remote for Direct TV and as soon as I press the mute/select buttons in order to put in the codes it says that my remote isn't programed for the TV yet so I cannot press that...
Hi, I work for Directv in the technical department... it is normal for the error message you listed to display on the tv when programming the remote. All you have to do is completely ignore whatever it says on the screen and just complete the remote programming process. I will summarize the instructions for you: First, press and hold mute and select until the green light above the mode switch on the REMOTE flashes twice(can take about 5 seconds of holding down before the green light flashes), then enter your 5 digit code using the keypad on the remote(no matter what it says on the screen-still ignore), after entering the code the green light should immediately flash twice again(that confirms the code was entered correctly), once that happens try pressing the volume up button on the remote, if volume bar displays on the screen increasing the volume then that is the correct code. Once that is all done and volume then works from directv remote slide the mode switch on remote back over to the left under DTV symbol and use remote as normal. Once you change channels or pretty much press any button on remote that is Directv related the error messages will disappear. I usually just press the exit button on the remote in irectv mode to clear the error messages. Hope this helps. :)
Jan 09, 2010 | RCA DIRECTV Satellite Remote Control
Reprograming my tv remote
Hi chevry,
universal remotes vary with respect to button options. For a Sanyo TV you can try these codes. (This is manual mode).
0098, 0066, 0091, 0023, 0017, 0027, 0080.
Press the TV button on the remote. Than press & hold the set button until the LED stays on. Enter the four-digit code. When the remote control recognizes the correct code the LED will turn off. If the code is not correct the LED will flash several times & stay lit. Enter the next code. (You'll have less than 25 seconds to try another code) or the remote will exit the programming mode.
How to use the auto search. (One code at a time). This will take some time.
Turn on the TV. Press & hold the set button until the LED comes on, point the remote at the TV & press the volume + once (This moves the remote through 1 code at a time. Continue to press the volume + (Do not do this very fast or you'll miss the correct code), until the TV turns off or changes channel. Than press the set button again & the LED will go off. The remote should now be programmed for the TV. Test TV by turning the on/off button on remote. Check volume up & down.
Good Luck!
Mike
Jul 04, 2008 | Televison & Video
Codes for palsonic televisions
Hi, that TV is not listed in the code list for your model.. You can try an automatic search by doing the following:
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. The
remote control is in programming mode
3. Press and release power. The POWER INDICATOR flashes once and stays on
indicating the unit is in Power Scan mode.
4. Press CHANNEL + or CHANNEL - repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
If the device responds, the remote control has been
programmed. If the device does not respond, repeat steps 2-5.
For future needs, here is the link to your manual:
Bookstone 538744 remote manual
Apr 12, 2008 | Brookstone 538744 Remote Control
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
Feb 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
One For All URC 7740 Remote Control Logo
373 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
