Question about HP LaserJet 3380 All-In-One Printer
Scanner Error - Power On > Power Off
Telephone shape LED and Exclamation point LED keep blinking while the 'Scanner Error - Power On > Power Off' message appears in the control Panel.
  • 4 more comments
  • Ed in Fla May 28, 2008
    Same thing started last week. Prints ok, nothing else. Tried the hard reset suggestion from HP Biz forums. No luck. Apparently the scanner carriage is about midway and does not return to the far right.
  • Anonymous Jul 29, 2008
    Scanner Error - Power Off > Power On
  • gvdgroup Oct 02, 2008
    warming bulb problem. turn off- on
  • estevens577 Oct 16, 2008
    the scanner is in the middel of the glass
    each time i turn the power off en then on the scanner moves a little to the right
    It does not go back en i can not copy or scan
  • Anonymous Jan 31, 2009
    Scanner Error - Power On > Power Off problem
  • dante_harris Mar 10, 2009
    Phone light and explanation mark blink on and off. screen says power error
Search 'clean scanner mirriors 3300 laserjet' on fixyourprinter.com for details on cleaning. A service manual is avalable-file name 100manualov.rv/hp-3380.pdf
Posted on Aug 11, 2010
    Problem Solver:
  • 7 Answers
One of two things are going on. There could be dust on the mirrors causing the Scanner to not read the black line under the Scanner top As black with a small amount of dust in the scanner assy. The system does not read the correct resistance on electric. Thats when it knows that its is calibrated for true black. From there it can do Gray scale. I would clean the mirrors on it then the bottom of the glass inside. If this does not work purchase a scanner assy at the contoller on the scanner itself is broke.
Posted on May 28, 2008
Sounds like the scanner has died. Sometimes restarting can help out. If you can print try printing out the configuration page and let us know what the error codes are.
Posted on Aug 07, 2011
Saya mau tanya solusi problemnya
Posted on Aug 25, 2008
Power on off error
Posted on Aug 09, 2008
4 Suggested Answers
  • 58 Answers
SOURCE: error light
it detected an error. try opening the paper tray to see if there are paper jammed. take out the the drum with powder and and turn off the printer. then put all back in place and turn on printer. usually the hp network printer is installed on the server. check on the server if you see on error from the hp driver program.
good luck.
Posted on Dec 06, 2007
dan231
  • 236 Answers
SOURCE: FLASHING EXCLAMATION POINT
Link to the manual: http://h10032.www1.hp.com/ctg/Manual/bpd09762.pdf
Basically it only means that the printer needs attention.
I would check for a paper jam or misfeed, out of paper, low or empty toner.
Posted on Dec 12, 2008
  • 164 Answers
SOURCE: error message,
REMOVE THE POWER CORD AND ALL CONNECTION CABLES. lET STAND FOR 2 - 3 MINUTES AND RECONNECT CABLES THEN POWER CORD. tHIS WHOULD ALLOW YOUR PRINTER TO CLEAR ITSELF AND RESET.
Posted on Feb 07, 2010
Just got a four handset phone: cant stop them from blinking...
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when people call while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Jul 22, 2012 | Lands Phones
There is a green blinking canister next to the power reset button and next to it is an orange light with an exclamation point. What is this indicating?-
Its an information / error led . It says server hardware has encountered an error. Find device that has error and replace it if required .
You can see a similar orange color on device that has error .
Check these parts for orange color .
1: SMPS
2: Memory
Thanks
Dec 12, 2011 | IBM x3400 Server
Hi Buddy, Can you help me with my HP printer? I keep getting a Scanner Error 8 message and it won't print. Time to buy a new printer?
Make sure the scanner usb and power leads are securely seated
the drivers for the scanner might have been corrupted
you might have to uninstall the scanner restart your computer then reinstall your scanner
if your printer/scanner came with an installation disc the drivers could be on it
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow Question/exclamation ? ! mark or a red X this will mean you need to install a new driver for this device right click to update driver
select properties again you will have the similiar options also have option to troubleshoot
HP PRINTER DRIVER PACKAGES
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=25523
hope this helps you
Nov 16, 2011 | Office Equipment & Supplies
Samsung led monitor blinks on pc but only on desktop picture
presss four buttons on the control panel simultaneusly and keep pressed untill
unlocked message will appear when unlocked message will appear your problem will be solved .all procedures will carry in power on condition
Oct 31, 2011 | Samsung SYNCMASTER 570DXN MONITOR 58.1 X...
The fax appears to dial the number successfully. The receiving fax is turned on. It apprears to try for a long time. The error report says "no answer."
It is not your fax line is the other party.did you try any other number?
Post back.
Solution one: Perform a fax line test Perform a fax line test to check whether the fax line is properly connected. Step one: Run a Fax Test
  1. Press the Setup button (c01395353.jpg ) on the product control panel.
  2. Use the Arrow keys (c01073166.jpg ) to select Service , select Fax Service , select Run Fax Test , and then press OK . The Fax Test prints.
    • If the report passes, try to resend the fax.
    • If the report fails with the message 'Fail - the phone line is not active,' plug the cable into a working telephone jack, and then try to resend the fax.
    • If the report fails with the message 'Fail - the cord is in the wrong port,' continue to 'Step two: Change the cable to the correct port.'
Step two: Change the cable to the correct port Make sure the telephone cable is inserted in the correct port. Remove the cord for the fax line from the port labeled with a telephone, and then insert it into the correct port. Figure 1: Fax portsc01756259.gif Scanner error message The message 'Scanner error ' displays on the product control panel while sending a fax. Solution: Check paper size This product only supports paper less than 381 mm (15 in). Use only letter, A4, or legal sized paper for sending faxes. To send this fax, copy or print the original document onto shorter paper, and then resend.
If you need more help come back.Post / thumbs / testimonial are welcome!
Dec 10, 2010 | HP Laserjet M1319F Laser Multifunction...
I DO NOT KNOW HOW TO SCAN FROM MY COMPUTER. tHERER USED TO BE A WIZARD A PERSON WOULD CLICK ON, NOW APPARENTLY ON wINDOWS 7 THEY HAVE REMOVED THE WIZARD??? KELSEY1@min.midco.net
Reload the software for the scanner. First remove the software from the control panel then reinstall it. You should have the wizard back. If not you need to go to Control Panel-System-Hardware-Device Manager and see if your scanner is listed as a device. It may need a windows 7 driver if it appears with a yellow exclamation point. If it is not showing you need to go to the manufacturer site and download a new driver. Windows 7 has a lot of hardware driver issues. Once you see the scanner listed in the device tab without any yellow exclamation point you should be good to go!
Feb 21, 2010 | Canon PIXMA MX310 All-In-One Printer
The amber lights are blinking next to the printer icons and exclamation points on top of the printer. How do i get that to stop so my print job can go through?
There 3 light on the printer that able to indicate to user when problem occur.
1st button light blink rapidly = the printer may be out of paper, so load more paper and press the 1st button itself to continue. Or may be paper jam is occur, so clear the paper jam and press the 1st button light itself to continue.
If 1st button light blink slowly = mean the cartridge carriers are stuck, so raise the scanner unit and remove any object blocking the path of the cartridge carrier, make sure the cartridge are closed and installed properly, then lift the scanner unit, gently push the scanner support towards the cartridge carriers, and carefully lower the scanner unit until it is completely closed. After that press the 1st button itself to continue.
If 2nd LED light blinking = the color cartridge need to be replaced soon.
If 2nd LED light is ON = the color cartridge need to be replaced immediately.
If 3rd LED light blinking = the black cartridge need to be replaced soon.
If 3rd LED light is ON = the black cartridge need to be replaced immediately.
YBC (/\)
Aug 06, 2009 | Lexmark X2500 All-In-One Printer
Fujitsu Scanpart 620c Leds error Amber on, Green blinking,red bli
Thank you for contacting Fixya.
You need to check the blinking times of the Paer jam LED. Then check the followings:
1. If the lamp is on, then ADF Switch is malfunctioning. Disble or short the switch.
2. If the lamp is off, then it is Flatbed or ADF Inverter error. Lamp inverter circuit is to be replaced.
5. If the Lamp is still off, then Lamp is to be replaced.
6. If the issue still persists, then you may have to contact the authorized Avision Service personnel for further diagnosis and suggested repair or replacement.
Hope the above information is helpful.
Please revert if you have any doubt.
Regards,
TechSatya
Mar 26, 2009 | Fujitsu ScanPartner 620C Flatbed Scanner
My hp laser jet 3030 keeps reading 79 error power on power off, pls hep with an answer
Try to perform a soft reset
1. Press MENU/ENTER.
2. Simultaneously press then release the * button and the # button to enter the Developer's
menu.
3. Press the < or > button until the message REINIT FFS appears on the second line of the
control-panel display.
4. Press MENU/ENTER.
5. The process takes approximately 2.5 minutes. During that time, the control-panel display
will change several times before returning to Ready.
6. When the Ready message appears on the control-panel display, press CANCEL to exit the
Developer's menu.
Jan 21, 2009 | HP LaserJet 3330 All-In-One Printer
Mitsubishi WD-52725 picture problem
Good Day;
1. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. (LED does not stop blinking after plug in) Disconnect the USB connector from the card reader to the front from the Chassis, if the LED stops blinking after 70 seconds replace the Card Reader part # 299P271010. 7. (LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). 8. (LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A 9. (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). Good Luck, big irish.
Nov 01, 2008 | Mitsubishi WD-52725 52". Rear Projection...
HP LaserJet 3380 All-In-One Printer Logo
3,135 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
